Power rear window 05 stepside
Discussion in '1st Gen Tundras (2000-2006)' started by Jfred88, Jul 13, 2022.
  1. Jul 13, 2022 at 11:15 AM
    Jfred88
    Jfred88 [OP] New Member
    05tundrastepside
    None
    Does anyone have procedure/detailed to replace no power rear window in 05 access cab with a power (roll up/down) full rear window? What components are required to complete the exchange?Thanks jfred
  2. Jul 13, 2022 at 11:17 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Yes, sell the access cab and buy a double cab instead, since those came with them from the factory.
    This post is brought to you by the roll-down back window gang.
  3. Jul 13, 2022 at 11:23 AM
    @des2mtn might sound like he's joking, but he's not.
    Access Cabs didn't come with full up/down window. The cab size and window sizes are totally different. Access Cab and Regular share a lot of commonalities. Double Cab is a totally different beast.
    Same is true for the moonroof, and the larger overhead console with temperature and compass.
    FrenchToasty and des2mtn like this.
  4. Jul 13, 2022 at 11:30 AM
    des2mtn
    Shady Grove
    Tonto cover
    Yep. This isn't something that can't be done cheap or easily. For the amount of time and money you'd spend trying to do something custom that not even work, you'd be better off buying a whole 'nother truck all together which you know will work.
  5. Jul 13, 2022 at 1:19 PM
    Jfred88
    05tundrastepside
    None
    Thanks. That’s what I was thinking. I just liked the stepside better. Think I will pass on doing the change. thanks. jfred
  6. Jul 13, 2022 at 2:20 PM
    I was waiting to hear “challenge accepted!”. Guess not. o_O
