How to Reset Your Incorrect Fuel Gauge
Discussion in '3rd Gen Tundras (2022+)' started by PapaDave418, Aug 2, 2022.
  1. Aug 2, 2022 at 12:01 PM
    PapaDave418
    PapaDave418 [OP] A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
    These steps refresh your gas gauge cluster if it is showing an incorrect amount. For example you know you have half of a tank (and your wife never secretly fills the tank for you) then suddenly it’s displaying a full tank. This will not fix the issue, this just allows you to know how much fuel you actually have in your tank.
    I talked to my lead tech at my local Toyota dealership and he said they are aware of the issue, it is a software fix, but those take a while to test to make sure that it’s not affecting any other system in the truck.
    If you suspect your fuel gauge is off, step 1 is to simply remove the gas tank. Jk
    1- Come to a stop and while still in DRIVE turn off the truck
    Then off
    2- Take a deep and calming breath and Shift to Park
    3- Hold perfectly still, don’t even breathe, and watch your gas gauge to see if it moves
    4-Take your foot off the brake sad at how little gas you actually have and turn off the truck fully
    BTW all that dust came from the mountains I’ve conquered
  2. Aug 2, 2022 at 12:53 PM
    deepdesign
    deepdesign New Member
    Ok. I got the gas tank off. What’s the next step??
  3. Aug 2, 2022 at 1:05 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Always use instant mpg, more useful than the average at teaching a driver to be economically efficient. Like dont let it hit 10 or using downshifting to hold that 99 a little longer...sucking at 'coast & squirt' is more common than most folks realize.
  4. Aug 2, 2022 at 1:08 PM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Next is to squirt WD-40 into your twin turbos
    Medicineman likes this.
  5. Aug 2, 2022 at 1:08 PM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Ummm huh?
  6. Aug 2, 2022 at 1:32 PM
    j.b.
    j.b. New Member
    Jake
    2022 Platinum MGM
    This post definitely validated my choice to wrap my piano black trim piece around my shifter. Scratch magnet :(
    murtro, DBWA, docfnky and 3 others like this.
  7. Aug 2, 2022 at 1:33 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Squirt, get to the speedlimit safely, but quickly, then try to coast.
    Coast, use minimum throttle to climb hills or pass. Sometimes involves dropping to a lower gear for more power @ 20% throttle.
    on the highway, i can commit to that around 50%. Sometimes i need to accelerate around someone, or slow to hold momentum where the efftards use unnecessary brakes.
    really gets you in the mood to take all traffic offenses personally. And keep you attentive to your own traffic 'Edda quit' lol, that was my iphones spell check.
  8. Aug 2, 2022 at 1:39 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    thats all I noticed
    murtro and DBWA like this.
  9. Aug 2, 2022 at 1:44 PM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Haha so I read this and marched out to my truck with cleaner to see how the scratches look, dammit!
    So the first photo has now been changed, but there are some light scratches that really just show up in the photo. So weird. Hard to see with the eyeball, easy in the photo. Those white specs are from a paper towel and again easy to see in the photo, barely there in real life. What’s the world coming to when photos don’t depict real life!
  10. Aug 2, 2022 at 1:51 PM
    j.b.
    j.b. New Member
    Jake
    2022 Platinum MGM
    I just wish Toyota didn't choose to put arguably the most easily scratched surface known to man in the spot that has the most things coming in contact with it. Only took like an hour to throw a vinyl wrap on it if you were so inclined. I suppose it is still better than the glossy fake wood-grain of the past? *cough* GMC *cough*
  11. Aug 2, 2022 at 1:55 PM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    True, got a photo of what you did?
  12. Aug 2, 2022 at 1:59 PM
    j.b.
    j.b. New Member
    Jake
    2022 Platinum MGM
    I picked some sort of satin dark gray metallic. Considering changing the color to match the silver piece above it a bit better, but honestly it doesn't stick out at all either way.
  13. Aug 2, 2022 at 2:17 PM
    eddiefromcali
    Eddie
    100% Stock
    might have to try wrapping it vs paying $100 for the tufskinz overlay.
  14. Aug 2, 2022 at 2:19 PM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    @j.b. Wrap looks really good. Did you have to pull the black trim piece out to wrap it or can you wrap it in place?
  15. Aug 2, 2022 at 2:20 PM
    j.b.
    j.b. New Member
    Jake
    2022 Platinum MGM
    the material for the wrap cost me $17 from Amazon.
  16. Aug 2, 2022 at 2:22 PM
    j.b.
    j.b. New Member
    Jake
    2022 Platinum MGM
    I pulled it all out. Some guy made a youtube video on it, and I just followed that. Took the guesswork out of the equation.
    https://www.youtube.com/watch?v=YIQKJ8wqjmw
  17. Aug 2, 2022 at 2:24 PM
    eddiefromcali
    Eddie
    100% Stock
  18. Aug 2, 2022 at 2:26 PM
    PERRY1060
    Perry
    Indiana
    Nice thanks for the link.
    j.b. likes this.
  19. Aug 3, 2022 at 5:55 AM
    deepdesign
    Oh wow so I just did that and the gas gauge dropped down. My question was it correct at the higher level or at the lower level.
  20. Aug 3, 2022 at 8:14 AM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    I have found that whatever it moves to when I do this process is the correct amount, provided you are on flat ground when you do it
  21. Aug 7, 2022 at 3:22 PM
    eddiefromcali
    Eddie
    100% Stock
    I've tried this several times, doesn't fix it :(
  22. Aug 7, 2022 at 9:24 PM
    Tundra009
    Tundra009 New Member
    Concord, CA
    Just a note if you decide to wrap it yourself. Pay attention at the electrical plugs when reconnecting them. There are a total of 3 plugs behind the plate. 2 of them can be plug in to the other one causing your switch to burn. I made that mistake and tech said I swapped the 2 wires. This burned my switch and I was I was stuck in 4H and you will not be able to switch it back to 2L. Yes you can swap them and they will go in. Bad design as they are so close to each other that you can accidentally swap them.
  23. Aug 7, 2022 at 10:09 PM
    eddiefromcali
    Eddie
    100% Stock
    Assuming this only applies to 4x4 trucks then?
  24. Jul 12, 2025 at 9:51 AM
    G8Santini
    G8Santini New Member
    25 Tundra SR5, 4x4, PremCnv, Perf. Pkg., Blackout, TRD 3”Lift, 20”TRD rims
    Heritage grille, fog lights, 35x12.5x20” Nitto, low profile toolbox, F/R tow hooks
    3 years later your still helping folks. Did it today on a 1.5 month old 2025 with tank reading about 1/8 off. Can make a big difference if you have the smaller 22.5g tank. Appreciate it!
  25. Jul 12, 2025 at 11:07 AM
    eddiefromcali
    Eddie
    100% Stock
    That method works great for lower trims with an actual needle gauge, not for the digital cluster on my 22.
    This method worked for me
    kirkb likes this.
  26. Jul 14, 2025 at 11:09 PM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    T-SB-00038-0025 fixed this fuel gauge issue on my 23 and I’ve heard on 24’s as well. Not sure if they’ll even load it on a ‘25.
  27. Jul 15, 2025 at 12:08 PM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Yeah they say that, and I had the fix done, still every once in awhile it’s off
  28. Jul 19, 2025 at 12:57 PM
    PNW Tundra Mike
    Back in So Cal
    Which fix and when did you have it done?
  29. Jul 20, 2025 at 7:37 PM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Whatever the TSB was back about 1.5 years ago
  30. Jul 21, 2025 at 10:03 AM
    trazerr
    trazerr New Member
    Oregon
    2024 Toyota Tundra Platinum LR
    There is a new fix out as of a month or two ago FYI
