Coachbuilder Rear Brake/ABS Relocation Kit
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2point5seconds, Jul 13, 2022.
  1. Jul 13, 2022 at 10:50 AM
    2point5seconds
    2point5seconds [OP] Wish I didn't have so much money
    Sensei
    Nor Cal
    2019 Tundra SR5 TRD 4WD Double Cab
    Icon Stage 9 lift, 700 pound rated Eibach spring, Sumo Springs (rear), RCI engine skid plate. RCI Lower Control Arm Skid Plates, RCI Transmission Skid Plate, RCI Cat Guards, Rago dash plate. RAM phone holder. Bed rails. Tint. 17x8 Icon Rebound wheels. 315/70/r17 Falken Wildpeaks. AAC Trigger 6 Shooter, midland MTX-115 radio, Chassis Unlimited front bumper, OLB Bar light and ditch lights, Baja Fog lights, Smittybilt winch, Husky floor liners, bed rail, Cali Raised Bed Stiffeners, driver's side grab handle, Wheeler's Offroad front bump stops, Decked Tool Box
    2019 Tundra 5.7l SR5 TRD 4WD DC
    Stage 9 Icon Lift with Full RTX leaf Springs (option 3). Eibach 700 pound springs in front to keep lifted up from the heavy fab bumper. Maxed out in front.
    I noticed a couple of weekends ago that the shop that did my lift, left my brake line just hanging without bolting it back down to the rear differential. So, I'm guessing for the last year and a half, it's been like that. I also am missing a bracket to hold the ABS lines onto the rear differential. Spoke to Toyota and after a week, they found it and said it'll be 200+ bucks because it comes with some sensor. Time to look at junk yards...
    Anyways, my question is with the 3" lift I have with the Icon Stage 9, will this Coachbuilder Brake/ABS relocaton Kit be long enough to support any flexing that the differential may run into when I go offroad? I don't do any rock crawling, but there were a couple of times I had to ride one side of that mountain road and flexed pretty good.
    https://www.boss4x4.com/product-p/cb8-bk.htm
    I was initially going to replace the two rear center brake lines that bolt to the rear differential with longer ones to account for any flexing or dropping. But the Coacbuilder kit is alot cheaper.
    Anyone have experience with going off road with the Coachbuilder kit? or would you recommend changing out the rear center brake lines with longer ones so it could still be bolted to the rear differential and have some slack?
    Thanks!
  2. Jul 13, 2022 at 10:53 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    2point5seconds[OP] likes this.
  3. Jul 13, 2022 at 10:59 AM
    2point5seconds
    Sensei
    Nor Cal
    yeah. Those were the brake lines I was looking at if I went that route. It just got expensive with labor at the shop. they'd have to replace brake lines, bleed the lines and add new fluid. I've read in another threat that it was easy to do, but I've never bled the system all the way. I've changed out brake pads and rotors and had to pump the brakes to get the air out, but that's about it. They said it was easy though....
  4. Jul 13, 2022 at 11:02 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yea it's not too difficult at all. Plenty of upsides to doing the lines over the bracket but up to you.
  5. Jul 13, 2022 at 11:21 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
  6. Jul 13, 2022 at 11:21 AM
    Tundyfundy
    Bay Area, CA
  7. Jul 14, 2022 at 2:27 PM
    2point5seconds
    Sensei
    Nor Cal
    Yeah. I called and spoke to him. He is hecka nice. He asked me to raise the rear and let the rear differential drop. Measure how much the rear shocks dropped and see how much space is between the bottom of the brake line and the bracket on the rear differential. The rear shocks dropped about 15.5 inches. And there was about 2-2.5 inches of space between the brake line and bracket. he said it should work. Their kit allows 2.25 inches.
    I also spoke to Boss 4x4 and they thought that it would work also.
    So I'm going the cheaper route first. install it and test it out on some back roads to try and make it flex. See if I have some slack in the lines.
    David gave me an pretty cool explanation about the rear differential that I never thought of before. he said it's like a see-saw. The pumpkin in the middle of the differential is the middle of the see-saw that really doesn't go anywhere. Only the outside where the tires are will drop. The middle doesn't move much. I'm no mechanic (but I want to be on when I grow up), but sounds right.
    I also am running Sumo Springs as my Bump Stops in the rear. So that's a few inches taller than stock bump stop. And a lot more solid. I'm hoping that'll prevent it from dropping too low when flexing.
    reywcms likes this.
