Camper shell roof support
Discussion in 'Tonneau Covers, Caps and Shells' started by Tundra18overland, Jul 20, 2022.
  1. Jul 20, 2022 at 3:55 PM
    Tundra18overland
    Tundra18overland [OP] Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    thearborbarber likes this.
  2. Jul 20, 2022 at 10:55 PM
    SR5camper
    SR5camper New Member
    AZ / TX
    2015 SR5
    This looks like a PIA. I would probably just upgrade to a reenforced shell before going that route.
    How much weight are you planning on running on top of the shell? Most unreinforced camper shells are rated for 400lbs+ of static load and 250lbs+ of dynamic load. So more than enough for a roof rack full of gear or even a light RTT. ARE shoudn be able to provide you with more accurate load ratings.
  3. Jul 21, 2022 at 1:24 PM
    Tundra18overland
    Jesse
    GA
    That sounds about right, but I'm still concerned with cracking and shifting of the shell over time. I plan on doing some tough off roading.
  4. Jul 21, 2022 at 2:43 PM
    SR5camper
    AZ / TX
    2015 SR5
    Unless you're mounting something heavy on it I wouldn't worry about it. My midtravel DC and many others have thousands of hard off-road miles on their shells without any problems
  5. Sep 3, 2022 at 5:42 PM
    Aswongsc
    Aswongsc New Member
    Even though it’s not listed, they do fit the tundra. I took the measurements from the website and measured the bed sides. But if you have bed rails, don’t think they will. I did have to cut some of the overhang of the topper that hangs over on the inside in order to have the bracket as much over the center of the bed side.
  6. Sep 3, 2022 at 6:27 PM
    Tundra18overland
    Jesse
    GA
    What year is your tundra?
    you have any pics of install?
  7. Sep 3, 2022 at 7:54 PM
    Aswongsc
    Aswongsc New Member
    I have a 2010 double cab
  8. Sep 3, 2022 at 8:37 PM
    Tundra18overland
    Jesse
    GA
    Thanks, looking good. I really want to keep my bed rails, I have stuff mounted to them. Pretty certain the Milford won’t work with the bed rails? I thought the Milford could be attached to the bed rails as part of the install
  9. Sep 3, 2022 at 8:48 PM
    Aswongsc
    Aswongsc New Member
    I’m not sure how, it’s basically a C-clamp onto the bed sides.
  10. Sep 4, 2022 at 4:31 AM
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    You could lower the rails but it limits tie down strength and mounting options a little bit. I did it though.
  11. Sep 5, 2022 at 9:54 AM
    Tundra18overland
    Jesse
    GA
    got pics of the milford mounted?
