  1. Jul 20, 2022 at 5:24 PM
    Jjclamdips
    Jjclamdips New Member
    Wichita, Ks
    2000 Access Cab
    I assume that they are all painted underneath, it’s just a vinyl decal.
  2. Jul 20, 2022 at 5:49 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    If you do please share a pic. I've been pondering black wrapping the A and B pillars and the lower part of the grill. I'm just totally stealing the 2022 design:
    Mountun Goat and doublethebass like this.
  3. Jul 20, 2022 at 6:05 PM
    ACDC2ZZTop
    ACDC2ZZTop Rock n Roll!
    Travis
    Oregon
    2012 MGM Tundra double cab 5.7L V8
    All cosmetic so far see my posts in 2nd gen Black out chrome in progress….
    I may have to do this. I have same paint color and looks better IMO
    Jjclamdips[QUOTED] likes this.
  4. Jul 20, 2022 at 6:19 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Same here on the 3rd gen idea
  5. Jul 20, 2022 at 7:54 PM
    Kwe1982
    Kwe1982 New Member
    Wisconsin
    2007 Tundra and 2011 Sequoia
    Finally got to installing the full skid and cat protection on my 07.
    not too fun when all of your undercarriage is coated will woolwax.
    Mountun Goat and joseph_womack like this.
  6. Jul 20, 2022 at 7:56 PM
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    They give a great ride and last pretty well.
    I've recently put my third set on the front end of this truck, the other two will go on when the rear's worn down a bit more - I don't do proper rotations as I'm too tight to stump up for four tires in one hit. So, simply put, I get about 60,000 on the front and about 75,000 on the rears.
  7. Jul 20, 2022 at 8:01 PM
    EmergencyMaximum
    @TheBrit , If you rotate tires properly, you save money by prolonging their lives. Also, no need to do four tires all at once, rotate them in pairs; makes it easier, half the effort.
    TheBrit likes this.
  8. Jul 21, 2022 at 1:11 AM
    TheBrit
    Mark
    I do rotate, in pairs.
    My brother in law, who has a rural Florida attitude of only fixing his vehicles when their ability to be propelled forward is affected, has two things he does to his vehicles. He religiously does his oil changes at, what I consider to be, ridiculously short intervals and rotates all 4 tires reasonably regularly. If he has to replace one tire, he'll do them all and thinks I'm the loony for not doing the same. :eek:
    I'd rather do regular all round maintenance, change my tires when they need it and not before. :)
  9. Jul 21, 2022 at 3:06 AM
    ftmyerstundra
    ftmyerstundra New Member
    Gary
    2007 Tundra Crew Limited
    absolutely none
    Overhauled the front suspension. Was pretty straight forward but was not fun laying on my back in the garage in the florida heat trying to but 220 ft lbs on those 4 bolts. Hopefully wont have to do it again.
  10. Jul 21, 2022 at 8:58 AM
    Tundra3k
    Tundra3k New Member
    Kansas
    2012 Crew Max
    Nope. I’m holding off on getting one for now.
  11. Jul 21, 2022 at 1:46 PM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Took her down the mountain for a bath and to get a tire patch/plugged. Last patch on this tire, Big O will have to replace it next time as they only do 3 patch/plugs per tire and I'm only 1yr/8,259 miles into a 3yr/60k warranty. Probably getting the others replaced next yr since I am well past 1/2 worn. I thought I was at 10-11k, but I was a little off.
  12. Jul 21, 2022 at 5:23 PM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    This is why I bought a huge Ridgid impact wrench
    Ohannon7 and joseph_womack like this.
  13. Jul 21, 2022 at 5:24 PM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    Reduced my gas mileage by about 40% for certain periods of time
    WVI, Blang805, MTRock and 6 others like this.
  14. Jul 21, 2022 at 5:54 PM
    flyeaglesfly94
    flyeaglesfly94 2013 Tundra Platinum
    Atlanta GA, USA (ATL)
    Eibach Pro Truck Lift - Stage 2
    Where did you buy the grille insert?
  15. Jul 21, 2022 at 6:51 PM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    I think off of Alibaba. It was like $150-$160 shipped. Came with the letters
  16. Jul 21, 2022 at 7:37 PM
    flyeaglesfly94
    How do you like the eibach Kit?
  17. Jul 22, 2022 at 5:38 AM
    BEDINTRUDER
    BEDINTRUDER New Member
    Dom
    OHIO
    2011 Tundra RockWarrior (SOLD) 2018 Tundra Limited
    Since ive been towing more often and with heavier loads, decided to grab a Firestone Ride Rite kit. installation was a absolute breeze. Very happy with how it turned out
  18. Jul 22, 2022 at 5:53 AM
    Chrslefty
    Chrslefty New Member
    08 dubble cab
    What windows vents are you running? Have you been pretty happy with them??
    Truck looks great
  19. Jul 22, 2022 at 6:01 AM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    Honestly, I have no clue...they came with the truck when I bought it! I can take a look when I head out later and see if there's a brand name stamped on them. I assume there should be. They seem to work well? I have no comparison as they're the first set I've ever had on a vehicle. I have noticed a couple of spots where they've rubbed the paint down, but again, I'm not sure if that's normal or not!
    Chrslefty[QUOTED] likes this.
  20. Jul 22, 2022 at 6:05 AM
    Windsor
    Homeless in Oregon
    Some.
    They are even nicer when you add an automatic adjust setup. Great excuse for OBA.....
  21. Jul 22, 2022 at 6:12 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Can't speak for TJ, but I have been very happy with my Eibach 2.0's
    Fully adjustable (up front) to dial exactly the lift you desire.
    Beefy construction; Factory, Bilstein, and most others I've seen have a tiny little spindle for the lower mounts, which are not confidence inspiring.
    Coilovers come fully assembled with new, beefy top mounts. Didn't even use my spring compressors.
    The ride is quite comfortable on-road, even with heavy, +1 AT tires (@50psi). Offroad, provides playfully handling and decent comfort over washboard (I have not added any rear sway bar.)
    You get the strength of steel construction while the zinc coating should provide better corrosion resistance than typical paint.
    All in all, Eibach has assembled a very nice kit for the $. I have thoroughly enjoyed them over the past year.
    joseph_womack likes this.
  22. Jul 22, 2022 at 3:09 PM
    Musicmasterd12
    Southern Louisiana
    Installed throttle controller and some cup holder inserts
    EF120B36-A32A-4C1A-9CA6-AAA3544E1B40.jpg 112076C1-E079-4F5D-A714-ACCB0142671E.jpg
    D4x4TRD, joseph_womack, WVI and 6 others like this.
  23. Jul 22, 2022 at 3:28 PM
    EmergencyMaximum
    Hmm, what's controller do?
    Okiebug likes this.
  24. Jul 22, 2022 at 3:29 PM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    Put myself back 20 years.
    Not even sure this is the correct orientation or location...
    Also, note the zip ties holding the license plate on after the rusty bolt literally popped out with a loud clang.
    D4x4TRD, joseph_womack, WVI and 3 others like this.
  25. Jul 22, 2022 at 3:33 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  26. Jul 22, 2022 at 3:43 PM
    Musicmasterd12
    Southern Louisiana
    better throttle response, reduces the lag
    only took it for a short trip around the block so far but it’s definitely noticeable. Will have to check it out on the hwy
  27. Jul 22, 2022 at 5:04 PM
    EmergencyMaximum
    I thought tow haul mode was designed to do just that?
  28. Jul 22, 2022 at 5:08 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think that the add-on gives more options than just the one that T/H offers. For example, I think that the controller can make less sensitive than stock, kind of an Economy setting.
  29. Jul 22, 2022 at 6:14 PM
    Musicmasterd12
    Southern Louisiana
    correct. It’s got an eco, normal, sport, and sport plus mode. And then each mode has 9 settings
    so multiple different sensitivity settings (both increased and decreased).
    Wynnded[QUOTED] likes this.
  30. Jul 22, 2022 at 6:52 PM
    EmergencyMaximum
    Well, don't get me wrong, but how does sensitivity improve your way of driving? Sensitive or not, it's still a 4.6 or 5.7. There's only so much you can gain by adjusting sensitivity. Not enough power, depress pedal more, simple as that. No need for some fancy controller if you ask me, gang.
    Sorry if I sound like a broken record. I'd love to be proven wrong.
    07 Tundie likes this.
