Wheel bearings squeaking
Discussion in 'Performance and Tuning' started by RNDABOUT, Jul 14, 2022.
  1. Jul 14, 2022 at 6:19 AM
    RNDABOUT
    RNDABOUT [OP] New Member
    17 Quicksand TRD Off-road
    Hiya gang.
    2017 offf road DC 6.5.
    My front bearings are squeaking/ squealing. I don't think they should be. I didn't have this issue on my 2002.
    35's on18's no lift.
    Looking to upgrade bearings. Suggestions?
    TIA
  2. Jul 14, 2022 at 9:30 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Stock is fine and should be reliable and long lasting. sure it is bearings and not brakes? How many miles on your truck? What wheels/offset are you running? How do you use your truck? Any offroading in mud, sand or water?
  3. Jul 15, 2022 at 6:57 AM
    RNDABOUT
    Doesnt seem logical with only
    80k km (50k miles), Right?
    All my brakes just redone, i have stock TRD rims with 35 Toyo AT3s. No spacers or offset change. I just remolded the plastic mudflaps to fit the tires.
    All I can think to attribute bearings wearing prematurely is consistent curb hoping and puddle jumping.
  4. Jul 15, 2022 at 7:07 AM
    frichco228
    Frank
    Virginia
    Those big 35s put a lot more stress on a half ton truck than 32 inchers. Guessing you also moved to lower offset rim or wheel spacers which also increase stress on the bearings. And then of course there is use, so off road, running in mud/sand/water, driving fast in corners with big tires all put additional stress on the bearings. If you purchased the truck used, no telling what the previous owner did or how they used the truck.
    But yes, needing wheel bearings at 50k miles seems premature.
  5. Jul 15, 2022 at 7:26 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Does it have OEM in it?
    I believe the recommended brand is Koyo and luckily they aren't too hard to find (not limited to paying inflated dealer pricing)
    RNDABOUT[OP] likes this.
  6. Jul 15, 2022 at 7:45 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Since you got your brakes recently serviced I'd check if the brake dust shields are touching something.
