Offroad Limo
Discussion in '2nd Gen Builds (2007-2013)' started by JRS, Jul 18, 2022.
  1. Jul 18, 2022 at 7:33 AM
    JRS
    JRS [OP] New Member
    2012 DCLB
    Bought the truck early 2019 as a personal work vehicle. Took some time to find, but was able to get a WT model with a long bed. It remained stock for three years through countless projects before we decided to dual purpose and begin using it for more family fun. I'm also the type that will invest 10x time and effort on something to DIY rather than buy and bolt on.
    Will keep an updated pic and list here:
    Suspension and wheels:
    • Black Rhino - Rapid
    • Ridge Grapplers 37-12.5 R17
    • Eibach coilovers 2.0
    • SPC uppers
    • Deaver U748
    • Energy Suspension bushings
    • Toytec shackles
    • Durobumps
    • Bison stop cam kit
    Armor:
    Cabin:
    Brakes:
    • Powder coated with EBC Orange HD pads and OEM rotors
    Accessories:
    • Softopper
    • Hewitt SAIS delete kit
    • Remote start
    • Seat jackers
  2. Jul 18, 2022 at 7:39 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Very cool! In for updates!
    JRS[OP] likes this.
  3. Jul 18, 2022 at 7:39 AM
    JRS
    JRS [OP] New Member
    2012 DCLB
    Powder coating is extremely DIYable. Everyone knows red brakes work better.
  4. Jul 18, 2022 at 7:48 AM
    JRS
    JRS [OP] New Member
    2012 DCLB
    Can't stress how nice wrapping the steering wheel is. I opted for no perforations.
    Another member posted a link to East Detailing. By no means am I an affiliate type of dude, but they email a 10% off link. Putting it here in the event someone tries it and it works. If it doesn't, let me know and I'll remove the code.
    576051
  5. Jul 18, 2022 at 7:53 AM
    JRS
    JRS [OP] New Member
    2012 DCLB
    Will drop a few trail pictures along the way too.
  6. Aug 20, 2022 at 11:14 PM
    Hotwire
    Hotwire New Member
    Montana
    2008 Tundra SR5 double cab
    Nice truck! Following
    JRS[OP] likes this.
  7. Oct 1, 2022 at 9:44 AM
    msikk
    msikk New Member
    Sweet ride! Caliper powder coat looks great.
    JRS[OP] likes this.
  8. Oct 1, 2022 at 10:36 AM
    JRS
    JRS [OP] New Member
    2012 DCLB
    Took a cool pic this morning with the rear stuffed and the front at full droop. Also tested ATRAC for the first time by floating both a front and rear.
  9. Mar 2, 2023 at 5:42 PM
    JRS
    JRS [OP] New Member
    2012 DCLB
    Swapped the driver side front diff needle bearing for the ECGS bushing.
    Black@Blue19 and e30cabrio like this.
  10. Mar 2, 2023 at 5:45 PM
    JRS
    JRS [OP] New Member
    2012 DCLB
    Rebooted the halfshafts. Pic is showing OEM v CVJ silicone inner and ORS outer.
  11. Dec 9, 2024 at 6:36 AM
    JRS
    JRS [OP] New Member
    2012 DCLB
    Needed to upgrade the rear in prep for a travel trailer.
    New v old:
    "Customized" the Toytec shackles. They apparently didn't R&D these. When used in the closer position they strike some bolts in the bed.
    You're an absolute unit of a man if you can get Energy Suspension bushings into the double wrapped eye of Deaver U748s. I'm not and had to press them in. All others were easy with hand force.
    Install pic the next morning with light. Things need to be buttoned up and torqued.
    Rake rake rake.
  12. Feb 17, 2025 at 8:49 AM
    JRS
    JRS [OP] New Member
    2012 DCLB
    Should've upgrade the headlamps 6yrs ago. Did the tails to make the rear match this decade. Boost Auto tow mirrors for the new camper.
    No, 3M's 2080 satin dark gray doesn't match. Had some leftover so gave it a shot. Will swap over to the Oracal 970RA-937.
  13. Mar 8, 2025 at 7:06 PM
    JRS
    JRS [OP] New Member
    2012 DCLB
    Took this 35 footer for its maiden tow straight to the CAT scales. The 37s are squishy. Going to pull it with OEMs before making the call on purchasing a second set of wheels. Went with the ProPride WDH. First setup was good but still need to tweak a bit.
  14. Mar 24, 2025 at 9:56 AM
    JRS
    JRS [OP] New Member
    2012 DCLB
    Towing update: took the TT for its first interstate drive yesterday and had moderate winds around 13-15MPH. Using the Propride hitch was great. Still getting used to dragging something this big, but the winds didn't introduce sway as the two were jolted as a unit.
    Had put the sway bar back on and aired up to 48PSI. Big improvement in handling/feel when towing, although I prefer the bar off for normal driving. Too bad these weren't like Jeeps with an electronic sway bar disconnect.
    Ambient was 75degF and trans pan/converter, oil and coolant all stayed in check. Everything remained sub 200degF except for the converter when under load and unlocked.
