  1. Jul 27, 2022 at 8:59 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    It is IMO. I have 17X8.5 at 0mm. I added 3/4" spacers for frame rub. From a poke standpoint, we are almost identical (1/4" +12mm). I'm on a bigger tire so, the body rub took a bit of work. You should be perfect.
  2. Jul 28, 2022 at 10:35 AM
    TravisJr
    TravisJr New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
    Added a toolbox:
    KK6PD, RUSTYNUTS, 5N0W808 and 16 others like this.
  3. Jul 28, 2022 at 12:50 PM
    alb1k
    Left Coast
    It's good
    Your truck looks great!
  4. Jul 28, 2022 at 3:56 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Just curious if you have OEM cams or a different setup?
  5. Jul 28, 2022 at 6:47 PM
    snoope
    snoope The Old Man
    Body clips and assorted plastic fastener kit ?? o_O
    I just ordered one from Amazon and it had all the parts I needed PLUS....and included a few of those plastic body knifes/ easier to pull those PIA door switches out with :thumbsup: :hattip:
    Inner fenders all TIGHT , fender skirts secured and a few pieces that were worn but starting to rattle...:fistbump:
    NUDRAT[QUOTED] likes this.
  6. Jul 28, 2022 at 7:06 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Just an FYI.
    SPC are cheaper, for a very good reason. I've seen those plastic sleeves squish in the slotted holes and make knocking noises in the front LCA's of Toyota trucks & SUVs.
  7. Jul 28, 2022 at 7:22 PM
    Wait, uppers, lowers, or adjusters?
    I just ordered their UCA because they looked beefier than what Camburg and others are putting out.
  8. Jul 28, 2022 at 7:35 PM
    alb1k
    Left Coast
    It's good
    I'm not sure the specifics of SPC. but I will say they are not beefier than TC or Camburg. Nothing is.
    oscardog86, RUSTYNUTS and 805Tundra like this.
  9. Jul 28, 2022 at 7:36 PM
    TravisJr
    TravisJr New Member
    Lots o’ mods
    You are too kind. It’s a work in progress. Happy with the advances so far.
    oscardog86 and RUSTYNUTS like this.
  10. Jul 28, 2022 at 7:39 PM
    alb1k
    Left Coast
    It's good
    I'm not even being kind. I really like it and I think you have really made an effort for a long run play on that one. Seems like a very smart set-up. I will tell you, my experience has been go with the best you know at the time, and then adjust, and adjust again. But I'm trying to push things now, never did before. I think you are super stoked and made great choices.
  11. Jul 28, 2022 at 7:49 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Bolt / cam adjuster kits.
  12. Jul 28, 2022 at 8:06 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    My truck will have an experimental tune on a spare ecm. If the tune works well then the fixes will be known for the VF Tuner whenever that happens.
  13. Jul 28, 2022 at 8:11 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Got the spindles back on and man what a difference new bearings make. Much smoother and quieter. My homie hooked it up and only charged me 100 total for both. It was a good day :)
    NUDRAT, shifty`, oscardog86 and 3 others like this.
  14. Jul 28, 2022 at 8:17 PM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    What's the tune involve?
  15. Jul 28, 2022 at 8:20 PM
    empty_lord
    05 rollover special
    Physically modifying the ECM by a friend. He doesn’t do it normally. But he’s willing to mess with it. Likely just going to mess with MAF. Maybe some vvti tweaks.
    But dyno time is needed to go aggressive. And this process is uh… LONG.
  16. Jul 28, 2022 at 8:28 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    @empty_lord @BubbaW @shifty`
    If i buggered the integration relay, but am willing to hardwire the headlights what else could malfunction?
    @shifty` they disabled other shiftys acct.
    NUDRAT likes this.
  17. Jul 28, 2022 at 8:29 PM
    daveeasa
    Fixed my passenger headlight today by recycling the nylon insert from the OG headlights. It fits nice and snug whereas the new (OEM) one pops out. One less problem. Also swapped back to OEM corners and put in new NA bulbs.
    Next up is fix the headlight problem.
    Also, front coilovers off because they don’t lift the nose. So probably need 700’s instead of the 650’s they came with?
    Voss likes this.
  18. Jul 28, 2022 at 8:29 PM
    empty_lord
    05 rollover special
    Hard to say. The integration relays affect a lot of the truck
  19. Jul 28, 2022 at 8:31 PM
    daveeasa
    So, my plan as of right this moment is to order a new part. Eric from Decatur thinks he knows the right one. He has 2 in stock. I think I can plug it in and test with it to see what it does. Then I could send one to you if it solves our problem.
    shifty` likes this.
  20. Jul 28, 2022 at 8:33 PM
    daveeasa
    But with a harness and an aftermarket switch, it’s possible to go completely off reservation. Just no high beams that way without having it all ground switched and capturing the high beam ground.
    I was at my truck twice today but super tight on time and didn’t get to prove the h4. I suspect our ground switching might be ok and we just need the +12V part? But that’s a guess.
  21. Jul 28, 2022 at 8:34 PM
    daveeasa
    If someone made a 3 way rocker in oval shape, that would be a decent temp headlight switch.
  22. Jul 28, 2022 at 8:39 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Lemme know if it fixes it, i plugged it in without due diligence, this is on me. And if i can hotwire in some lights, i'm pretty sure i'll be better off.
    Low beams might be a 37" lightbar.
    RUSTYNUTS likes this.
  23. Jul 28, 2022 at 9:05 PM
    daveeasa
    I got your back. Defective product is a business expense. I just don’t want to fry your truck worse so I’d rather confirm the board does no damage before sending you one. I’ll order up tonight.
    I can hook you up with a headlight harness down the road but I’m kinda in a rough spot the next couple of weeks as far as time.
  24. Jul 28, 2022 at 9:16 PM
    Outbound
    Aaron
    Northern Alberta
    Detailed it and pulled all my stuff out of it. Dad has paid me for it so it's officially his now. Just waiting on my new truck..
    NUDRAT, shifty`, RUSTYNUTS and 2 others like this.
  25. Jul 28, 2022 at 9:43 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Nice! I’ve been considering a tool box lately. Seems like a better and cheaper storage option vs typical overland cargo containers. Tools and extra parts would do well centered on the truck.
  26. Jul 28, 2022 at 9:58 PM
    TravisJr
    TravisJr New Member
    Lots o’ mods
    Dealer tried to sell me on a new Decked box he had in stock. Aesthetically, it wasn’t up my alley, but if I was outfitting a true work truck it would be the direction I would go.
  27. Jul 28, 2022 at 10:03 PM
    daveeasa
    I came close to getting decked for the ‘05. Since that’s the one truck the dog won’t ride in. But I wasn’t overly keen on it. Makes sense. Nice to have tools. But probably better not as a daily. And if it’s not a daily then why have them there at all?
  28. Jul 29, 2022 at 1:15 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Aw shucks. Already reinstalled em huh? I was gonna say that wouldve been THE perfect opportunity to weld on a set of spindle gussets. I welded mine on the truck, and it's done, but lookin at that pic of your spindles off the truck and bare..... that would be ideal, so much easier.
  29. Jul 29, 2022 at 6:16 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Its best to do them off the truck, but I think if you are careful with your heat and you weld in intervals so the heat doesnt build up in one area too much you can get away with doing them on the truck. But still, if i ever go that route id probably wanna do them off the truck if possible.
    5N0W808[QUOTED] likes this.
  30. Jul 29, 2022 at 7:23 AM
    That was never the plan for me. I'd always planned to do a two-phase approach to support the end goal. I've learned multiple times about going all-in, it doesn't work for me and my life. Just results in never being finished with anything, but much more so than the usual not-finished you'd end up with.
    NUDRAT and oscardog86 like this.
