Steering wheel lock/coolant water leaking
Discussion in '2nd Gen Tundras (2007-2013)' started by raymond_hb, Jul 22, 2022.
  1. Jul 22, 2022 at 10:40 AM
    raymond_hb
    raymond_hb [OP] New Member
    Oakland, CA
    07 Tundra Limited 2WD
    Hi all,
    Today as I was making my way home I heard a strange high pitched noise followed by a clunk. When I pulled into my garage I noticed my steering wheel started getting stiffer the more I would turn it to back into the garage. Once I gave it a little gas the steering wheel would come loose. After I parked I noticed ALL my coolant was leaking from the radiator. Also popped the hood and noticed there was water around the engine bay some splashing above and the radiator reservoir is empty.
    Safe to say my radiator popped but what I’m not understanding is why my steering wheel became stiffer unless I gave it gas? Anyone have any idea? I’ll be searching for a new Radiator soon but I’d like to know if there is anything else I need to check
  2. Jul 22, 2022 at 10:44 AM
    Bozothedog
    Bozothedog New Member
    Is the fan belt still there???
  3. Jul 22, 2022 at 10:54 AM
    raymond_hb
    Oakland, CA
    It’s looking like it is there drenched in coolant
  4. Jul 22, 2022 at 10:56 AM
    raymond_hb
    Oakland, CA
    Sorry forgot to quote
  5. Jul 22, 2022 at 11:10 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Pump pulley could've been slipping if it was getting soaked would be my first thought.
  6. Jul 22, 2022 at 2:40 PM
    raymond_hb
    Oakland, CA
    It sounds like this is about what might’ve have happen I’m glad it wasn’t too serious. Thank you everyone for your input :D
