Ditch Light Wiring??!
Discussion in '3rd Gen Tundras (2022+)' started by Frozen.Tundra, Aug 3, 2022.
  1. Aug 3, 2022 at 6:19 PM
    Frozen.Tundra
    Frozen.Tundra [OP] New Member
    2022 Army Green 1794 6.5 TRD
    Ran the ditch light wiring in my 4runner no problem, but cant find any guides online as to how to do it in a 22 Tundra.
    Figured I'd be the first to write something up.
    Being that the engine is so far back in the bay, I think the best option is to run the wiring behind the heat shield I circled in the photo, and send the switch wire in through the firewall where a bunch of the wiring goes.
    Any advice from someone who has already would be appreciated!
  2. Aug 3, 2022 at 6:23 PM
    Taco-Spike
    Two Trucks
    Looks like you have the pics where everything should / will go.
  3. Aug 3, 2022 at 8:38 PM
    pandapro
    pandapro New Member
    That looks like a tight fit and you may want to consider fishing the wire out from the cab to the engine bay.
    Is there another grommet to pass through the firewall? In the 2.5 gen, there is one on both the driver and passenger side.
    Another option is to pick up a wireless switch controller like the trigger 4 or 6. If you plan on adding other accessories, this would save you the trouble of fishing more wires through later on.
    Frozen.Tundra[OP] and Roctane84 like this.
