Kings 700lb Springs
Discussion in 'Suspension' started by Ron_Pro, Aug 1, 2022.
  1. Aug 1, 2022 at 5:26 PM
    Ron_Pro
    Ron_Pro [OP] New Member
    California
    2020 Tundra TRD Pro CrewMax
    I just installed Kings 2.5’s all around with the standard 600lb springs up front. I dropped an inch in lift up front with the new setup. I just ordered the 700lb springs to assist with the drop in height. Does anyone know much more lift will the 700lb give or in other words how much less of a sag will I experience after swapping springs? Thanks in advance.
    Current Setup:
    Kings 2.5’s w/ 600lb springs
    TC uppers
    Deaver U748 leaf’s w/ 3/4” shackles
    Y0TA PR0, Roctane84 and COTundra23 like this.
  2. Aug 1, 2022 at 6:07 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Did you adjust the king's with the 600s? You lost that much lift with them adjusted to max height?
    I don't know the answer to your question, but you should get a 16% increase in height with no preload :rofl:
  3. Aug 1, 2022 at 6:16 PM
    Ron_Pro
    California
    Driver set at 12 threads and passenger set at 10 threads. I have a C4 front bumper too which plays a factor.
    Ely010606 and snivilous[QUOTED] like this.
  4. Aug 2, 2022 at 7:16 AM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    El Cajon, CA
    It's going to be impossible for someone to answer your question accurately. Every truck is different and will need to be adjusted accordingly. I'm going to assume you got the extended travel coilovers and want the max height. Based on up/down travel our max recommended shock length at ride height would be around 23.66". See this diagram for measurements:
  5. Aug 2, 2022 at 4:01 PM
    Ron_Pro
    California
    Thank you. I completely agree that it’s impossible for a solid answer. I was hoping someone would be able to chime in with their experience so I can use theirs as reference.
    You are correct. I do have the extended travel shocks and I’m looking to achieve max height from the coilovers. I installed Deaver U748’s with MCM shackles (3/4”) and achieved nearly 3 inches of rear lift. That’s even with approximately 350lbs of static weight back there. I’m looking at what I can do to bring up that front end up a bit. I also have a pretty good driver side lean too. I know I can fix that with dropping the pre-load on my passenger side.
    Total shock length sits at 23” currently.
    These are my measurements from center of hub to fender.
    RF - 23.5
    LF - 24.25
    RR - 27.25
    LR - 26.25
    Thanks for the feedback @AccuTune Offroad
  6. Aug 2, 2022 at 8:27 PM
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    C4 Overland bumper, BD SAE fogs, Leitner Designs Rack, Rago Bed Channel Stiffiners, Warn Xeon 12S Plarinum, Bedslide, Front Runner Roof Rack, roof rack solar panels, RCI Full under carriage aluminum studs, RCI rear diff skid, Rago dash plate, Rago accessory panels, OEM LED headlights with wiring harness.
    I installed icons with 700lb Eibach springs and the heaviest icon leaf pack option in the rear. The 600lb couldn't handle the weight.
    C4 Overland
    ICON UCA'S
    Warn xeon 12s
    I have 35" tires.
    This is where im at.
    Skew12, SAGE63 and Ron_Pro[OP] like this.
  7. Aug 2, 2022 at 8:38 PM
    Ron_Pro
    California
    Appreciate the info! Truck looks good btw.
    JCBerb[QUOTED] likes this.
  8. Aug 2, 2022 at 8:44 PM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Not the same situation but similar. I'm running 700lb OME springs up front. After addition of my Coastal Offroad bumper (very similar to C4) I did not notice any appreciable difference in ride height up front.
    Ron_Pro[OP] likes this.
  9. Aug 2, 2022 at 8:47 PM
    Ron_Pro
    California
    Appreciate the feedback.
  10. Aug 2, 2022 at 9:33 PM
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    There are 800lb springs available. I would consider those if the 700lb don't work out.
    Ron_Pro[QUOTED][OP] likes this.
  11. Aug 3, 2022 at 6:06 AM
    Ron_Pro
    California
    Appreciate it. I hope the 700lb springs gets me where I need to be.
  12. Aug 3, 2022 at 3:52 PM
    AccuTune Offroad
    El Cajon, CA
    Happy to help. See this all the time though... too much lift in the rear and not able to get the front up to where you want it without maxing out the shock at ride height. We do not reference hub to fender etc... doesn't mean much to us. We are after the specific lengths of the shocks strictly for performance reasons. If you are at 23", looks like you can still go up at least .66" at the shock, which should gain you around 1.25" - 1.5" or so of lift. Also very common to offset the front coilovers to compensate for the lean.
  13. Aug 3, 2022 at 3:59 PM
    back_cast
    back_cast New Member
    Denver, CO
    Same thing happened to me...pulled 6112s off that were set at 2.5" and lost lift with the King 2.5 RR EXTs at max recommended length lol...frustrating but whatever I guess.
  14. Aug 3, 2022 at 4:04 PM
    Ron_Pro
    California
    Really appreciate the info. I wish I lived closer to you guys so you can guys dial in my suspension. I was just in San Diego last month too. Haha. Thanks again.
  15. Aug 3, 2022 at 4:06 PM
    Ron_Pro
    California
    I pulled Fox Pro suspension with the Westcott lift which gave me 3 inches. I lost nearly 1.5 inches up front after the Kings. Partially due to the Kings and Deavers out back pushing my front end lower. I’m hoping the 700lb spring and some other mods will get front end up a bit. I still want a rake, but not this much. Lol
  16. Aug 3, 2022 at 4:16 PM
    Ron_Pro
    California
    Does adding the 700lb spring extend the shock length or will I still be at 23” after install? Thanks
  17. Aug 3, 2022 at 4:20 PM
    pandapro
    pandapro New Member
    I have a C4 overland, winch, lights, as well as a dual compressor under the hood so it might be similar to your set up. With 700# springs with 14 and 12 threads showing on the driver and passenger, respectively, I’m sitting at 24” hub to fender. When I first had them installed, I was sitting at 25” so it seems they’ve settled a bit. I’ll adjust them to bring it back up to 3”, but I hope this helps.
  18. Aug 3, 2022 at 4:24 PM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    700lb should ride higher if all else remains equal (collar position, weight), how much higher is hard to say
  19. Aug 3, 2022 at 4:54 PM
    pandapro
    pandapro New Member
    Correction, I’m still sitting at 25” hub to fender
  20. Aug 3, 2022 at 5:32 PM
    Ron_Pro
    California
    Thank you for the information. I have the same setup with the exception of a winch and mounted compressor. If I bump up my driver side pre-load to 14 threads and keep my passenger at 10, and add the 700lb springs, will I get back up to 25” or perhaps even more since I don’t have winch and compressor?
    Current hub to fender
    LF - 23.5 (12 threads) + .5” at 14 threads = 24”
    RF - 24.25 (10 threads)
  21. Aug 3, 2022 at 5:35 PM
    Ron_Pro
    California
    If everything remains the same, would it be safe to say it won’t be no more than an inch?
  22. Aug 3, 2022 at 5:57 PM
    pandapro
    pandapro New Member
    Yeah, if I have more weight in the front than you, you’ll definitely be higher or need less preload to achieve the 3” lift. But like accutune said above, each truck is different. I’ll bet you’ll be fine though.
  23. Aug 3, 2022 at 6:01 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Really hard to say.
  24. Aug 3, 2022 at 6:07 PM
    Ron_Pro
    California
    Thank you. Are you running a shim?
  25. Aug 3, 2022 at 6:15 PM
    C.I.
    Cesar Pedrin
    Cabo, Mx
    This really is above my paygrade, but math don't lie... however I'm not great at math and all my **** are guesstimates.
    If for example your truck has about 60% (using king's specs for the ext-travel shocks) left of suspension travel left when sitting on the ground (level ground that is) then that means springs are compressed ~3.4" on your current preload, it would take another 300 lbs per spring to compress a 700 to that same number, literally a third 600 spring compressing a single inch, so maybe, just maybe, swapping springs may sit 1" higher... could be 1/2", however, we're not even considering the angle the shocks are mounted in, this is literally a 1:1 suspension to shock travel example. Reason why I can't give you a number, it's by far more practical to measure ride height rather then come up with a math formula.
    Spring rates are funny that way.
  26. Aug 3, 2022 at 6:43 PM
    pandapro
    pandapro New Member
    Nope, just the coilovers.
  27. Aug 3, 2022 at 8:56 PM
    Ron_Pro
    California
    Thank you. This all above my pay grade. Haha. That’s why I hit up the forums to get valuable information from members with true experience. I appreciate the time and information you have provided.
  28. Aug 4, 2022 at 7:05 AM
    AccuTune Offroad
    El Cajon, CA
    The spring does not change the shock at all. Check out this animation below demonstrating what would happen to the SHOCK if there was too much preload on the coilover.
  29. Aug 4, 2022 at 7:12 AM
    Ron_Pro
    California
    Thank you so much. Since the spring won’t extend the shock length and I’m sitting at 23”, I still have more room to adjust the pre-load before it maxes out at 23.6”. Correct?
  30. Aug 4, 2022 at 7:20 AM
    back_cast
    Denver, CO
    Anyone have a link for the 700 lb springs you'd use on the coilover set highlighted below?
