Would you trust your 2000 Tundra to pull a 4-5000 lb camper
Discussion in 'New Member Introductions' started by Tom H, Jul 16, 2022.
  1. Jul 16, 2022 at 3:20 PM
    Tom H
    Tom H [OP] New Member
    Tom
    2000 Toyota Tundra TRD
    We are original owners of a 2000 Tundra TRD sr5 with 80,000 miles. We have wanted to buy a camper about 4-5000 lbs. Would you guys trust the Tundra hauling that much weight?
    Thanks,
    Tom
  2. Jul 16, 2022 at 3:31 PM
    Retired...finally
    What's your owners manual state? Do you mean towing? Are you in the rust belt with possible frame rusting beyond surface rust?
  3. Jul 16, 2022 at 3:50 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    How far are you towing? Mountains or flat land? The 4.7 is more than capable of pulling 5000lbs
    You’re gonna be towing in 3rd gear, so you won’t be flying down the road like everyone tows today in their turbo diesels, but who cares 60mph is safer anyway
    WBW likes this.
  4. Jul 16, 2022 at 4:03 PM
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    Any chance that you could take it for a test drive? Just because some of us have towed heavy it'll be you that has to be happy with it. Seems to me that it's the kind of purchase that you would want to take for spin, to make sure everything is kosher, before signing paperwork.
  5. Jul 17, 2022 at 5:55 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! You also might want to check the weight ratings on your door sticker.
  6. Jul 18, 2022 at 6:37 AM
    Tom H
    Tom
    Toyota gave us a new frame nine years ago.
  7. Jul 18, 2022 at 6:52 AM
    Welcome from NY.
  8. Jul 18, 2022 at 6:54 AM
    Can you? Yes you can. Should you? If you’re starting with a 4-5000# camper, you should be able to tow that and keep it within the numbers if that matters. I towed a larger camper than that with my 2000 for years. It’s possible and capable. Your setup and comfort zone may vary.
    Tom H[OP] likes this.
  9. Jul 18, 2022 at 7:56 AM
    Retired...finally
    That's a good start. Now you need to find out what the towing capacity of your particular truck is. Not familiar with that year but usually the towing capacity depends on what engine you have and if your truck came equipped with a towing package. Also do you have a trailer brake controller.
    https://towingcap.com/toyota/tundra/2000/
    Tom H[QUOTED][OP] likes this.
  10. Jul 18, 2022 at 9:41 AM
    tdm850
    tdm850 New Member
    2021 Toyota Tundra
    I had a 2003 limited 4x4 4.7 my dad had it before me and he had a 7200 pound travel trailer. He would pull it from California to Florida many times it did just fine not a power house up the hills put would pull down the interstate at speed. When I got it I had a 4700 pound trailer it would pull it even better less weight right. I could run down the interstate at 60 I took it for California to Oregon and got 10 mpg. Going up the passes about 50 miles an hour but that's at have throttle I take it easy on my equipment. Truck had 176,000 miles on it air bags I would run 50psi in them. The trailer matters my trailer was balanced really well and towed like it was on rails.
