Anyone know how I can get into the passenger side ac vents?
Discussion in '2nd Gen Tundras (2007-2013)' started by ftmyerstundra, Jul 29, 2022.
  1. Jul 29, 2022 at 6:29 AM
    ftmyerstundra
    ftmyerstundra [OP] New Member
    Gary
    2007 Tundra Crew Limited
    absolutely none
    The foam on the open close door is decaying and causing a whistle is making me want to punch a kitten. Thanks in advance.
  2. Jul 29, 2022 at 6:33 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    I assume you are talking about the blend door? The system has several sevros and flaps that move depening on which setting the air is on. Floor, Defrost, Dash Vent ect. It also has one that moves when you adjust from hot to cold air. The problem is all of these servos and doors are inside the HVAC box which is under the center dash behind the radio. To do much you almost have to pull the entire dash out.
  3. Jul 29, 2022 at 6:36 AM
    ftmyerstundra
    Gary
    absolutely none
    No, its the door that closes the vents manually. I am very selfish with the ac down here in Florida so when I am alone I like to close the passenger vents and enjoy 100% of the ac. When I close the passenger vents they whistle thru the foam on the vent doors.
    Jeff_5_7 likes this.
  4. Jul 29, 2022 at 6:41 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Your talking about the actual vents on the dash. A,B in the photo below. Passenger side is a little harder to get too. You are most likely going to have to fully remove the glove box and be careful because the passenger side aigbag is right above it. The vents are a part of the entire dash assembly. If I remember later today when at my garage I have a full dash pulled out and can take some pictures from the inside to show how they are attached ect.
    NewImprovedRon and Leo's first like this.
  5. Jul 29, 2022 at 6:45 AM
    ftmyerstundra
    Gary
    absolutely none
    Correct, a and b. I appreciate your help on this.
  6. Jul 29, 2022 at 8:08 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    My "C" vent has been broken since I bought my truck. Won't hold any position other than straight down. Also makes a man wanna punch a kitten :D
  7. Jul 29, 2022 at 8:30 AM
    ftmyerstundra
    Gary
    absolutely none
    There is a fix foe that. I pulled the tab off and mute electrical tape between the fingers that grasp the vent. It tightened it right up
  8. Jul 29, 2022 at 8:34 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Nice! Thanks for the tip
  9. Jul 29, 2022 at 10:38 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Here are some photos. You can see both vents attach to the back side of the dash with screws. Probably not the easiest place to get to and work but at least you have an idea what it looks like.
    F1B51411-D300-4F6B-9E84-EECE1482DAEC.jpg 8DFF9811-6F58-42E5-A2A3-6A3308DDB58D.jpg 7FD89841-6955-49E6-96D8-05C7BACD9716.jpg FDCC7ABF-8CB9-4458-92AE-E22C45991739.jpg F75DBA70-4B0F-45B2-91AF-7CEE53242EF9.jpg
  10. Jul 29, 2022 at 11:14 AM
    ftmyerstundra
    Gary
    absolutely none
    Wow that would be a lot of work. Thanks for taking the time to get me that. Much appreciated.
  11. Jul 29, 2022 at 12:29 PM
    chrisf111
    chrisf111 New Member
    Please update if you do this. Also live in Florida, and also hate the whistle from the degraded foam. Seems like some new foam would do the trick, just a matter of getting back there.
