Dash panel bracket
Discussion in '1st Gen Tundras (2000-2006)' started by RVAtruck, Jul 25, 2022.
  1. Jul 25, 2022 at 7:03 PM
    RVAtruck
    RVAtruck [OP] New Member
    Richmond, VA
    2005 Tundra double cab Limited 4wd
    I just had a new stereo installed and the guy said the brackets that hold the trim piece around the stereo and ac knobs are totally shot. Looking at the blowup for the dash panel, I can’t tell if the brackets are a separate part, or if I would need to replace the whole dashboard to replace those brackets. Anybody out there have any experience with this?
    https://parts.toyota.com/a/Toyota__...ENT-PANEL--GLOVE-COMPARTMENT/841420-5551.html
  2. Jul 25, 2022 at 7:11 PM
  3. Jul 25, 2022 at 7:15 PM
    Or maybe it's the 'Instrument panel brace' shown here?
    Can you get us a pic of what the guy is bitching about? This sounds like it may be a serious 'nope out' situation.
  4. Jul 25, 2022 at 7:26 PM
    RVAtruck
    Richmond, VA
    The screws that hold this thing in have no place to go. Anybody can’t tell if that bracket is part of the whole dash or a separate piece
  5. Jul 25, 2022 at 8:27 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    So the piece in the picture is fine? You just need the piece that this actually screws into?
  6. Jul 25, 2022 at 8:40 PM
    RVAtruck
    Richmond, VA
    Correct
  7. Jul 26, 2022 at 4:26 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Mind taking a picture similar to what's posted below showing what your "guy" is talking about.
    The bracket piece @shifty` is highlighting in red should take care of top 2 screws. The other 3 screws at HVAC control knobs should be available as part of HVAC control module or the rectangular HVAC module would just fall.
    If the bottom 3 screws is all you have holding face plate in place, IMHO that's more than enough if top bracket is not available.
  8. Jul 26, 2022 at 4:58 AM
    Teutonics
    Teutonics BestGen Member
    2005 DC SR5 4WD 4.7L AX
    If it were me I'd try to get creative with some epoxy or JB Weld to fill and redrill/tap the holes. Or even epoxy in some speed nuts.
  9. Jul 26, 2022 at 5:22 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    How can they be "shot"? They're not a wear or maintenance item by any means. They only get used when the panel is removed, maybe a dozen times or less typically in the life of the vehicle. More than likely your guy...um, er...let's say he may have contributed to the problem. Pictures please...
    shifty` likes this.
  10. Jul 26, 2022 at 5:31 AM
    RVAtruck
    Richmond, VA
    It’s in the shop so again so I can’t take pictures, but I think the pieces that Shifty and BubbaW posted should do the trick
    the panel was loose when I got the truck. The dash cup holder won’t go all the way in also. I’m guessing the previous owner got into the dash and didn’t put it back together right. Once I get the truck home and get into the dash I’ll send some pictures
    I appreciate all the help. Glad there’s a chance I won’t have to replace the whole dash
  11. Jul 26, 2022 at 6:57 AM
    This was my very 1st thought on my 1st reply above. If there was a problem with them, it would've been noticed at removal, and the "guy" should've notified the customer. That's standard practice for CYOA (cover your own ass) in the industry. The fact this dude is hearing about it after the fact tells me either the person installing it (a) did it himself or (b) is trying to reinstall the panel incorrectly.
    But I digress. OP explained it well enough. And OP, the trick with epoxy or JB seld to re-fill the mounting hole is on-point.
  12. Jul 26, 2022 at 7:40 AM
    w666
    Maryland
    Yeah, but...the mounting holes have spring clips, so perhaps they are gone and thus "oversize holes"?
  13. Jul 26, 2022 at 8:18 AM
    Look at the pic BubbaW posted a couple replies up. No spring clips in the HVAC control holes. I don't remember what's up top to hold the screw in.
    I know in some of my older cars they used spring clips. I can't remember what's in the upper holes of my dash.
  14. Jul 26, 2022 at 8:35 AM
    w666
    Maryland
    Yeah, I meant the uppers.
    shifty`[QUOTED] likes this.
  15. Jul 26, 2022 at 9:20 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    The upper is part of that bracket shifty mentioned in his 2nd post and there are no clips, not on fnt side nor bck side of bracket. The holes in bracket are simply sized to accept the original screws provided. I'll also add that the bracket itself does not come out easy peazy....don't ask how I know !
    from my 04 Tundra…
    w666[QUOTED] likes this.
  16. Jul 26, 2022 at 9:25 AM
    Sometimes with stuff like this, simply "deforming" the hole (i.e. flattening it, removing crown slightly) will close the hole enough to firm up the fasteners. I've had to do this with (for example) cowl fasteners on a previous vehicle.
    BubbaW[QUOTED] likes this.
  17. Jul 26, 2022 at 9:31 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Agree but if/when you have panel off, you'll see that the only way to deform the hole by flattening can only be achieved by removing bracket IMHO. Hopefully OP's bracket is indeed in place and can replace properly sized screws or drill a slightly bigger hole to accept bigger screws.
    OP should have stayed off work today....suspense is a bitch :eek::D
