2022+ Gen 3 Turbocharger Failure List.
Discussion in '3rd Gen Tundras (2022+)' started by Coal Dragger, Feb 9, 2022.
  1. May 18, 2022 at 1:18 PM
    #121
    Outbound
    Aaron
    Northern Alberta
    I think people are making a bigger deal of it than it is. Yes, it's a problem. It doesn't seem to be something normally expected of Toyota quality and that's why it's being splashed all over the internet. My suspicion is that it's well under 5% of produced Tundras that have the issue.
    DBWA, 22TTPlatinum and Craigaz like this.
  2. May 18, 2022 at 1:55 PM
    #122
    johnye75
    johnye75 New Member
    emo
    2022 tundra SR
    n/a
    I have to agree, based of forum polls and other inquiries, only few owners have the issue. Around 30k tundra's are already sold.
    22TTPlatinum, TMack77 and Craigaz like this.
  3. May 19, 2022 at 1:42 PM
    #123
    TitleFight88
    TitleFight88 New Member
    New to the tundra group, just came over from have a tacoma for the past 10 years.
    1.) 4/22 build date
    2.) 5/18 in for service
    3.) 5/14 failure - 510 miles
    4.) Parking Support Brake Malfunction - Advanced Ultrasonic Detecting on Range System (in app)
    My issue started with a warning saying Parking Support Brake Malfunction. I never received a reduced power warning. Took it in on 5/18 for service, they were backed up and had to keep it overnight for diagnostics.
    'Performed health check on vehicle, no codes found for parking brake system. Did have code P25B473 Turbocharger/Supercharger wastegate " actuator stuck closed. Started repair procedure, cleared code, turned vehicle off for 30 seconds, turned vehicle on and got coolant up to operating temperature, 170 degrees F, off again and set up snapshot function. Turned vehicle back on and started recording data. Checked data for measurements. Wastegate valve sensor voltage when fully open (bank 1 and 2) measured 1.31V and when fully closed measured 3.80V. When measuring voltage from wastegate fully opened to fully closed contact, voltage was 3.9V/sec. Performed all readiness test for code P25B473. System judgement came back as normal and no codes are present. Took vehicle on test drive and vehicle performed as designed.
    They told me it is all recorded now, so if the errors come back up, they have a history and will do whatever is needed to fix the issue.
    All in all, I am not too concerned and have confidence that my dealer will take care of me. Sucks that we are having issues but I somewhat expected it with a first year.
  4. May 20, 2022 at 3:06 PM
    #124
    truckit
    truckit New Member
    Georgia
    2023 1794 MGM, AVS, power running boards, spray in bed
    Excellent chronology - post. Sorry your having to deal with this.
    Your questions... "is this actually a turbo/wastegate issue, or is it a calibration/technology issue with all the new technologies in the Tundra?" GREAT QUESTION. I've been posing this question of 'part issue or technology issue?' on YouTube Tundra truck forums. I don't know the answer either but with the absence of information from Toyota it may be a turbo actuator (part) problem or a technology (firmware) problem or both?
    I'm a Toyota loyalist in that I have bought 8 different Toyota automobiles/trucks over the (40) years and the way Toyota has managed this issue has been quite disappointing. All that aside, still have confidence on the brand and waiting on delivery of my 22 Tundra ordered.
  5. May 20, 2022 at 7:15 PM
    #125
    mdre
    mdre New Member
    Matthew
    Livermore, CA
    2022 Tundra Limited Crew Max TRD OR 4x4
    I agree that your dealer sounds like they will take care of you. Some great service notes they provided you on that first visit.
    TMack77 likes this.
  6. May 23, 2022 at 5:30 PM
    #126
    OkieTundra22
    OkieTundra22 New Member
    Has anyone done or seen like a state by state map of these issues? Would be interesting to see if they are spread out throughout or regionally focused.
  7. May 30, 2022 at 1:31 PM
    #127
    brucega7x
    brucega7x New Member
    2022 Tundra SR5 CrewMax 4X4
    I actually believe Toyota is being truthful with the 1% thing.
    They've sold thousands of Tundras already. If more than 1% were having wastegate issues, I think we would know it.
    It seems like a bigger issue because, well, not as many people are taking to Facebook to say how much they love their truck...but you can bet your bottom dollar they'll be on every Tundra group and forum they can find to say that they're having a wastegate issue.
    That's just how the internet works. What's the saying? A loud or vocal minority?
    If mine ends up having the issue of course I'll be annoyed/aggravated. It's an expensive truck, and at this point, I would hope the issues are worked out. But I bought the truck 100% fully knowing that it is an issue I may possibly deal with. From here if it happens, it was on me that I rolled the dice.
    TMack77 likes this.
  8. Jun 3, 2022 at 11:13 AM
    #128
    johnye75
    johnye75 New Member
    emo
    2022 tundra SR
    n/a
    OkieTundra22 likes this.
  9. Jun 7, 2022 at 6:08 PM
    #129
    TitleFight88
    I am only sharing my experience so others can do exactly what we all do, research and try to figure out what might be wrong with their truck. When I ran into my issue, it took 4 days just to get an appointment and into the shop. They couldn't even tell me if it was safe to drive, or if it would cause more damage. It was helpful to come on here and see what others experienced.
    I LOVE my Tundra. It is by far my favorite vehicle I've ever had and I don't feel like I am trash talking it to make seem like a bigger issue. BUT, I do think this is a major issue. When you buy a vehicle, you expect to be able to drive it safely. Breaking down and potentially being stranded, with children, is simply not acceptable from any new vehicle. This should be brought to the attention of the manufacturer and if a forum helps do that, then great.
    Henry1jg, truckit and Breathing Borla like this.
  10. Jun 7, 2022 at 6:11 PM
    #130
    Breathing Borla
    AZ
    well said
    have my tundra cash ready but this and the wind noise give me pause
    TitleFight88[QUOTED] likes this.
  11. Jun 7, 2022 at 6:59 PM
    #131
    Coal Dragger
    Coal Dragger [OP] New Member
    Kung Fu Dick
    Reports of issues seem to have slowed down here. Maybe a good sign? Cautiously optimistic.
    For those who have to wait days for an appointment, I would just keep driving the truck. In fact I would gleefully drive it hard, hoping to blow it up. Like high pressure testing a rifle barrel, if it survives it’s probably good enough I go…. if it fails I sure don’t want it anyway.
    Henry1jg and Breathing Borla like this.
  12. Jun 7, 2022 at 7:03 PM
    #132
    TitleFight88
    Typically, I totally agree with you, but I need my truck and who knows when I could ever get a replacement if it blew up. If it was 2019, I’d hammer it down.
  13. Jun 7, 2022 at 7:26 PM
    #133
    Coal Dragger
    Kung Fu Dick
    Understand.
    I have multiple vehicles at my disposal, so I have the relative “luxury” of being able to wait to buy, repair, or replace one.
    Not everyone is in the same boat.
    If it makes you feel any better the default programing in the Tundra seems to be self protective. If the waste gate sticks the ECU cuts throttle to make boost nearly impossible. Of course that renders the truck in limp mode.
    Breathing Borla likes this.
  14. Jun 23, 2022 at 7:00 AM
    #134
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Does anyone know what the process is when Toyota builds their vehicles and then test drives them?
    How many months/miles would they have put on the new tundra before they start shipping them out?
    We all see the early pics of the tundra all wrapped up so we cant identify it during their test runs, I
    just wonder how long they performed their tests before they were offered for sale or order.
    I would think they found and knew about this issue before they were offered for sale.
    Maybe that's not how it works, IDK...
    Tundrastruck91 likes this.
  15. Jun 25, 2022 at 11:18 AM
    #135
    22PlatWCP
    22PlatWCP New Member
    Mississippi
    2022 WCP Platinum 4x4
    Seeing as how so few of the 2022’s have been affected by this issue what were the chances that their test vehicle(s) would have had the problem?
    TMack77 likes this.
  16. Jun 28, 2022 at 7:24 AM
    #136
    2017TundraNC
    2017TundraNC New Member
    North Carolina
    2022 Tundra 1794 4x4 6.5'
    Add me to this list! Assumed it was the trans but I see here it maybe otherwise.
    1550 miles. Truck cut off on me, while on the Interstate.
    One hour ago...
  17. Jun 28, 2022 at 12:29 PM
    #137
    Gene5253
    Gene5253 New Member
    Gene
    Boise ID
    2020 Tundra CM Limited
    Build date ??
  18. Jun 28, 2022 at 1:28 PM
    #138
    22PlatWCP
    Mississippi
    Why don't you find out for sure it's the waste gate/turbo issue before posting it here? Maybe it IS your transmission.
    Ranger2005 likes this.
  19. Jun 29, 2022 at 1:26 PM
    #139
    Coal Dragger
    Kung Fu Dick
    That’s a sound bit of advice just to keep this discussion organized.
    I may ask a moderator to come in and remove some extraneous posts, including my own just to keep information tidy here.
    Paging @ColoradoTJ if he wants the task….
    22PlatWCP likes this.
  20. Jun 29, 2022 at 5:08 PM
    #140
    Having a transmission fail on a brand new truck is so much better. :p
    Bannerman and Melikeymy beer like this.
  21. Jun 29, 2022 at 6:34 PM
    #141
    22PlatWCP
    Mississippi
    Having a comment on a transmission failure in a thread about turbo failures is kinda ridiculous.
    TMack77 likes this.
  22. Jun 29, 2022 at 6:56 PM
    #142
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
    I know this isn’t all about the turbo, and I’m in a first gen. However, I have talked with 10+ 2022 owners in front of their trucks and none of them have had any lights or failures. 5-15k miles on them all.
    Craigaz, vichmr and TMack77 like this.
  23. Jul 19, 2022 at 8:07 AM
    #143
    DockCrasher
    DockCrasher New Member
    2022 Tundra CrewMax Limited MGM
    Mine is in the shop now getting the turbo replaced as we speak. I’ll update with all the particulars later. My question: once the dealer has the parts and they’ve started the job, how long has it taken everyone to get their vehicle back?
  24. Jul 19, 2022 at 9:39 AM
    #144
    Breathing Borla
    AZ
    build date?
  25. Jul 19, 2022 at 10:12 AM
    #145
    DockCrasher
  26. Jul 19, 2022 at 10:56 AM
    #146
    22PlatWCP
    Mississippi
    Mileage?
  27. Jul 19, 2022 at 11:24 AM
    #147
    Breathing Borla
    AZ
    Have there been any may or June build failures? I think the last one I saw was April
    If not , they may have fixed it for the new builds
  28. Jul 21, 2022 at 10:03 AM
    #148
    RangerMarsh
    RangerMarsh New Member
    2022 Tundra TRD
    Once parts are in stock, it took 2 days in my case.
  29. Jul 21, 2022 at 12:54 PM
    #149
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    2022 SR5 TRD OR 6.5' Bed
    Got my truck back the same day they received the parts. It took a couple days to get all the necessary parts. Truck was there for 5 days including the weekend. They were all over it at my dealer. Painless experience.
  30. Jul 28, 2022 at 11:11 PM
    #150
    mrtech2
    mrtech2 New Member
    Dave
    New Mexico
    2022 Blueprint Tundra Limited TRD
    Wind noise? My 2022 Tundra Limited TRD Off Road is the quietest truck/vehicle I have ever owned.
