Adding trans oil
Discussion in '2nd Gen Tundras (2007-2013)' started by Jorg4709, Jul 18, 2022.
  1. Jul 18, 2022 at 7:38 AM
    Jorg4709
    Jorg4709 [OP] New Member
    Jorge
    Toyota Túndra 2008
    Somebody got a video about how to put tranny oil on a Tundra?
  2. Jul 18, 2022 at 7:49 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Are you losing tranny fluid?
  3. Jul 18, 2022 at 8:04 AM
    Jorg4709
    Jorge
    Toyota Túndra 2008
    No; I bought the truck a year ago and I want to know if it needs
  4. Jul 18, 2022 at 9:34 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    If it isn't leaking then it shouldn't need any. It's a relatively complicated process of getting the trans up to temperature and then all that you can prove is if it's overfilled since there's no conventional dipstick. There's some youtube videos if you search change tranny fluid.
    FrenchToasty and baraynavab like this.
  5. Jul 18, 2022 at 9:49 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  6. Jul 23, 2022 at 10:13 AM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    2007 Tundra CrewMax 4x4 5.7L V8
    Yeah so how many miles does your truck have? Do you know of the tranny fluid was flushed before? If not you may have to do a full tranny fluid drain and fill. Which is a little complicated but doable. Tranny fluid should be changed every 60k miles. Sooner maybe if you tow big stuff more often.
    Also make sure you use the Toyota OEM WS tranny fluid. That's the only fluid that I would put in the transmission. It's a little expensive but it's OEM standard. Like the whole drain and fill should cost you about 60 bucks I think if I remember correctly.
    I started doing a tranny fluid drain and flush but when I opened up my drain plug I got clean cherry red fluid smells sweetish as well. Which indicates to me that tranny fluid was in good condition. So I didn't replace it.
  7. Aug 2, 2022 at 4:14 PM
    Borgunit
    Borgunit New Member
    JR
    Ohio
    2013 Black Rock Warrior
    mav7021234 likes this.
  8. Aug 2, 2022 at 4:25 PM
    Borgunit
    Borgunit New Member
    JR
    Ohio
    BTW. If you drop the pan and things go bad (broken bolt). This guys advice is a life saver. Especially the chiseling out the bolt portion.
    You have been warned.
    https://youtu.be/z5UoXzvVP5c
