  1. Jul 15, 2022 at 2:08 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Very expensive and hard-ish to master. But if you are doing blackout or bumpers or sliders and want a factory look and durability out of the can....
    I've been using it for some time, after trying every other plasti-dip recommendation. I just did my sliders after POR15, and then trying to check the look of Duracoat-18 to match my lid in a dark grey. The textured Duracoat is awesome for bedliner. Great textured base with smooth over. But, smooth on smooth steel - forget it. I sanded lightly the lameness I rolled on those sliders as a test and sprayed the Raptor 2K. Perfect.
    https://www.amazon.com/dp/B07GNWRX2H?ref=ppx_yo2ov_dt_b_product_details
    Sunnier, RUSTYNUTS and KNABORES like this.
  2. Jul 15, 2022 at 6:18 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    j/k flip flops? Is that when you roll a jeep down the side of a mountain?
    KK6PD and Jack McCarthy[QUOTED] like this.
  3. Jul 15, 2022 at 6:21 PM
    NUDRAT
    SW CT
    Wouldn't this keep the lights on when he's trying to sleep in the bed?
  4. Jul 15, 2022 at 6:27 PM
    Well then we’ll have to add a motion sensor as well and write a detection algorithm so that it won’t trigger if he rolls over on his sleep.
    Maybe a 5g/Wi-Fi connection for algorithm updates?
    Amazing how a light switch can get complicated. haha
    Sunnier and NUDRAT[QUOTED][OP] like this.
  5. Jul 15, 2022 at 6:31 PM
    :devil: That’s just evil.
    NUDRAT[QUOTED][OP] likes this.
  6. Jul 15, 2022 at 8:18 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    I got you bro. LETS :deadhorse:It's actually pretty simple with the right switches
    Untitled.jpg LED - off. Change the position of either switch and LED - on
    If you dont like that roller switch, any SPDT momentary switch that you can get your tailgate to actuate, will work
  7. Jul 15, 2022 at 8:52 PM
    daveeasa
    Ok, advice time.
    wife and kids leave tomorrow morning. I am driving up to meet them on Wednesday. I have to work Monday and Tuesday. So I’ll have some time at night and also Sunday, though I have to drive on Sunday to see the bro in law and take him to the airport.
    I sliced off 2-3mm of my left index finger today trying to triple task and not being careful.
    I really want to get cruise control done on the ‘05. I think that’s #1. From there I could do either of
    1. Dual battery install on 2016 (I believe I have all parts to make this work)
    2. Steering wheel swap on 2005 to add audio controls (pairs well with adding cruise but I have zero idea if I need to swap the clock spring and/or what extras I need to add from there. I do have 2 open connectors on the back of the stock radio. Probably wouldn’t finish this one but a leather wheel could be nice.
    3. Bedside molle panels on the 2005 (seems straightforward since I had them on the 2016 already)
    4. Replace weatherstrip on bakflip on the 2005 (the truck is going to be in the PNW for a while so weatherproofing it makes a lot of sense.
    5. LED bulbs in front / rear on the 2005 (have them for the Tundra)
    6. LED bulbs in the chmsl
    I could also pursue lighting in the shell in the 2016 but ideally that is going to come from the aux battery or Switch-Pros. I have a bunch of kits for that stuff.
    Man it’s tough to prioritize. And hard to know if I should attempt a wheel swap. I think it might be possible to swap the wheel without the audio controls and not have to replace the airbag cover. But not sure how well that all lines up.
    Also sounds like the wife really wants baseboard done in the master vanity.
    it’s so hard to prioritize.
  8. Jul 15, 2022 at 10:03 PM
    KK6PD
    KK6PD 2 1 yr. retired . . . after 42 yrs
    ROAD
    Upper Los Angeles Foothills
    2003 AC Tundra . . . . 7th owner
    New Tires, Stereo & Speakers,Uni-Strut Tie Down Continue watching THIS SPACE FOR FUTURE DEVELOPMENTS
    This looks familiar! I would use a waterproof switch for the tailgate, S1 is a great choice! Simple, and no Raspberry Pi needed!
    Although I still like Pi!
  9. Jul 16, 2022 at 8:37 AM
    Sunnier
    Sunny
    San Diego, CA
    I know you for a few recommendations. Please share which this was, for the benefit of the rest of us that are SD area.
  10. Jul 16, 2022 at 8:49 AM
    Sunnier
    Sunny
    San Diego, CA
    Well, Hmmn. Typically, getting the wife’s baseboards done earns you the most time to work on your projects without getting nagged, once she gets back. And that’ll take less time without others in the way house. Plus, you will still have high incentive to do all the truck projects, whereas that baseboard project is never going to have more allure. I’d knock that out and buy yourself the freedom to get back to what you wanna do.
    But that’s more saw work; be careful!
    RUSTYNUTS and shifty` like this.
  11. Jul 16, 2022 at 8:55 AM
    Sunnier
    Sunny
    San Diego, CA
    PSA: just because you have the accessory in hand, does not mean you have to install it. :wink:
  12. Jul 16, 2022 at 10:12 AM
    daveeasa
    Tis true. Gonna focus on cruise as that's the most time critical right now and may require assistance. Thanks for the advice/guidance. I do likely need to get baseboard dealt with but that can also happen in the afternoon/evening since most of that is likely indoor or close to the garage in the driveway.
    alb1k and Sunnier like this.
  13. Jul 16, 2022 at 10:20 AM
    I think this motto is part of the reason I never get anything done. :D
  14. Jul 16, 2022 at 10:50 AM
    alb1k
    Left Coast
    It's good
    Haha! Vey true.
    RUSTYNUTS and Sunnier[QUOTED] like this.
  15. Jul 16, 2022 at 10:52 AM
    Sunnier
    Sunny
    San Diego, CA
    :fistbump:
    Ha! Same.
  16. Jul 16, 2022 at 12:36 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Saw a black truck like mine for sale by the side of the road, so of course I had to check it out...
    2003, V6, 5 spd manual, 2wd, base package (steelie wheels, no fogs, etc.). 210,000 mi. NO RUST (I crawled underneath to confirm). Otherwise very clean and detailed.
    It's a crazy world we live in...$7,900
    shifty` and Jack McCarthy like this.
  17. Jul 16, 2022 at 2:37 PM
    Sunnier
    Sunny
    San Diego, CA
    alb1k and des2mtn like this.
  18. Jul 16, 2022 at 2:38 PM
    Sunnier
    Sunny
    San Diego, CA
    Oh. I also got my whip. :rolleyes:
  19. Jul 16, 2022 at 2:52 PM
    daveeasa
    Got my cruise in and currently using it. Park at sac, haul horses, Uber pet, fly to sac on Wednesday to finish the drive.
    334730C3-1689-4160-858C-4D3DC9A6C2D6.jpg 19E8F637-015A-4134-A04E-A1A5D7B74D9B.jpg
    5N0W808 and alb1k like this.
  20. Jul 16, 2022 at 2:58 PM
    Sunnier
    Sunny
    San Diego, CA
    I wondered. I just got home. Gonna unload the BFT (paid off btw, 2017, fewer than 35k miles), then wash up to unwrap presents. :)
    des2mtn and alb1k[QUOTED] like this.
  21. Jul 16, 2022 at 3:14 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    What did I miss? :(
    RUSTYNUTS and NUDRAT[OP] like this.
  22. Jul 16, 2022 at 3:58 PM
    NUDRAT
    SW CT
    @Tundra2
    time for updates, with pictures - lots of pictures.
  23. Jul 16, 2022 at 4:02 PM
    Sunnier
    Sunny
    San Diego, CA
    This is Steve from Blues Clues doing the “mail time” song, me communicating my great excitement to someone likely to have memorized every episode. ;)
  24. Jul 16, 2022 at 4:18 PM
    The mountains have been calling and we finally went today. I wish I could live up there. Spent the day swimming and taking our $5 Target float down the rapids.
    We passed two of these guys on the way. Each guy was driving a beat up 1st gen Taco with a bed full of parts and a even more beat up Toyota Pickup in tow. Seems like a lot for those Taco's to tow.
    alb1k, KK6PD, RUSTYNUTS and 4 others like this.
  25. Jul 16, 2022 at 4:23 PM
    Would someone please explaining what kind of tire/wheel ritual is going on here?
    RUSTYNUTS and FrenchToasty like this.
  26. Jul 16, 2022 at 4:38 PM
    Sunnier
    Sunny
    San Diego, CA
    Trying to minimize sun damage. Around here we mostly see it for RV’s that sit in one place for months on end, direct sun exposure on one side only.
  27. Jul 16, 2022 at 4:47 PM
    This is New England and it was on both sides of the car. Sun damage around here is minimal.
  28. Jul 16, 2022 at 4:48 PM
    Sunnier
    Sunny
    San Diego, CA
    Can’t tell you then.
  29. Jul 16, 2022 at 4:50 PM
    NUDRAT
    SW CT
    I'm going with they were / are ceramic coating the paint & didn't want to get anything on the tires/rims.
  30. Jul 16, 2022 at 4:50 PM
    I assume drugs are involved, or maybe cats…..
    RUSTYNUTS, shifty`, KNABORES and 2 others like this.
