SOS Performance drop kit
Discussion in '2nd Gen Tundras (2007-2013)' started by bull_yota, Jul 31, 2022.
  1. Jul 31, 2022 at 7:11 PM
    bull_yota
    bull_yota [OP] New Member
    2011 Red Tundra Base
    Ported throttle body by 454chuy
    installed the SOS drop kit in rear but it still sits stock height. tips ?
  2. Aug 1, 2022 at 5:32 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Did you flip the rear end up inside the leaf spring? All you posted is a picture of the shackle. (That I can see at least)
    The rear end kit flips the rear differential so it’s in between the frame and the leaf spring, with the leaf under it.
    From the factory the leaf spring is on top of the rear end, flipping it drops the truck like 6 inches and the shackle actually lifts is back up an inch or two depending on if you want 4-5 inches of drop in rear.
  3. Aug 1, 2022 at 5:39 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    I took these photos right after installing mine. You can see the rear end is now in the middle of the gap and the leaf spring is underneath it. The adjustment in the shackle sets the height. The lower you set the leaf in the shackle (more distance between the leaf end and frame) the higher the truck will sit.
    C6A0E2BE-E266-4C40-A6FD-F32BB8E5AA02.jpg F57B7109-255E-4865-9444-16F470342D8F.jpg
    bull_yota[OP] and des2mtn like this.
  4. Aug 1, 2022 at 6:31 AM
    bull_yota
    This cleared it all up ! the manual wasn’t clear on placing my leaf springs under my drive shaft and i think that’s all i’m going to need. thanks you
    Jeff_5_7 likes this.
  5. Aug 1, 2022 at 6:43 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    You should have some extra parts laying around then. The guys at SOS are great but I will agree the instructions were not the best. This was the second time I had done one so I already had an idea of how it worked. If you have any more questions about the install feel free to post them here.
