  1. Jul 29, 2022 at 12:57 PM
    #8701
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Looks good!!! Is that work you are doing or having done???
  2. Jul 29, 2022 at 12:59 PM
    #8702
    I wish I was that handy. I hired out for the basement. They finished framing in 1.5 days with jus two of them
  3. Jul 29, 2022 at 1:32 PM
    #8703
    EmergencyMaximum
    EmergencyMaximum New Member
    That foto #2 and #3 completely bogs my mind. That wall is in the air. Is the roof that sturdy that I can hold all that weight? I mean all those walls, being suspended in the air, that is some serious weight!
    How do you install baseboards if there will be almost 2" movement?
    NWPirate likes this.
  4. Jul 29, 2022 at 3:12 PM
    #8704
    NWPirate
    Zach
    WA
    Yeah, that blows my mind! Those don't exist around here.
  5. Jul 29, 2022 at 3:16 PM
    #8705
    EmergencyMaximum
    Agreed, I haven't seen anything like that on socar or fl either! My logical part of the brain is thinking, if the whole slab is reinforced and moves up or down as one single piece together, why not just have it as a foundation and let the walls be built on that slab? Let the whole thing as a whole move up and down.
    Is the slab separate construction from the foundation?
    :pprobably driving @T-Rex266 nuts with all these questions..
  6. Jul 29, 2022 at 3:21 PM
    #8706
    I think it has a lot to do with their soil, I think it’s bentonite, it expands and absorbs like no other
  7. Jul 29, 2022 at 3:30 PM
    #8707
    Vizsla
    Vizsla 2 = 2.5
    Would move too much. Think of things that meet or attach to the house, stairs, driveway, decks, etc… Be trip hazards everywhere depending on the season. Slab is separate so it can float, foundation is engineered, helical piers etc. are common. Expensive to build a house in Colorado.
  8. Jul 29, 2022 at 3:34 PM
    #8708
    Idk if any of these pix help
    baseboards, just goes on top. In the four years we have lived here (built new) I don’t see a difference in the baseboards
    if I go out front, I can see a little bit of shifting in certain areas (backyard slope as example) but it’s hard to notice and still “in compliance”
  9. Jul 29, 2022 at 3:46 PM
    #8709
    Vizsla
    Vizsla 2 = 2.5
    Baseboards attach to the green plate attached to the floor only. They cover the gap and allow the up and down of the slab to be hidden. Door frames are attached with slots allowing the frame to go up and down, door trim is only attached to the frame allowing it to slide up and down. Huge pain in the butt, almost impossible to do the doors correctly.
  10. Jul 29, 2022 at 3:54 PM
    #8710
    sensei
    sensei master and teacher of nothing
    trd boosted, trd bbk, fox stage 4, corsa, amp, jl/kenwood
    low maintenance landscaping for our residence where i keep the 2nd gen. finishing off the gate and fencing is next.
  11. Jul 29, 2022 at 4:16 PM
    #8711
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    What brand and type of floor is that? Looks great.
  12. Jul 29, 2022 at 11:42 PM
    #8712
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Did some adulting today. Been sick of looking at my fence with all the rot and such. Too the pressure washer to it today. Only got maybe a 1/3 done today. Will finish and then need to stain it.
  13. Jul 30, 2022 at 11:14 AM
    #8713
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Coil overs (3”) and 295 tires, ESP storage, grab bar; RCI skids; tinted windows; rear air bags
    My neighbor came over with his backhoe and dug a hole in my yard.
    TaquitoBandito, saybng, LukeS and 6 others like this.
  14. Jul 30, 2022 at 11:43 AM
    #8714
    Tripleconpanna
    ...should we ask what the hole is for???
    :spy:
    TaquitoBandito and NWPirate like this.
  15. Jul 30, 2022 at 3:36 PM
    #8715
    Outbound
    Aaron
    Northern Alberta
    More progress today.
  16. Jul 30, 2022 at 6:19 PM
    #8716
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    I’m going to build a mostly underground greenhouse. Being mostly buried, it will keep it cooler in the summer and warmer in the spring and fall. Should make for a longer growing season.
  17. Jul 30, 2022 at 7:23 PM
    #8717
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    Yeah, it's a real drag getting busted halfway through a growing season... :spy:
  18. Jul 30, 2022 at 7:38 PM
    #8718
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    For their other neighbor. :D
  19. Jul 30, 2022 at 9:57 PM
    #8719
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    The photos explain everything, thx. I never heard of floating walls till these posts.
  20. Jul 31, 2022 at 3:05 PM
    #8720
    Tundar the Barbarian
    Tundar the Barbarian New Member
    2020 MGM TRD OffRoad
    Speakers, amp, subs, floorboard lights...and the little step thing under the bumper
    The floating walls thing was amazing to see...never heard of such an animal...thanks!
  21. Jul 31, 2022 at 3:17 PM
    #8721
    TheBrit
    Mark
    It’s taken a few months, thanks to the joys of having a day job, three week vacation, those weekends with lack of enthusiasm or better things to do blah, blah, blah, but I can finally see the end of the first major honey-do job on the list since we moved into the place a year ago. It’s not as though I haven’t done a load of snotty little fixes, had the back corner of the house underpinned and insulated and boarded out the garage (not that that counts as a honey-do. ).
    No, I have finally gotten close to finishing the freestanding 25’ X 10’ deck that ‘we’ agreed upon when we moved in. Phew!
  22. Jul 31, 2022 at 3:26 PM
    #8722
    Over the week, finished paint and quarter round in the guest bedroom and cutting materials for the Murphy/wall bed for it. Today first try at veneer banding... did the birch, still needed to do the cherry. Still just a couple big piles of wood at this point...would've rather faced it with solids like custom cabinets or furniture, but never done one of these and it has some mechanicals, so I just straight followed the kit instructions.PXL_20220731_220250172.jpg PXL_20220731_220247345.jpg 16593061511263867108140525760447.jpg
  23. Jul 31, 2022 at 4:12 PM
    #8723
    EarlyRiser
    EarlyRiser New Member
    2020 Black Tundra SR5
    Replaced the ceiling fan in one of the bedrooms. Motor was toast but lights still worked so I just moved it into the spare room and swapped the fully functional fan in its place. Glad I don’t install fans for a living, my shoulders were burning.
    TaquitoBandito and MadMaxCanon like this.
  24. Jul 31, 2022 at 4:37 PM
    #8724
    TheBrit
    Mark
    Seems a few of my pics dropped off my earlier post. So here are a few of the serious grunting stage…
    back on April 9th…
    Next day, with added pint of Kentucky mule.
    Under shot before I finish the vertical soffit next weekend. Not yet sure whether I am inclined to create an access point where the photo is taken from to give me storage/access…
    Got just enough lumber and decking left to make a nice dedicated storage spot for our trash can
  25. Jul 31, 2022 at 4:54 PM
    #8725
    This is wild stuff. My first time seeing it too. What state are you in?
  26. Jul 31, 2022 at 4:55 PM
    #8726
    CO
  27. Aug 1, 2022 at 11:36 AM
    #8727
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    That's an interesting floor.
    Murphy beds are great! We have one in our "lounge" to use for overflow guests when the primary guest room is already being used. You're going to love having it.
  28. Aug 1, 2022 at 12:01 PM
    #8728
    Thanks! I had bamboo flooring for a project that didn't materialize, but it wasn't enough for the room needed more. Found a little darker correct depth/tongue and groove on clearance, so decided I'd make a pattern. Turned out nice, but won't do THAT again!
    That room looks GREAT! Looking forward to having a room that is useful for other things 50 weeks of the year, and a decent bedroom the other two.
    NewImprovedRon and Taco-Blender like this.
  29. Aug 1, 2022 at 12:29 PM
    #8729
    drobb
    drobb The Feral Snail
    2013 Tundra CrewMax 4x4
    326F844F-74E7-49C1-B9EA-8DBE41646473.jpg It’s HOT today. Good day to test the new solar. All the usual things running, plus all ceiling fans, both work PCs, 3 PC monitors and a portable AC unit. Not toooooo shabby…. lol
  30. Aug 1, 2022 at 1:58 PM
    #8730
    All electrical / ethernet ran in the basement. No pix, as there are lot of junction boxes, switches, etc
