  1. Jul 29, 2022 at 3:03 PM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Katzkin Leather seats, JRI shocks, Rival aluminum skids, 285/70/17 outpost nat, Berger catch can, icon rear +.5 springs, gator trifold bed cover, Perry parts bump stops, switchback turn signals,
    I got the 10inch about 2 years ago.. Best mod :curls: in my opinion! Make sure you install the resonator! :cheers:
  2. Jul 29, 2022 at 3:21 PM
    ftmyerstundra
    ftmyerstundra New Member
    Gary
    2007 Tundra Crew Limited
    absolutely none
    Is the hole precut foe the resonator?
  3. Jul 29, 2022 at 3:35 PM
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    She got a new radiator, thermostat, coolant, driver side CV axle, and new rotors and pads on all 4 corners.
  4. Jul 29, 2022 at 3:38 PM
    Oxman44
    Oxman44 New Member
    08 TRD Reg cab
    2.5" OME lift
    My '08 RCSB is in the shop right now getting a full OME 2.5", and sick new 295/70 shoes/wheels. Very pumped! probably wont be done till next week though... so a long weekend
  5. Jul 29, 2022 at 3:43 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Nope. You may be able to order it precut though, but then you wouldn't have the flexibility of adjusting placement if it's a little off and bumps into something, like the bottom of the bed.
  6. Jul 30, 2022 at 1:53 AM
    CMikeB
    CMikeB New Member
    Gee, you were so "excited" too. Moving
    When you buy a system from Keith, you keep your stock tailpipe. In my case,when I bought my first exhaust (10") I gave my tailpipe away so he sent me one with the system. He pre-cut it for me, it's been fine where he put the hole. Because my tailpipe stays, I won't need to mess with the resonator or where it is. They haven't changed over the years. When my 20"exhaust came,there was a new resonator included that they sent by mistake, it'll get returned with my old exhaust.
  7. Jul 30, 2022 at 4:07 AM
    CMikeB
    CMikeB New Member
    Not interested in a "date" hon:sorry:, just passing along some information.
  8. Jul 30, 2022 at 4:43 AM
    THOR's
    THOR's New Member
    Thor
    North Carolina
    2021 Tundra TRD Sport and XP Predator Package
    Finally got around to install a VIOFO dash cam (father’s day gift)into my truck. Wasn’t sure I’d like it, but it was amusing watching the video of my Tundra being serviced yesterday!
  9. Jul 30, 2022 at 5:10 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    NO no no. The date would be with Kieth. Cuz of the testemonial.... Is this getting weird?
    Never mind. Just interested in what the damn system sounds like, if you are so inclined.
    CMikeB[QUOTED] likes this.
  10. Jul 30, 2022 at 5:30 AM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    Yesterday I installed the missing bottle opener to my new to me Decked system. Also installed tie downs into the rails they had already installed in the Decked system. And finally installed drain plugs in the drawers in case I wanted to fill it up with ice. I put the drain plug at the rear of the drawer and unscrews from the bottom as I had plenty of space between the drawer and tailgate.
    This morning I’m repainting my amp steps with a spray Bedliner paint.
  11. Jul 30, 2022 at 6:14 AM
    CMikeB
    CMikeB New Member
    Sorry Trey, not weird, just me misunderstanding.... once AGAIN!:rolleyes: I'll be sure to 'attempt' a sound video when the system is on.:D
  12. Jul 30, 2022 at 7:14 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
  13. Jul 30, 2022 at 8:19 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Mine got insurance, full tank of premium and the first pressure wash it’s had in a year. Even vacuumed all the hay bits out the cab. She’s a road goat again! :D
  14. Jul 30, 2022 at 8:28 AM
    I see you have the AC on while working in there. It's hot over here on the Tampa side already.
  15. Jul 30, 2022 at 1:21 PM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    yeah I’m in tampa too (Lutz) and I used AC while not poking at wires, but turned it off to solder and test wires.
    After 2 failed attempts I found a locksmith that knows his craft.
    Had him swap the 80s key fob for one of those fancy European luxury switch blade keys. Ooh La La
    Edit: yes the new key folds in half
  16. Jul 30, 2022 at 8:54 PM
    mike diamond
    mike diamond New Member
    Michael
    2007 toyotaTundraLimited
    20 inch wheels
    Bought air filter and cabin filter- installed denso air filter ( got rid of k and n) - will i stall cabin filter at daybreak
    joseph_womack, omgboost and WVI like this.
  17. Jul 31, 2022 at 12:24 PM
    Kur
    Kur New Member
    Mesa, AZ
    08, 5.7, Double Cab Tundra, White
    In preparation for some new wheels and 10mm spacers, I replaced my wheel studs with extended studs. These are 14x1.5 studs. They are almost an inch longer than stock. I measured all the important specs like the diameter of the knurled section and whatnot. It all checks out.
    If you are interested, you can find them on ebay in packs of 12 or 24. They were literally the only extended wheel studs i could find that were the right size.
    I thought i might have to cut the cap off my stock lug nuts until i got the new wheels and aftermarket lug nuts, but as you can see, the factory nuts thread all the way down to the rotor without issue. So no cutting for me.
    D4x4TRD, WVI, aelarson and 5 others like this.
  18. Jul 31, 2022 at 5:43 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Installed some LED puddle lights. What a difference! Fit like a glove, only had to crimp down the spade connectors a little
    WVI, joseph_womack, omgboost and 3 others like this.
  19. Jul 31, 2022 at 7:03 PM
    red_5ive
    red_5ive Jedi Knight and friend of Cpt. Solo
    Southern California
    2008 4.7L CrewMax
    • 3.5" Maxtrac Spindle Lift • 2.5" Spacer • Monster XD778 18 x 9 wheels, +18 Offset • Nitto Ridge Grappler 325/65 R18 (34.6 x 12.8 - temporarily back on the 32s until I can decide on gears) • Nitro 5:29 Gears (awaiting installation - on hold for now) • Black/smoke headlights • Clazzio custom leather seats • Boss Wireless Android Auto head-unit • Backup camera
    Carrier bearing spacers
    wv00097, Prostar 190, WVI and 4 others like this.
  20. Aug 1, 2022 at 2:42 PM
    aelarson
    aelarson New Member
    AZ
    2011 SR5 Tundra (Silver Sky Metallic)
    Finally finished my bed shelf concept! This will allow all of the space above the mid line under the topper to be usable for gear (bows, guns, duffle bags, bins, etc.). It still allows plenty of space for coolers, bags, bins, etc. underneath. I have 2 stacked Milwaukee pack out bins for recovery gear and they fit perfectly.
    The frame is made out of 80/20 extrusion (2x2 and 1x2) and is bolted right through the topper and the lip of the bed. It is solid. The shelf itself is a piece of plywood u-clamped to the aluminum frame. This is where the project went south in my eyes. It looks really janky and unfinished. Being version 1 (prototype/concept), I am going to run it as is for hunting season to see how I like it/how it holds up. If all is good, I will rework it and make it pretty over the winter months. I am thinking either carpet or bed liner for the shelf and using some 80/20 brackets to bolt the wood to the frame. No u-clamps, I don't like that.
    I also threw in a RAM iPad mount so I can run OnX on my big screen. I have 2 mounting balls to make a sturdy base, the rest can be configured how you see fit. Should be nice!
    Lastly, I finished my hitch rack. The swing-out arrived and everything meshed together nicely. More storage! The frame up above the rack is 80/20 as well. I'm done with 80/20 projects, it's expensive!
  21. Aug 1, 2022 at 2:54 PM
    BoysandHisToys
    Central Virginia
    I think that was the second mod I did to mine after I got it.
  22. Aug 1, 2022 at 2:58 PM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    What is that?
    PhotoNerd likes this.
  23. Aug 1, 2022 at 3:12 PM
    realest5.7
    realest5.7 New Member
    Cascadia
    2012 RCSB SR5 4x4 5.7 TRD Off Road
    Spent my first night in the Tundra. My old Tacoma sized tent nearly fit, the upgraded version should be here this week…
  24. Aug 1, 2022 at 7:23 PM
    Kur
    Kur New Member
    Mesa, AZ
    Got the new wheels and tires mounted. Somehow the tundra can make even 37s look small...
    Ohannon7, Prostar 190, WVI and 6 others like this.
  25. Aug 2, 2022 at 7:44 AM
    frankforttrdpro
    frankforttrdpro New Member
    Bala
    Frankfort
    2007 5.7L RCSB 2x4
    Spend a few hours detailing my Truck. Paint still holding up for a 15 yr old truck.
  26. Aug 2, 2022 at 8:20 AM
    shannon
    shannon New Member
    shannon
    Asheville, NC
    2010 DC
    How's the articulation there? Looks like a trail would tear that up?
  27. Aug 2, 2022 at 10:37 AM
    red_5ive
    Southern California
    2008 4.7L CrewMax
    Nice! Still looks perfect! :thumbsup:
    Wish I could say that about my '08, the factory white is starting to oxidize. It was garaged most of its life, too!
  28. Aug 2, 2022 at 11:14 AM
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    I have an white 07 that has spent it's entire life outdoors (granted it has been in the pacific NW), and it was looking fairly ratty. I hire a mobile detailer to come an do a light paint correction on it a couple of months ago and it looks like brand new. Since white doesn't have a clear coat, I am going to give ceramic coat a try next.
    red_5ive[QUOTED] likes this.
  29. Aug 2, 2022 at 11:21 AM
    COElkHunter
    COElkHunter New Member
    Jeremy
    2012 Silver Tundra TRD limited Crewmax 4x4
    3" OME lift w/ UCAs. ARE overland shell w/ ARE roof rack. 34" Falken Wildpeaks. ARB awning. Road shower. Wilco Offroad Hitchgate Solo High Clearance. LED lighting upgrades. Lockerdown console safe. Weathertech floormats. Duluth deluxe rear seat cover to go under the offroad approved car seats.... :P
    Finally got around to installing my Victory cab-over rack. Came out awesome... The harbor freight hoist made doing it solo easy. Changed out how my awning was mounted to the ARB factory mounts and quick release bolt on's. Needed a bit more clearance for the cab rack to fit. Pulled the headliner just enough to see what I was doing, protect the air bags while drilling, and sneak a vacuum in there to get the shavings. Drill stops made the holes simple, used a uni-bit to ream the holes to a tight fit. Only SNAFU was the Astro rivnut setter I bought, broke on the 2nd nut... WTF! So I ended up setting them by hand...
  30. Aug 2, 2022 at 11:48 AM
    red_5ive
    Southern California
    2008 4.7L CrewMax
    I did try applying one of the Maguire's paint restore products which seemed to help a little, but I'm also very impatient with rubbing compounds of any kind and hate doing that kind of work, even with a polisher.
    We have a couple of mobile community detailers in the area, I'll give them a try. Thanks!
