Toyota Tundra transponder ecu module
Discussion in '2nd Gen Tundras (2007-2013)' started by Nickw007, Jul 19, 2022.
  1. Jul 19, 2022 at 10:34 PM
    Nickw007
    Nickw007 [OP] New Member
    Hi
    Does anyone know where the transponder ecu module for 2007 Toyota Tundra is located?
    is it behind the hvac box ?
  2. Jul 19, 2022 at 10:43 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Yes. Back of the evaporator core housing.
    Should be part 89780-0C010
  3. Jul 20, 2022 at 6:14 AM
    Nickw007
    Thanks a lot for your reply!
    do you happen to know if the connector for it is on the driver or passenger side ?
    Do you think it’s accessible without pulling out the dash?
    I changed evaporator but have the one plug left shown in pic to connect and couldn’t find anywhere so am praying it’s for the transponder ecu module on back of hvac box and that I missed.
    been trying to get struck to start for a week and couldn’t find issue.
    Truck has no security light flashing at all so I think/hope it’s because the transponder ecu module wasn’t plugged in.
    Took dash out 3 times already and couldn’t find anything not connected so with gods good will hopefully that plug isn’t connected and the truck will fire right up when I connect it.
    gonna do it this afternoon and post here of it worked!
    if you happen to know which side of hvac box it’s on Id really appreciate it so that maybe I don’t even have to remove dashboard again
    thanks a lot!
  4. Jul 20, 2022 at 7:19 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    The Transponder ECU is on the back of the HVAC box near the fire wall in this cut out area (in red). Looks like to me the connector comes in from the passenger side and its up near the top of the box. Study yours carefull as this picture is kind of upside down from the way the box sits in the truck
    Look at this pinout to see if your wire colors match. It most likely is the Transponder ECU plug from what I can see.
  5. Jul 21, 2022 at 7:54 AM
    Nickw007
    Yeah thanks a bunch for that info !
    it’s exactly what the issue was, causing the crank no start & no security light flashing. after changing evaporator and putting dash back, didn’t see that connecter there for the transponder ecu and didn’t plug it in.
    I was so happy hearing that damn motor stay on lol after a week of searching up and down, I was losing hope thinking I’ll have to tow it to Toyota and pay them however much to find that the transponder ecu wasn’t plugged in lol. After seeing the pic I was 95% sure it would fix the issue though
    thanks a lot for the pics and confirming transponder location.
    Zero change of seeing it without knowing it’s there and pulling out dash. Even with the dash out it’s still a tight but hole trying to plug in it in.
  6. Jul 21, 2022 at 8:03 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    How hard was it to plug in with the dash installed? Were you able to reach up under there and get the connector on or did you have to take the dash apart again?
    Nickw007[OP] likes this.
  7. Jul 21, 2022 at 9:01 AM
    Nickw007
    Yeah I had to take the dash out again completely and the crash-bar/dash frame
    and even then had to pry the hvac box back from firewall to get a few inches clearance to fit hand back there and wiggle it on.
    Was able to pop it in without taking hvac box out but definitely had to take dashboard and frame out again to get enough space to pop it in.
    zero chance I could fit with the dash on
    tried to upload the vid I took but the site doesn’t seem to allow vid upload
    but this is pic of the connector back there
    Jeff_5_7 likes this.
  8. Jul 21, 2022 at 9:02 AM
    Nickw007
  9. Jul 21, 2022 at 9:03 AM
    Nickw007
