2018 Revving when shifting into 1st gear
Discussion in '2.5 Gen Tundras (2014-2021)' started by bigraz, Jul 11, 2022.
  1. Jul 11, 2022 at 9:04 AM
    bigraz
    bigraz [OP] New Member
    I have a 2018 tundra trd offroad with 23k or so on it. I have noticed lately that sometimes it revs to 2k before shifting into first and this happens while moving slow or stopped,there is no clunking or jumping into gear just the higher revs. Doesn't do it all the time which makes it more strange to me and if you let off the throttle and re apply it stills needs to rev before the shift occurs.I dont think taking it to the dealer would do anything besides having them drive it and say they "nothing wrong"
    Has anyone else had similar issues and if so can anything be done to eliminate this? Maybe a pedal commander or banks product?
  2. Jul 11, 2022 at 8:13 PM
    Sierra_Nevada
    Sierra_Nevada New Member
    Kansas City
    2020 Magnetic Gray Platinum
    TRD Pro Fox Suspension, SCS Ray 10 Wheels, BFG KO2 275/70 R18
    I had similar issues in a Ford F150 and the dealer flashed the computer and corrected it. I don't know if it would be the same in a Tundra, but it was a quick reprogram in the Ford.
  3. Jul 13, 2022 at 8:09 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    cold start will always have higher rpms. Suggest you check for clean air filter and maybe clean the MAF.
  4. Jul 13, 2022 at 10:12 AM
    Pbed85
    Pbed85 New Member
    Pete
    MN
    2019 dbl cab limited cement
    Mine seems to do this right after leaving my house when taking a right turn. Revs higher then shifts into 2nd I believe. Also doesn't like to shift into 6th if I jump on the highway soon after starting
  5. Jul 13, 2022 at 10:27 AM
    ATF has to warm up first before normal trans operation. Even my old 2000 does this.
  6. Jul 14, 2022 at 1:07 AM
    CMikeB
    CMikeB New Member
    When creeping along, leaving my neighborhood, I'm locked into 3rd then 4th gear till I get to the road. Trans has a chance to reach some semblance of correct temp, instead of lugging into high gears before it's ready. I haven't driven my truck in 'D' in 12 years:D
  7. Jul 14, 2022 at 7:30 AM
    TRDBurglar
    TRDBurglar New Member
    Slidell, LA
    2016 TRD Crewmax
    Level kit, Method MR316 wheels, 295/70R-18 FALKEN WILDPEAK A/T3W, BAK Revolver X4s tonneau, RB20s
    I've had 4 toyotas that do the second gear high-rev thing, I think it is a cold engine/emissions thing.
  8. Jul 14, 2022 at 8:37 AM
    bigraz
    I doesn't only do it when the engine is cold.I have had the issue when the truck has been driven and warm but it doesn't do it all the time...it's strange
