Gonna pull with the Tundra for the first time tomorrow
Discussion in '2.5 Gen Tundras (2014-2021)' started by graves037, Jul 7, 2017.
  1. Jul 7, 2017 at 7:06 PM
    graves037
    graves037 [OP] New Member
    Michael
    Pea Ridge AR
    16 Tundra SR5
    3" readylift, trail grapplers on 20" rockstar II's, truxedo lopro, lund bull bar, 20 & 30 in lightbars, tint, LEDs
    Tomorrow is gonna be the maiden voyage for the tundra tomorrow....not a lot, just a 4 seater Kawasaki teryx and a Polaris sportsman on an 18ft car hauler
  2. Jul 7, 2017 at 7:07 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Should be a piece of cake from what I've seen. Have fun.
  3. Jul 7, 2017 at 7:18 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    17' Tundra SR5, 12' Tacoma TRD offroad
    Should be easy day, I just pulled an 18ft car hauler and the truck did great. 70mph on the highway with ease.
    Do you have the integrated brake controller? If so how's it working out for you?
  4. Jul 7, 2017 at 7:21 PM
    graves037
    Michael
    Pea Ridge AR
    16 Tundra SR5
    Good to hear! Yes I do, and all good so far but until tomorrow I've only toted the trailer around empty
  5. Jul 7, 2017 at 7:24 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Were you able to get the trailer tires to lock up with the empty trailer?
  6. Jul 7, 2017 at 7:35 PM
    graves037
    Michael
    Pea Ridge AR
    16 Tundra SR5
    Well no, but I had the gain at 3 or 4 and never tried to make them lock em up. What am I missing here? Are there issues with it? What are they?
  7. Jul 7, 2017 at 8:38 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Yeah, many have had issues with it not performing well. I had my gain set to 10 when I pulled my 18ft car trailer last week and could never achieve lock up, that's why I was curious.
  8. Jul 7, 2017 at 9:39 PM
    Before leaving with a trailer, you should always test the trailer brakes. Roll forward 2-5 mph and manually use the brake controller to stop the truck.
    You can also use the controller at full power and try to pull forward.
    Either way, if the brakes don't stop you or prevent you from rolling forward, something isn't right.
    There is another check to do for testing the emergency braking system, but I would just start there for now.
    Most states it is mandatory to have two functioning braking axles on trailers over 3000 lbs. I am required on my trailer before I put anything on it.
    NewImprovedRon and joonbug like this.
