4.88’s or 5.29’s
Discussion in 'Performance and Tuning' started by atacorion, Jul 23, 2022.
  1. Jul 23, 2022 at 8:26 AM
    atacorion
    atacorion [OP] New Member
    2012 TRD crewmax
    2012 with 35’s, buddy has 4.88’s and I dig the power and lack of noise. But I have heard 5.29’s might also be the way to go.
    whichever way has got to be better than the stock gear ratio right? But which one is better for long highway trips with occasional off-roading/towing?
  2. Jul 23, 2022 at 8:43 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    5.29s are better for everything. Lots of regearing threads showing people's feedback.
  3. Jul 23, 2022 at 8:52 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    How I looked at it was there's little to no price difference between the two and with 5.29s you give yourself the room to go up to 37s or 38s without having to re-gear [again].
    No brainer.
    Tripleconpanna, ColoradoTJ and Vr0ck like this.
  4. Jul 23, 2022 at 9:51 AM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    I havent been able to get a hold om 5.29 gears due to supply chain.
    Hope you have better luck.
  5. Jul 23, 2022 at 9:53 AM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    5.29 all day
    Tripleconpanna and texasrho83 like this.
  6. Jul 23, 2022 at 9:53 AM
    cctxquicksand
    Try Keith at dirty deeds, he was able to get me my Sierra gears with the quickness
    texasrho83 and Vr0ck[QUOTED] like this.
  7. Jul 23, 2022 at 9:55 AM
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    Just had my 5.29's installed about 2 weeks ago. I didn't even consider 4.88's -- just had my 500 break in fluid flushed and I have no noise with my nitro gears. I had a slight whine during break-in. I'm on 34.5 inch tires.
    619Tundra, RaginTxn, Skew12 and 4 others like this.
  8. Jul 23, 2022 at 10:20 AM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    How does one calculate final drive gear ratios? I'd like to compare stock configuration to 4.88, 5.29 with various tire sizes.
    5N0W808 likes this.
  9. Jul 23, 2022 at 10:23 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    7.60's & send it. Straight pipes. A little extra gas for lots of glory.
    Johnmatrix, Elduder, Uturn09 and 3 others like this.
  10. Jul 23, 2022 at 10:23 AM
    Plenty of tire/gear calculators out there on Google that let you play with different size/gear ratios.
  11. Jul 23, 2022 at 11:38 AM
    blenton
    blenton New Member
    Here's a chart. The RPM is calculated at 60 MPH with a 1:1 transmission gear, which is fourth gear in our trucks. But it's helpful for comparisons. 4:88's would be closer to the correct RPM with 35's; 5:29's are pretty deep but would give more acceleration by keeping the RPM's higher, at the expense of fuel economy (if that matters to you). I've thought about 4:88's and 33's, but I drive enough freeway (80MPH speed limit) that I doubt I'll go there.
  12. Jul 23, 2022 at 12:08 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    5.29
    Never look back
  13. Jul 24, 2022 at 12:59 AM
    TravisJr
    TravisJr New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
    I’m on 35s and 5.29s in a 2010. It’s the way.
  14. Jul 25, 2022 at 5:19 PM
    FlipMonkey21
    FlipMonkey21 New Member
    Mark
    SoCal Glendale
    2019 Toyota Tundra 4X4 Sport
    2019 Toyota Tundra Crewman TRD Sport Kings 2.5 Front & Rear suspension Camburg UCA Method Wheels MR312 18X9 +18 Offset 5x150 matte black w/toyo open country RT 35x12.5R18 tires Toyo Open Country RT 35X12.50 R18LT 123Q 10 P.R TRD Front Sway Bar (Removed) TRD Rear Sway Bar ( Removed) Carven Cat-Back Kit (torque 65lbs to 70lbs of torque) Windows tint Bakflip MX4 Bed Cover TRD CAI NSV air compressor AJT Design chrome delete NSV Light Bar Diode Dynamics 42" light bar Diode Dynamics SS3 Max Pod CBI Full Skid Plate CBI Lower Control Arm Shield Sibi Built regear Revolution 5.29 Harrop rear lockers Rigd mega swing Wheel lock Deaver springs U-748 King 3x16 650 Coil springs
    Going 5.29 revolution gear next week looking forward to it.
    porkitt and texasrho83 like this.
  15. Jul 25, 2022 at 5:31 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    For sure, If you are in the "middle" of gears, go lower. I was between 4.56/4.88 and thank god I went 4.88 on 33-34.
  16. Jul 25, 2022 at 7:19 PM
    Tundra John
    Tundra John New Member
    2020 Tundra Platinum 4x4
    4” Readylift, Fuel 20” tires w/ Kenda 35”x12.5 tires, tint, dechromed, Custom Platinum Badging, Running Boards, Auto tailgate lock, LED swap, Changed out stereo system, VLeds Interior floor lights, DirtyDeeds 8” exhaust, TRD air filter, wrapped interior silver components,
    I chose 4.88’s with my 35’s because I dont ever plan on going Up to 37’s and it gives me flexibility going down if I ever have to.
    I also have a Supercharger that might help too.
    619Tundra, 5N0W808 and 1eyedclyde like this.
  17. Jul 25, 2022 at 7:37 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    I went with 4:88’s on 35’s and could not be happier.
    619Tundra, 5N0W808, RaginTxn and 2 others like this.
  18. Jul 25, 2022 at 7:45 PM
    bflooks
    bflooks New Member
    Metrowest MA
    I have 5.29s on 33s and I don't regret the decision. Never once. Even if I didn't tow, it's where I want to be. 2200 at 65mph is something I can live with since it no longer downshifts or unlocks when cruising. I'm also consistently getting 15.5 mpg on the highway, and load has decreased between 20 and 25% on average.
    kaymonster and porkitt like this.
  19. Aug 1, 2022 at 1:35 PM
    mountainpanda
    mountainpanda New Member
    2016 Super White SR5 TRD 4x4
    How does altitude factor into this? I'm leaning towards 5.29 and I live at 6,000 feet. I'm on 35's and don't really plan to go bigger but you never know. I'm assuming 5.29s would make up for a little more loss of engine performance at altitude but I'm new to the regearing conversation.
  20. Aug 1, 2022 at 1:40 PM
    snivilous
    SW UT
    It doesn't come into play any more than usual. I also live at 6000ft, and besides the usual ~15% loss of power you have due to elevation everything else will remain the same. With 5.29s you'll spin ~25% more rpm but also have that much more torque at the wheel. So if you're in 6th gear at 2000rpm you'd then be at 2500rpm in the same stretch of road. If you're in 4th gear on a road, good chance you'll be able to maintain 5th gear now, etc. 35s, power loss due to elevation, add in towing or hauling anything, I highly recommend 5.29s. I live in Utah which has the highest speed limits in the nation and I've never "run out" of rpm for the engine on the interstate. You can still hit 100+mph all day with 5.29s, and the rest of the time you're either utilizing a higher gear than you normally would or the engine isn't working as hard because it has less load due to the increased torque at the axles.
    bflooks, texasrho83 and TravisJr like this.
  21. Aug 1, 2022 at 1:48 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Per Keith at DirtyDeeds, anything over 33.4" gets 5.29's, 33.4" and smaller, 4.88's.
  22. Aug 1, 2022 at 1:52 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah Keith has always advocated 5.29s with 33s. Something I don't really agree with but I've got 5.29s & 35s and some don't agree with that :notsure:
  23. Aug 1, 2022 at 2:36 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Give him the full story and he'll serve you well. I tow and have 33.4's. due to the weight, I went 5.29 after speaking with him and I couldn't be more grateful. There's definitely some trade space. A lighter tire probably.would have made daily driving annoying, but a heavier tire tames it very well. Keith gets all of this and won't steer you wrong.
  24. Aug 1, 2022 at 2:47 PM
    MadMaxCanon
    I really wish i had the money to get the 5.29s and power trax on, would be a whole different truck with 33's and the amount of added weight I have, i usually roll close to max payload.
  25. Aug 2, 2022 at 10:04 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    it saves you gas, so eventually it pays itself off and more.
    MadMaxCanon[QUOTED] likes this.
  26. Aug 2, 2022 at 10:05 AM
    MadMaxCanon
    Wondering if the wife would buy that lol
  27. Aug 2, 2022 at 10:26 AM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    Would some of you be willing to share what the shop charged you for the regear? Trying to build up the nerve to do gears and at least a rear locker but I really don't know what to expect for install costs.
  28. Aug 2, 2022 at 10:29 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    All that wife needs to know is that shoes and pretty dresses cost as much per year than a single performance mod... works for me
  29. Aug 2, 2022 at 10:34 AM
    MadMaxCanon
    I dont know if its good or bad in this context but my wife is definitely not a shoes and dresses person, shes extremely cheap, which works for me most of the time, except when I say itll cost 3k for gears on a brand new truck lolol
    DeesCrewMax and C.I.[QUOTED] like this.
  30. Aug 2, 2022 at 10:49 AM
    C.I.
    Cesar Pedrin
    Cabo, Mx
    You better cherish her, high maintenance gets old quite fast :cookiemonster:
    MTRock and MadMaxCanon[QUOTED] like this.
