Dash Clock Replacement
Discussion in '1st Gen Tundras (2000-2006)' started by tundrainsc, Aug 3, 2022.
  1. Aug 3, 2022 at 4:54 AM
    tundrainsc
    tundrainsc [OP] Happy Tundra 1st Gen
    06 Limited 4.7 2WD
    My clock has quit working on my 06 DC Limited. It was so dim I could never read it anyway during daylight. I would like a small thin clock to stick on the dash where the factory installed one is. Can go on without a working clock if I can't find a nice looking stick on. If anyone has found a replacement pls post picture and seller info
  2. Aug 3, 2022 at 5:26 AM
    Interesting. I seem to remember the clock is just part of the 4WD switch assembly panel, I just can't remember if it was a modular component or not, or something you could easily replace.
    I really need to take pics of the back of my center dash panel next time I've got it off to work on stuff.
  3. Aug 3, 2022 at 5:30 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Inexpensive options
    Novinex Ultra-Thin LCD Digital Display Car Vehicle Dashboard Clock with Calendar(Color:Black) https://www.amazon.com/dp/B07DYRQJCV
    YOUNGFLY Mini Car Clock Auto Car Truck Dashboard Time Self-Adhesive Bracket Vehicle Electronic Digital Clock https://www.amazon.com/dp/B07L13BCXR
  4. Aug 3, 2022 at 6:15 AM
    You might be able to fix it if you can get the clock circuit out of the bezel assembly. Supposedly a lot of the failures are due to cracked solder joints that just need touch up with a soldering iron.
    shifty` likes this.
  5. Aug 3, 2022 at 7:19 AM
    ... or solder in a light-gauge jumper after you test traces for continuity.
    I've also heard the HVAC controls having solder joint cracking issues. And there's a company somewhere out there who'll fix the board(s) if you remove and ship to them. I'd need to dig for the info. I have it stuck in my head theo ne company others mentioned is in TX.
  6. Aug 3, 2022 at 7:48 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    They did not make it impossible to touch up soldering but they sure made it a challenge. Had that whole circuit board off last year checking the 4WD drive switches and general look see. The clock module has about 30 paper clip size prongs that go downwards about 1 1/2" to circuit board.
  7. Aug 3, 2022 at 8:13 AM
    Huh. Thanks for posting that, Bubba
    So it looks like it's a shared PCB with the 4WD controls (@Scuddog this may be interesting to you). So if you got a working board, it wouldn't be too difficult to board-swap, a couple of screws to get there, as long as the donor truck was (ideally) same year, with same drivetrain (2WD/4WD). So not a horrible fix to replace the clock by way of replacing its circuit board.
    I don't see any HVAC controls through that specific PCB. I do see the little 5-wire jumper over to the airbag light/hazard control (or whatever). I'm surprised to see two power bulkheads on the PCB with the clock, unless one of those is feeding out to somewhere else for the 4WD buttons. @Scuddog that's kinda what I'm wondering here with your buttons. Maybe one of those connectors is loose, or maybe you've got a bad trace on your board?
    EWD would let you figure out the pinout for each connector and what power (if any) should be on each.
  8. Jun 9, 2025 at 5:30 AM
    BooRoc
    BooRoc New Member
    Drew
    @shifty` @BubbaW Hi Guys-My clock is constantly acting strange and has number lights out of sorts-The semi colon {:} between the digits blinks rapidly and the minutes move like seconds at times. Its erratic. Will this lead to other issues if I leave it alone? I don't have the wherewithal to solder it. I appreciate any feed back.
  9. Jun 9, 2025 at 6:28 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    BooRoc and whodatschrome like this.
  10. Jun 9, 2025 at 7:26 AM
    BooRoc
    BooRoc New Member
    Drew
    i appreciate it. I can live with it. Was worried about an electrical issue down the road or with other functions.
  11. Jun 9, 2025 at 7:52 AM
    I suspect @Jack McCarthy can speak more intelligently on this, but pretty sure the clock just uses a standard chip to deal with time progressing/clocking. Whether or not you could just swap it from another is another conversation. It's also no clear to me how easy a swap of the control PCB is.
    BooRoc[QUOTED] likes this.
  12. Jun 9, 2025 at 8:06 AM
    BooRoc
    BooRoc New Member
    Drew
    @shifty` You always pull through for me. Not related to this but my LCA bushings are shot on both arms, there oem. I'm not a moog guy but is there anything recommended besides OEM.
  13. Jun 9, 2025 at 9:50 AM
    When I’ve seen that behavior on other circuits (non Tundra related) it was typically due to a bad crystal oscillator or connection from it. If the oscillator isn’t visible (small metal rectangular can) it’s probably embedded within an IC package. Might be hard to tell without more knowledge of the components used. A usual giveaway is if the frequency is printed on the package.
    Then again, it could be something completely different. Just giving you my real world experience.
    G_unit3000 and bmf4069 like this.
  14. Jun 9, 2025 at 10:12 AM
    BooRoc
    BooRoc New Member
    Drew
    @Jack McCarthy Thanks alot Jack! I will just let it be for now. I appreciate your intel.
    Jack McCarthy likes this.
  15. Jun 9, 2025 at 1:45 PM
    Honestly, unless you have the means to press out the OEM bushings and install new OEM bushings, I would just wait for the next Toyota sale and buy complete LCA from Toyota directly. Pressing the old bushings out and getting new ones in isn't as easy looking as I've seen on other vehicles.
    The price point difference between getting the OEM bushings alone and the price of the arms with bushings you're paying like 30% more to get the complete arm, and there's no labor involved with pressing.
    Big problem with aftermarket arms is they tend to use shitty Chinese rubber that starts to disintegrate within a couple of years.
    BooRoc[QUOTED] and G_unit3000 like this.
  16. Jun 9, 2025 at 2:36 PM
    BooRoc
    BooRoc New Member
    Drew
    Word. Much Obliged.
  17. Jun 10, 2025 at 8:56 AM
    RadarLove
    RadarLove New Member
    LED interior swap, that's about it so far
    Is there a delete you can put in the place of the clock? Like a little cubby or something to make it look stock? My clock works but it's hard to read and I really don't need it. (will put a better stereo in there at some point)
  18. Jun 10, 2025 at 9:10 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    You could be the first to 3D print one and sell it to us. Here is a pic (not mine) for reference.
    Jack McCarthy and BooRoc like this.
  19. Jun 12, 2025 at 7:05 AM
    RadarLove
    hmmmm....good idea, i got something in the works, i'll post if it works out :)
  20. Jun 29, 2025 at 10:42 AM
    BooRoc
    BooRoc New Member
    Drew
    @shifty` Hey Shifty-I hope all is well Man. Sorry to beat a dead horse or sound greenhorn but I need to pick your brain more on this topic of LCA/Bushings. The OEM lower control arms are $360 a piece. I spoke to several Toyota dealers and the guy at Ourisman I deal with said these OEM LCA's rarely go on sale if ever. Do you know if the OEM Bushings have metal casing on them? Do you know if Energy Suspension or a better source that makes poly bushings that fit our truck. I want to try or at least explore and press the bushings in but want advice from guys like you on what the major conflicts are. I cant swing 360 a pop right now for LCA's and want to investigate pressing either OEM or equivalent bushings into my stock LCA. Is there a superior bushings out there to OEM that can be pressed. I know this forum is very cult like, but your different. Any advice you can share would be greatly appreciated. I have a ton of respect for you. Hang Loose.
  21. Jun 29, 2025 at 2:09 PM
    I only know they're a bitch to press out (LCA bushings) and aftermarket use shitty rubber that disintegrates.
    I also know that parts person you talked to is very misguided. And if you need the proof, @FirstGenVol caught new OEM LCAs for his 2002 access cab on sale, and here is his price out the door ordering from THIS DEALER, who, if you're not in Alabama, doesn't charge tax and is free shipping on orders more than $75 (up to $200 shipping cost). There is a 15% off sale coming for 4th of July some time in the next few days. Does this price look like $360/ea to you?
  22. Jun 29, 2025 at 2:33 PM
    Those people were wrong. Toyota has sales on parts frequently and as Shifty said, I was able to buy mine on sale.
  23. Jun 30, 2025 at 3:56 AM
    BooRoc
    BooRoc New Member
    Drew
    Thank you guys. I wasn't gonna pay that but needed more information. I just wish there was a reputable method to press in and out the bushings. Here is a couple screen shots from Oursiman Toyota. I appreciate your help.
  24. Jun 30, 2025 at 10:48 AM
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    Apparently the sale has already started and it's 20% off.
    shifty` and BooRoc like this.
  25. Jun 30, 2025 at 5:27 PM
    Nice. @MYOTA67 be aware: The sale has started, and it's 20% off.
    @BooRoc, the parts Ourisman gave you are both for the passenger side, what the hell? Passenger starts 48068 and driver starts 48069, both end the same.
    I ran up a cart with the left/right arms, left (driver) here, and the right (passgr) here. This is what you'd be paying out the door, shipped, no tax if you live in any of the 49 states that aren't Alabama, ordering from Serra's Birmingham location. Tell Ourisman to eat a bag of dicks, this is $40 more than a single arm they've quoted you. $406.19 if you buy during this sale, shipped.
  26. Jul 1, 2025 at 3:12 AM
    BooRoc
    BooRoc New Member
    Drew
    Thats incredible. Thanks Man. What a difference.
  27. Jul 1, 2025 at 6:31 AM
    $253 for arms that will last another 150k ain't bad. I checked mine Sunday and the bushings still look great. I replaced them ~2 years ago I think.
    G_unit3000 and BooRoc like this.
  28. Aug 10, 2025 at 7:41 PM
    stevon
    stevon New Member
    Stephen
    San Diego
    2003 Tudra
    20" rims
    tundrainsc,
    I recently purchased a 2002 access cab 4 door, have never seen the clock work even before I bought the truck. Took the dash center face off of the radio because I'm upgrading the stereo, took a stab to fix the dead clock display. First I had to figure how to remove the assembly from the truck, was a big pain but I got it out, taking the assembly apart I found a white wire disconnected and partially stripped. Trying to remove what I thought was a connector was a collection of soldered in pins which started breaking off the board as I was pulling on them, I finally just broke off the rest, cut off the pin housing (not a removeable connector) and just directly soldered each pin to the board. These 20+ year old plastics are extremely fragile, board hold down clips just fell a part in my hands! Had to hot glue the unit back together, any ways when I plugged it in success! clock lights up probably for the first time in 10 years but I inadvertently created a new problem the flashers were stuck on and constantly flashing when I plugged in the unit. It turns out that the pins are so close that my solder job jumped across and shorted the two pins to operate the emergency lights, cleaned up the pins, re soldered and wala! back in business. Still waiting for parts to make some more progress...
    Stephen
    tvpierce likes this.
