Rear Air bags......finally
Discussion in '3rd Gen Tundras (2022+)' started by Papa Smurf22, Aug 5, 2022.
  1. Aug 5, 2022 at 10:55 AM
    Papa Smurf22
    Papa Smurf22 [OP] New Member
    Jimmy
    Lacey,wa
    2022 Blueprint limited tundra trd
    Black out emblems, dominator d6 boards, westcott leveling kit, 17” Moto Metal rims with 33x12.5 Irok Swampers
    So look what came up on air lifts website. i will be pick these up down the road and ditching the firestones
    Keeferton likes this.
  2. Aug 8, 2022 at 12:11 PM
    t300
    t300 New Member
    Manitoba
    22tundra
    So the question is are these considerably better than the firestone kits that people have been installing, if so what makes them better? Not a challenge just want to know. Just over $100 firestone vs close to $500 for this so quite the difference
  3. Aug 8, 2022 at 12:30 PM
    Papa Smurf22
    Jimmy
    Lacey,wa
    So main difference is the firestone are only rate for 1000lb were there are 5000
  4. Aug 8, 2022 at 2:00 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    These will make your truck ride like crap unless you are running weight constantly
  5. Aug 8, 2022 at 2:13 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Are you really going to load 5000lbs? I'd like know how it works out for you.
    Roctane84 likes this.
  6. Aug 8, 2022 at 5:03 PM
    JohnnieBoy
    JohnnieBoy New Member
    2022 Army DC 4x4
    Icon Stage 3 Method 316's on 275/70/18 Ko2's NYTOP bumper w recovery's Leer 100XR
    Correct. As have I.
  7. Aug 11, 2022 at 8:01 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    Alright. What all would I need to have these and be able to air up all at the truck. Like can I have an on board compressor connected directly to these, so I don't have to air up with a chuck?
  8. Aug 11, 2022 at 8:06 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    so glad i have oem air bags :)
  9. Aug 11, 2022 at 8:40 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    :spending:
  10. Aug 11, 2022 at 8:58 AM
    mass-hole
    mass-hole New Member
    Which is completely unnecessary because its a half ton and probably doesn't even have much more than 1000 lbs of axle capacity available.
    Everyone who has ever put the 5000 lb bags in F150's(which is a lot because more is always better, right?) has complained about the trucks riding like dog crap after. I run the airlift Ridecontrols on mine, which are 2000 lb bags, and they are completely transparent when deflated. But I have filled my 6.5' bed to about 3/4 full with crushed stone and was still able to level it out.
    I wouldnt run them unless you absolutely have no other option.
    I do have AirLift 1000 lb bags in my Lexus GX coils and have noticed it tends to cause the back end to be a little more wiggly even if they are deflated.
  11. Aug 11, 2022 at 9:07 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    So this is too much?
  12. Aug 11, 2022 at 9:08 AM
    mass-hole
    Super cool. Would have been nice if Toyota had made a crewmax with a real bed though.
    Was that 5000 lbs?
  13. Aug 11, 2022 at 9:21 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Nah, didn't weigh it though.
  14. Aug 14, 2022 at 11:54 AM
    porterbc
    porterbc New Member
    Brandon
    2022 Tundra Crewmax Limited TRD OFF-ROAD
    Just found these this morning. I pull a 7x14 14000lb dump trailer quite often and tired of the sag..
    Ran air bags before.. they will actually ride better then coils if you only use the amount of air required.. ie: low psi empty… if you ride around with same are pressure in it you used to pull 10k lbs, yeah it’ll ride like a dump truck.
    Can’t wait to order a set and install them. Be perfect when BW Hitch finally releases their under mount goose neck hitch..
    these trucks are wonderful tow rigs for 1/2 ton market. If they put more then a 4 ply tire on from the factory we’d likely have more then a 1400lb payload capacity. 18,000km on my 2022 and tires are pretty much toast!
    SC4333 likes this.
  15. Aug 22, 2022 at 7:17 PM
    SC4333
    SC4333 New Member
    Grant
    2022 Tundra Limited TRD OR 4x4
    Agreed. I have had great success with this type of airbag in the past. When used as intended, they have a better ride quality than stock while loaded and no difference over stock when unloaded. I have a set on order and will hopefully get around to installing them this weekend.
    https://www.sdtrucksprings.com/index.php?main_page=product_info&products_id=59000
