Windshield washer nozzle - possible blockage
Discussion in '2nd Gen Tundras (2007-2013)' started by Uncle Dave, Jun 2, 2020.
  1. Jun 2, 2020 at 8:07 AM
    Uncle Dave
    Uncle Dave [OP] TANSTAAFL
    Englewood, FL
    2010 Toyota Tundra SR5
    Added APS iBoard 5" Running Boards/Matte Black - Nice!
    I've a 2010 Tundra, double cab SR5, 5.7L 2-wheel drive. The passenger side nozzle squirts a bit of fluid, not enough to wet down the windshield; driver side nozzle works well. I think the nozzle is clear and that the check valve maybe the problem. Anyone have suggestions on better identifying the problem and possible solutions? Any info appreciated. Stay safe.
  2. Jun 2, 2020 at 8:42 AM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    I would remove the line from the back of the nozzle and see what type of pressure you have there. If you have good pressure and flow, nozzle is plugged.
    NewImprovedRon likes this.
  3. Jun 2, 2020 at 12:30 PM
    Uncle Dave
    Englewood, FL
    Thanks for suggestion. I tried that and it appears I'm not getting much flow between the check valve and nozzle. The driver's side nozzle works fine, so I'm thinking it's the "branch" from the check valve to the passenger nozzle that's the problem. I'll try clearing that and see if it fixes problem.
  4. Jun 2, 2020 at 12:53 PM
    SandyTRD
    SandyTRD New Member
    ‘16 Pro
    Dented bumper
    I had the exact same problem and it was the check valve.
  5. Jun 2, 2020 at 2:24 PM
    Uncle Dave
    Englewood, FL
    Thanks, SandyTRD. Were you able to clean the check valve or did you opt for a replacement? If replaced, where did you get the new one?
  6. Jun 7, 2020 at 9:22 AM
    Uncle Dave
    Englewood, FL
    Quick update: Thanks for the suggestions. Problem solved - it was the check valve. I installed a replacement and am now getting full flow.
    Now, i'd like to replace the nozzle as it sort of works but not getting the full spread that I get from from the driver's side.
    Anyone know which nozzle is appropriate? I see offerings of +2, 0 and -2 degrees. Really?
    Found it! 0 degrees, based on observation.
  7. Jun 7, 2020 at 9:56 AM
    SandyTRD
    SandyTRD New Member
    ‘16 Pro
    Dented bumper
    Sorry I missed your question! I replaced it too. And I got a 0 for the nozzle also and it goes like a racehorse now.
  8. Jun 7, 2020 at 9:59 AM
    Uncle Dave
    Englewood, FL
    Thanks - I wonder why 3 different nozzles? It's nuts.
  9. Jun 9, 2020 at 11:20 AM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    Why not just take it off and blow it out with compressed air to clean it? Or use a piece of wire to clean and shop air?
  10. Jun 9, 2020 at 12:07 PM
    SandyTRD
    SandyTRD New Member
    ‘16 Pro
    Dented bumper
    In my case I figured if the valve crapped at 4 years I’d rather replace it for $15 than screw with it. Short money for less hassle.
  11. Jun 10, 2020 at 2:08 PM
    Uncle Dave
    Englewood, FL
    Thanks for suggestions. Interesting that there were two problems: 1- check valve was faulty (now replaced and working), 2- nozzle was faulty (replacement ordered). I tried clearing the nozzle (air, fine wire) but didn't help; the spray is extremely weak and doesn't apply enough fluid to the windshield. I swapped nozzles (driver and passenger side) and the results confirmed the one nozzle is faulty. Can't be running around with an underperforming nozzle! I suspect the faulty one was replaced sometime in the past (before I bought the truck) as the fit was extremely loose. I found OEM part on eBay, awaiting arrival.
  12. Jun 10, 2020 at 10:03 PM
    FWD Tundra
    Washington
    At least you tried to clean it and did a little trouble shooting to confirm bad nozzle before throwing new parts at it. Good job!
  13. Jun 11, 2020 at 11:54 AM
    Uncle Dave
    Englewood, FL
    Don't want to spend $$ if unnecessary. New nozzle showed up, installed, and all is right with the world.
  14. Jun 11, 2020 at 12:00 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I was going to suggest soaking it in white vinegar, glad you got it fixed.
  15. Jun 11, 2020 at 12:09 PM
    Uncle Dave
    Englewood, FL
    Might have worked, but the old nozzle was a poor fit making me think it was an aftermarket. OEM fits tight and right.
  16. Aug 7, 2022 at 10:40 AM
    GayFish
    GayFish Member
    2016 Super White SR5 CM 5.7L 4X4
    Anyone replaced the check valve on a 2.5 Gen? My 2016 isn't spraying on the passenger side and the nozzle seems clear. I saw some videos on the 2nd Gen and the valve is visible, for the 2014+ they seem to have put it somewhere under the hood insulation pad....
