Brakes Squealing - Less than 1k miles
Discussion in '3rd Gen Tundras (2022+)' started by Yameson7, Jun 20, 2022.
  1. Jun 20, 2022 at 9:45 AM
    Yameson7
    Yameson7 [OP] New Member
    2022 Tundra CrewMax SR5 4x4
    Hey Everyone,
    I recently bought my first Tundra (I’ve had two Tacomas so no stranger to Toyota trucks.) it’s a 2022 SR5 CrewMax and I’m having a pretty significant amount of brake squeaking and squeal.
    I checked my rotor surfaces and they seem fine but I haven’t heard of this issue being common like the wastegate issue so I thought I’d ask if someone else was experiencing the same thing.
    Thanks in advance for any insight!
  2. Jun 20, 2022 at 10:10 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    obviously just a guess but a rock trapped in the caliper can make noise.
  3. Jun 20, 2022 at 10:29 AM
    DEPFFEMT
    DEPFFEMT New Member
    2022 Tundra Platinum
    I'm also having same problem. Not loud slight when coming close to full stop. Started about week ago only have 800 miles on the truck.
  4. Jun 20, 2022 at 6:57 PM
    Yameson7
    @DEPFFEMT Yeah mine is the same way. @PlatinumPro I didn’t see any rocks in the caliper but I didn’t remove the wheels to inspect it. It seemed to have stopped on my way home from work this evening but I’ll see if it stays that way. I’ll post here if I find a remedy. Thanks for the insight guys!
    PlatinumPro likes this.
  5. Jun 20, 2022 at 7:27 PM
    mass-hole
    mass-hole New Member
    Do a couple of hard stops, 50 to 5 mph, back to back and see if it cleans things up.
  6. Jul 28, 2022 at 6:39 PM
    mikeaesq
    mikeaesq New Member
    2025 1794 TRD Off Road
    Same issue around 1100 miles. Will try the hard stops thing and see what I get.
  7. Jul 28, 2022 at 6:57 PM
    Tundrafarm
    Tundrafarm New Member
    22 hybrid limited 4x4
    Same here I-force max with 900 miles brakes squealing coming to a stop started at right around 600 miles have done a few stops as some here recommended and it stops doing it for a little bit, most of the times happens after having the truck sitting for a few hours.
  8. Jul 28, 2022 at 7:14 PM
    Yameson7
    I took my truck to the dealer for the rear axle recall and they opened a tech case for rust on the rotors. Currently awaiting a call back but I’ll keep you all posted. Hard stops weren’t successful for me. The issue dissipates depending on how long I drive.
    mikeaesq[QUOTED] likes this.
  9. Jul 29, 2022 at 7:46 AM
    LaTundraSR5
    LaTundraSR5 New Member
    Carlos
    2022 Toyota Tundra SR5
    I had this happen to me, and when I took it in they opened a ticket with their "Toyota" people, I guess. They ended up replacing rotors and pads and that fixed it.
    Yameson7[OP] likes this.
  10. Jul 29, 2022 at 6:37 PM
    Yameson7
    Did you have to cover the cost of the replacement?
  11. Jul 30, 2022 at 5:24 AM
    BadTrainDriver
    BadTrainDriver New Member
    2022 Tundra Capstone
    NaBra. That's what warranty is for.
  12. Aug 1, 2022 at 11:10 AM
    LaTundraSR5
    Carlos
    No, no cost out of pocket. They did have to get the OK to do it. It was a two-day process, though.
