Alignment Question for 22s
Discussion in 'Suspension' started by jmay86, Jul 23, 2022.
  1. Jul 23, 2022 at 8:21 AM
    jmay86
    jmay86 [OP] New Member
    Josh
    Columbus, Ohio
    '22 Lunar Rock LTD DC TRD-OR
    Can anyone who actually knows more than “Green Good, Red Bad” tell me how bad this alignment reading is?
    Just picked up the truck from 4WP and forgot to check the dang paperwork before heading home…
  2. Jul 23, 2022 at 8:37 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    Do you have a lift? That caster is really low. I believe factory spec is closer to 4.4 degree of caster. Camber and toe is pretty spot on to factory spec.
  3. Jul 23, 2022 at 8:39 AM
    jmay86
    Josh
    Columbus, Ohio
    westcott 3/1 and 35s
  4. Jul 23, 2022 at 8:47 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
  5. Jul 23, 2022 at 10:02 AM
    jmay86
    Josh
    Columbus, Ohio
    Think I found the issue… they used the specs for 20-21 model which I’m sure is different…
    Caster is how centered the wheel is front to back within the wheel well, right? If so, that could be why I noticed I’m still rubbing on full lock when reversing?
    ryanwgregg likes this.
  6. Jul 23, 2022 at 10:13 AM
    jmay86
    Josh
    Columbus, Ohio
    thank you, I’m going to call them Monday and see if they will fix this…
  7. Jul 24, 2022 at 8:07 AM
    docfnky
    docfnky New Member
    Push the rear cam bolts on the lower control arm as far out as it’ll go to maximize caster then adjust the front cam bolts to bring camber into specs.
