2 different type of tow hooks
Discussion in '2.5 Gen Tundras (2014-2021)' started by hatchboi, Jul 27, 2022.
  1. Jul 27, 2022 at 10:12 AM
    hatchboi
    hatchboi [OP] New Member
    Does toyota make 2 differend type of tow hook for the tundra? I notice i have the one with the loop facing towads the ground while i see some people have the one with both loops, one facing towards the front of the bumper and one loop facing towards the ground.
  2. Jul 27, 2022 at 10:18 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Not 100% sure but i think there are ones for the 2wd and ones for the 4wd.
  3. Jul 27, 2022 at 10:24 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
  4. Jul 27, 2022 at 10:40 AM
    1794TX
    Steven
    N.TX
    '20 1794
    I think the one with one loop pointing to the ground was a factory part for 07 - 13 models, and the two-loop were 14 - 21; but they should be swappable.
    If you're at the point of buying new ones, the two-loop version is pretty pricey, unless you can find an online seller. There are aftermarket options.
  5. Jul 27, 2022 at 10:55 AM
    hatchboi
    Part Number:51960-0C020
    Part Number:51960-0C011
    Yea one is $138 and the other one is $35. It hard to tell with the picture toyota provide cause it a drawn up image of it but im assuming the double loop cost more then the single loop. I see some people get them podwer coated red and it looks cool when it sticks out a little like this guy did https://www.tundras.com/threads/bilstein-5100-and-oem-tow-hook-red.48740/. I think it give it a nice little touch with my trd pro wheels.
    bulldog93 likes this.
  6. Jul 27, 2022 at 11:26 AM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
  7. Jul 27, 2022 at 11:27 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    @e30cabrio is selling a set: https://www.tundras.com/threads/51960-0c011-dual-ring-oem-tow-hooks.110662/
    Edit: Eric was quicker on the draw :quickdraw:
    Bikeric likes this.
  8. Jul 27, 2022 at 11:28 AM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
  9. Jul 27, 2022 at 11:28 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    As others have said, I believe the single loop tow hooks are from 07-13 and the dual loop tow hooks are from 14-21.
    Here is a set on eBay...
    https://www.ebay.com/itm/2848859353...YsaVgP3FZuT8SfqQVY9xbS7s-FX7g74MaAqsBEALw_wcB
    I also had mine powder coated red to match the sway bars, I like it
  10. Jul 27, 2022 at 11:33 AM
    McCrapper
    McCrapper New Member
    4wd point to the bumper.
    2wd points downward.
  11. Jul 27, 2022 at 11:36 AM
    hatchboi
    Appreciate the help everyone. I dont know why my 16 has the older truck hooks but im definitely interested in the hook bikeric
  12. Jul 27, 2022 at 11:38 AM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    Contact e30cabrio
