Advice needed on 2004 stock 2WD steering knuckles
Discussion in 'Suspension' started by Helipro, Jul 24, 2022.
  1. Jul 24, 2022 at 9:15 PM
    Helipro
    Helipro [OP] New Member
    2004 Tundra SR5 - 2WD
    None
    Got myself into a pickle here… Had this truck since new and got 435K on it now with no significant issues. Started getting a bit of a rumble while decelerating and thought it might be time to replace the front wheel bearings…. Gathered as much info as I could from online and thought “No big deal” … WRONG!!! Come to find out no one sells an aftermarket hub, and no one mentions that there are actually 2 bearings per hub. The outer bearings on both hubs wound up getting destroyed while trying to press out the hubs. Bearings frozen on the hubs… So… does anyone know where I can find replacement parts? Hoping I don’t have to buy full assemblies from the dealership. Getting the outer races out of the knuckles can probably be done with some careful Dremel grinding. Thanks in advance…
  2. Jul 24, 2022 at 10:06 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
  3. Jul 24, 2022 at 11:51 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    For the 00-02 trucks you can get the whole knuckle but they are $700 a side for aftermarket. Probably be better off finding a junkyard truck if you can. Just keep in mind after 03-06 is a different spindle from the earlier ones. Think it has to do with lower ball joint design.
