Tundras were built for this!!
Discussion in 'Towing & Hauling' started by FedExTrucker, Jul 29, 2022.
  1. Aug 2, 2022 at 8:41 AM
    #301
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    I estimate my door sticker to weigh 0.0225 ounces. :rofl:
  2. Aug 2, 2022 at 8:43 AM
    #302
    There are two different AAM 14 bolts too…fyi. 10.5 and 11.5. One with the gas motor and the other with the diesel.
    The differential is important, but it’s what’s on the axle ends that matter.
    Post #12 pertains to this conversation.
    https://www.tundras.com/threads/tow-ratings-guide-how-to-be-safe.39211/
    Cpl_Punishment likes this.
  3. Aug 2, 2022 at 8:51 AM
    #303
    mundra
    mundra New Member
    Ormond Beach, Florida
    2019 platinum 4x4
    315/70/17 Ridge Grapplers on Rock Warrior Wheels, Tinted windows,remote start,tech12volts audio upgrade w/2-10" subs, console charger, more to come soon.
    Your correct. And the axle end is closer to a 3/4-1 ton truck. Do you have the rear end clunk when you put yours in gear? If not you most likely will. This is a design by Toyota to aid in heat to allow our gears to expand. I have it in mine and I have towed from Ohio to deep in Florida a few times and other places. At this time I still will not trade my Tundra for another truck. I love diesels but the feds are killing those as well.
    Tripleconpanna likes this.
  4. Aug 2, 2022 at 9:01 AM
    #304
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    Correct if it’s solely based on hitch. The leaf springs and rear axle says it shouldn’t be towing the majority of 5th wheels
  5. Aug 2, 2022 at 9:07 AM
    #305
    Yes I did when I owned a Tundra. Been a while though.
    There is a big difference in semi-floating and full floating axles.
  6. Aug 2, 2022 at 9:18 AM
    #306
    Bammer
    Monroe, CT
    Thanks, now I have to cancel my fifth wheel order !
  7. Aug 2, 2022 at 9:22 AM
    #307
    Malinois38
    Malinois38 New Member
    Pa.
    2022 Platinum Hybrid WCP
    What a teaser! Details of the camper weight, pass grade %, length etc. I think we can all learn from this type of information.
    I will admit doing something really stupid (early on in my towing days). I pulled my 7K+ camper over the Teton Pass. The only thing dumber than going up was going down the other side! It is 6 miles of 10% grade and peaks at 10,000’ elevation. I could only do 30mph at the top and brakes were very hot at the bottom. I now carry East/West Mountain Directory and study it before traveling. Truck is still chugging along, 207K and running strong.
  8. Aug 2, 2022 at 9:44 AM
    #308
    We were coming down Highway 24 east bound. Speed limit just moved up to 55 mph from 45. There is a traffic light at a Walmart turnoff that turned as I was approaching. I tried to stop but the truck just pushed into the intersection. I did stop, just was in the middle of the intersection.
    Camper was 7500 lbs loaded, not sure if the grade. Most of that pass is 6-7% but at that location it might be 2-3%.
    Camper is a Keystone 280RS.
    mundra and Malinois38[QUOTED] like this.
  9. Aug 2, 2022 at 9:45 AM
    #309
    stevesgraytundra
    stevesgraytundra New Member
    Stephen
    2021 MGM SR5 CM 4x4
    Cool story…but does your truck have a sticker that approves of this message? ;)
    Bammer likes this.
  10. Aug 2, 2022 at 9:52 AM
    #310
    Malinois38
    Pa.
    Brakes! The weakest part of the Tundra, not payload IMO. Tundra brakes are not often discussed, but when towing they can be a huge problem if not maintained.
    Back to your regularly scheduled program!
    Backslider likes this.
  11. Aug 2, 2022 at 9:59 AM
    #311
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Tundra brakes are the best of the half tons, and the 5.7 is likely the best at engine braking too (haven't tried the GM 6.2 for this). The leaf springs are certainly the weakest point, then it's followed by whatever the reason the axles are only rated at 4100 lbs GAWR.
    Also here we're noting a 2-300 lb difference in brochure payload and door sticker payload. Imagine a F150 forum where that difference can be 2000 lbs!
  12. Aug 2, 2022 at 10:04 AM
    #312
    Retired...finally
    I'll bet you FedExTrucker's Unicorn high payload Tundra that the DOT didn't adjust the yellow timing for that light properly. Either they didn't add time when the speed was increased to 55 or the grade wasn't considered. The formula to set yellow light timing considers worst case traction conditions, reaction time and the worst stopping vehicle that's permitted on that road as well as grade. Somebody screwed up and it wasn't you.
  13. Aug 2, 2022 at 10:39 AM
    #313
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I kinda like the idea of letting everyone buy helicopters... It'll get a ton of jackasses off the road (at least until they pancake their newly acquired helicopter on one), and it will definitely fix stupid much faster!
  14. Aug 2, 2022 at 10:46 AM
    #314
    RCwyoming
    RCwyoming New Member
    RC
    2019 Tundra 4X4 CM MGM
    Good luck in your adventures. Looks like a great way to see if a truck is bullet proof.
  15. Aug 2, 2022 at 10:54 AM
    #315
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    I like to envision someone buying a new Tundra and Googling for towing and payload information and clicking on this link, lol.
    LukeS, Oey12, Bammer and 7 others like this.
  16. Aug 2, 2022 at 11:03 AM
    #316
    stevesgraytundra
    Stephen
    2021 MGM SR5 CM 4x4
    “I joined THIS tribe???”
  17. Aug 2, 2022 at 11:18 AM
    #317
    I take full responsibility for what happened. I couldn’t stop and that means I was going too fast for conditions or didn’t have enough truck.
    The light timing is a good point though. It does swap rather quickly.
    GODZILLA and Cpl_Punishment like this.
  18. Aug 2, 2022 at 11:27 AM
    #318
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    This is why I don't mind letting my speed drop as I go uphill, as you never know what might be over the crest. I know a lot of guys on the internet will say your truck is shit if it can't maintain 80 mph uphill in overdrive with your fully loaded trailer in tow...
  19. Aug 2, 2022 at 11:36 AM
    #319
    Yep. Saves a lot of fuel too. Down the grades I just set the cruise control, T/H, exhaust brake and control speed from my steering wheel. If people don’t like my controlled speed, that’s what the left lane is for.
  20. Aug 2, 2022 at 11:37 AM
    #320
    Retired...finally
    Riding a motorcycle teaches you this. I call it turning gasoline into brake dust.
  21. Aug 2, 2022 at 11:45 AM
    #321
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    A former coworker of mine loved the Allison and exhaust brake in his Duramax when towing his ~14k lb fifth wheel.
  22. Aug 2, 2022 at 11:46 AM
    #322
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    My dad taught me this. I've never ridden a bike and he hasn't had one since the 70s.
  23. Aug 2, 2022 at 12:13 PM
    #323
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    another few years and your country is going to be part of the new suburbia of Denver Springs Metro.... :cool: :bananadance: :cheers:
    hope things are well for you and yours.
    GODZILLA and ColoradoTJ[QUOTED] like this.
  24. Aug 2, 2022 at 1:24 PM
    #324
    glowblue
    glowblue From time to time
    VA
    This is one thing that people forget, what goes up must come down! Just today I was towing my trailer through West Virginia and my F-250 tows it like a dream. I was coming down an 8% grade over 6 miles and was really working the engine braking, truck brakes and trailer brakes to keep the speed under control. Just because your Tundra can drag a 15,000 lb trailer up the face of El Capitan doesn’t mean it can drag it down in a controlled fashion.
  25. Aug 2, 2022 at 1:33 PM
    #325
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    The true test for my truck will be the first time we tow our trailer over the Rockies and across the continental divide to the Kootenay mountains.
    ColoradoTJ and Nightshade Tundra like this.
  26. Aug 2, 2022 at 1:39 PM
    #326
    FedExTrucker
    FedExTrucker [OP] New Member
    Thurman
    19 Limited Crewmax
    Nokian Outpost AT
    I'm not assuming it's bulletproof... I'm in Memphis where people on I240 find out if their vehicle is bulletproof or not. I don't want to find out...
  27. Aug 2, 2022 at 1:47 PM
    #327
    AZBoatHauler
    So.Arizona
    I’ll see 3-4k RPMs holding 3rd gear going down steep grades with the boat hooked up - no pedal driving is how I roll loaded downhill.
  28. Aug 2, 2022 at 1:48 PM
    #328
    Nightshade Tundra
    Nightshade Tundra New Member
    Alex
    2021 Ram 2500 Laramie
    I'm a little late to the ongoing party but yes the insurance will cover your "stupidity". There are so many different senerios but I'll use one that seems to come up a lot. If the will call him "Happy Camper" say is involved in an accident where maybe he was not clearly at fault the other party's attorney or insurance carrier may request copies of what the "Happy Camper" was towing. If the "Happy Camper" was say towing over the limits of the vehicle he was towing the attorney or insurance could argue that if he was within his towing limits the accident may have not happened at all therefore he would want to pin the entire accident on the "Happy Camper"
    Honestly its not worth towing over the trucks limits no matter what the situation is. We all learn from that "This is the first time this is happened to me" moments so why not try and no go through it and tow with the appropriate rig. Your insurance company will be happy to not have to shell out so much money from your policy to cover say injuries to another party becuase of your carelessness because if you knowingly tow over the trucks limits its your carelessness and it will cost more
    "You" does not imply to the OP just using it becuase its easier :)
  29. Aug 2, 2022 at 1:50 PM
    #329
    Retired...finally
    Since you're talking about Memphis I assume you've using the word bulletproof in a literal fashion?
  30. Aug 2, 2022 at 1:50 PM
    #330
    Nightshade Tundra
    Alex
    I have a hard time believing this truck has a 1530 lb payload. My old 2021 Limited was only 1130 and this one is a limited from what I can tell. I know the older ones had less electronics in them but not 400 lb worth
