Semi-affordable 1st gen upgrades
Discussion in '1st Gen Tundras (2000-2006)' started by Vinny22, Jul 12, 2022.
  1. Jul 12, 2022 at 7:34 PM
    Vinny22
    Vinny22 [OP] New Member
    Kelvin
    Hello, I recently bought a 2003 white tundra that is 100% stock. This is my first truck and im excited to start adding some aftermarket items. What recommendations do you guys have for a semi-affordable route to wheels & tires, stereo system, soft shell bed cover, and anything else y'all have found you really like?
    YardBird likes this.
  2. Jul 12, 2022 at 7:44 PM
    First things first, before you put any money in it, (a) when was the last time the timing belt was replaced and (b) how bad is the frame rusted, because some people's frames have literally cracked?
    Also, what engine? What cab type access/regular/double? And is it 2WD or 4WD? All of these things will determine what people may tell you.
  3. Jul 12, 2022 at 7:58 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Full inspection. Check all the naughty bits underneath. Pull the wheels and skidplate, check brakes & steering components, if 4wd grease the driveshaft, adjust the parking brake...
    then, we can tell you to put a bracket lift on the front, lowering blocks on the back, and 235/35r24's and 8" of wheel spacers.
  4. Jul 12, 2022 at 8:01 PM
    Vinny22
    Kelvin
    Timing belt was changed recently, rust is in good shape (still there but just sprayed some anti rust on it). 4.7L V8, access cab, 4wd
    des2mtn likes this.
  5. Jul 12, 2022 at 8:07 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Congrats on the truck. I agree with the above. Get the basic maintenance out of the way. When you do start modding, make informed purchases and don't just buy stuff on impulse.
    As for cheap and proven mods though, a lot of other Toyota wheels fit with little to no work and can be found for cheap. LED dash light / climate control light conversion is a mod I'm glad did. Writeups can be found if you search within this sub-forum.
    But yeah, maintenance
    805Tundra, DarkMint and FrenchToasty like this.
  6. Jul 12, 2022 at 8:12 PM
    And slabs
    shifty` likes this.
  7. Jul 12, 2022 at 8:36 PM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
  8. Jul 12, 2022 at 11:23 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  9. Jul 12, 2022 at 11:25 PM
    des2mtn
    SW
    Tonto cover
    Coronado ain't affordable, get outta' here! :rofl:
  10. Jul 12, 2022 at 11:34 PM
    YardBird
    Jonesy
    2005 RCLB
    Well, providing a garage for the Tundra wasn't exactly affordable ~ even 30+ years ago.
    The Tundra was "On Sale" in the used market some 13 years ago when I purchased it from the original owner ~ a Toyota Parts Man.
    He did the upgrade to the "Limited" alloy wheels and tires, bed mat and aftermarket exhaust. I put a Retrax Pro tonneau cover on it to keep my Big Box store purchases from flying away.
    The Tundra is a "Work Truck" and not the Limited or SR-5 but it's the nicest vehicle I've ever owned.
    des2mtn
    des2mtn likes this.
  11. Jul 13, 2022 at 6:52 AM
    Definitely this point. And look at every page in this thread to find pics of what you like, share w/us. Then go here for radio stuff.
    Some thoughts on what you can expect, price-wise:
    • Basic "Stage 1" lift: $800-1,200 (avoid the Rough Country garbage, seriously)
    • Better "Stage 2" lift: $1,800-$3,300
    • New tires (alone): $800-$1,400
    • Wheels (alone): $800-$2,000
    • Camper or bed cover: $200-$1,500 (soft folding cover at low end, hard cover/topper at high)
    • Stereo (w/spkrs): $600-1,200 (go to Crutchfield so you get all adapters free, DO NOT CUT OEM harness!)
    • Dashcam: $100-350
    • Fancy rearview mirror: $75-300
    • Headlights: $200-1,200 (note: LED headlights can cause plenty of other problems)
    There's definitely a lot of other stuff you can do, but I guess these are the big cosmetic and performance improvement
    Sometimes you can find good deals in the Gen 1 marketplace here, on FB marketplace, OfferUp, Craigslist, etc. Like, I've seen hardshell camper tops go for as low as $200, but you gotta understand there are three different bed lengths for these trucks between the Regular Cab long bed, Regular and Access Cab standard bed, and the Double Cab - none of those three are cleanly interchangeable. Good deals on and wheels are there too, but save a headache and learn about wheel backspace and offset first.
  12. Jul 13, 2022 at 6:58 AM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Easiest and cheapest mods I've done are swapping blinker lights to LEDs, rear differential breather mod, defrost setting AC toggle mod (disconnect 2 wires behind control bezel), tiny footwell light LED replacement, glove box tiny LED replacement.
    AR 02 TUNDRA likes this.
  13. Jul 13, 2022 at 7:05 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I came in all gung-ho about modifying my truck. And after the maintenence, and a few road trips paying close attention to what i really need, and what can get kicked down the line, i've saved a ton of money by keeping it stock.
  14. Jul 13, 2022 at 7:16 AM
    Yup. I'd probably put myself in the "OEM+" camp, only minor tweaky upgrades.
    I feel like people who start threads like this or more in it for appearance mods than anything, but maybe I'm wrong.
    For me, I like the appearance of these trucks stock, or stock with small suspension/wheel/tire tweaks. The only lacking has been the dated technology of that era.
  15. Jul 13, 2022 at 7:58 AM
    Teutonics
    Teutonics BestGen Member
    2005 DC SR5 4WD
    I'll second the "easy upgrades"... LED brake lights (including 3rd brake light on cab) and interior overhead lights, stereo (double DIN with touchscreen and Carplay/Android Auto really seems to modernize the dash), Bilstein 5100 shocks/"lift", Weathertech floor mats. I might throw in seat cover refresh (if needed... katskinz for better than original or lseats.com for budget recover) and window tint too.
    AR 02 TUNDRA and FrenchToasty like this.
  16. Apr 30, 2023 at 12:41 PM
    ALMDawgfan
    ALMDawgfan New Member
    2004 Tundra 4WD Access Cab
    Hi guy... Fancy meeting you here?
    Trying to re do the Headlight/turn signals on my Gen 1.... OEM prices (Thank you ever so much for the tutorial) nearly gave me a nose bleed. My last replacements. TYC from rockauto, lasted about 5 years (give or take)... They simply got brittle over time. Now, given the price it might be a case of repeat every 5 years as needed, but having seen what those on the Forum can whip up I am interested in anything a step up... Most of the discounters are trotting out more of the same same replacements at slightly differing prices... Not better and best options...
  17. Apr 30, 2023 at 2:43 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Welcome to the club, Kelvin. It's no fun spending money on maintenance items, but your truck will thank you.
    pics when you can....:hattip:
    ALMDawgfan likes this.
  18. Apr 30, 2023 at 6:29 PM
    Longevity on your light housing depends on a wild array of things. Park out in the sun facing south all the time? They're going to oxidize and haze faster. Park indoors? They'll last longer. Drive on salt roads a lot? They're going to haze faster.
    TYC is typically on-par with Depo and Eagle Eyes, I think? I usually lean towards Depo, but have bought Eagle Eyes on other trucks. Get CAPA certified housings if you want some longevity. DEPO offers 5yr guarantee on their lens being clear and free of haze on their CAPA lights. It's usually less than 5-10% more for the CAPA version, if you can find it.
    As far as lighting upgrades ... need more info on what you want, and what you're willing to do.
    ALMDawgfan[QUOTED] likes this.
  19. May 1, 2023 at 7:22 AM
    bron-yr-aur
    bron-yr-aur New Member
    Ché Calvo
    Windber, PA
    2004 DC 4x4/Tow pckg
    Mods: zip-tied PS line and tire shine
    My son laughs at me because I’ve been able to blow the dust off my old cassettes and rock out to my 80’s/90’s collection lol. I will admit, though, that it’s killing me to not even have an aux Jack for my old iPod.
  20. May 1, 2023 at 7:37 AM
    Solid Snake
    Solid Snake The Anciet of Mu Mu
    West TN
    2006 AC 4x4 V8
    I got the GTA car kit which basically adds a bluetooth receiver to my stock radio. So I keep the original look, but can still stream my phone through my speakers.
  21. May 1, 2023 at 3:16 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
  22. May 1, 2023 at 5:38 PM
    abcinv and artsr2002[QUOTED] like this.
  23. May 1, 2023 at 8:36 PM
    Zoroaster
    Zoroaster New Member
    2002 LTD AC TRD
    My cheapest mod was taking the rear view off. LEDs f with my night vision
  24. May 2, 2023 at 7:30 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Not sure how I’ve missed this thread, cheap, easy, and effective mods are plentiful on this truck and one of my favorite things about them.
    My favorites include:
    Adjusting the LSPV (Load-Sensing-Proportioning-Valve) on the rear axle to increase rear brake bias
    Repainting my wheels to look brand new
    Repairing my OEM key fob
    Replacing PCV valve, cleaning throttle body, and cleaning MAF sensor
    Re-attaching my broken fuel filler door
    Removing rust and repainting various brackets & hardware
    Installing high quality new windshield wipers
    Replacing worn sway bar links
    And much, much more.
    Every one of these items on my list has made a significant improvement to the truck’s drivability and usability, as well as simply making it a more pleasant vehicle to drive. Every one has been worth every penny. You can check out my build thread if you want to see more. (not to toot my own horn)
    Durbin7, abcinv and ALMDawgfan like this.
  25. May 2, 2023 at 9:59 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I think if you just wanna do some light trailriding some real good insurance is going to be skidplates. I saw some stuff i'd have gone through, but was worried about my yankee mudflaps. With some plates and maybe sliders (and some 10 ply tires) i'd be much more comfortable following a random off road trail out in the desert.
  26. May 3, 2023 at 5:44 AM
    ALMDawgfan
    Sorry.... Employment had me a couple days.... I/m not much of a "Mods" type I just don't want to spend $4-$500 on a new Headlights set up. I will go with any that "LOOK" original but the TYC did disappoint. (I have to say at the price point I wasn't surprised at the haze inside 5 years but the mounting and adjusting plastic was another thing.) I would take DEPO if I can find them... (The name didn't come up in any Duckduck search) I am Familiar with CAPA standard for parts (Mostly for other body parts).
    At the moment I have looked seriously at "SPYDER" brand with a similar warranty to what you describe and claims as to light focus close to OEM.
  27. May 3, 2023 at 9:13 AM
    I've never heard of Spyder. I've used DEPO headlights the better part of 2 decades, ever since I was dabbling in the VW scene.
    Rockauto sells DEPO brand headlights. When I recently dropped the $220 to get H4 projectors installed on the truck, they only had CAPA certified housings for one side, so I was only able to get one. They were ~$84/ea and preloaded with all necessary bulbs, only to get them in, and butcher them by removing the interior reflector, so I could use the H4 projector bulbs.
    The one shitty thing about aftermarket is the adjusters. The OEM adjusters work like butter with a long philips head screwdriver, using the factory adjuster hole. Aftermarket housings, it's really hard to use a screwdriver and almost makes more sense to leave the blinker out, and adjust the levels with a wrench.
    I also have a near-new set of OEM housings I dropped $350 on before buying these. I just wasn't happy with the light output. The projectors don't broadcast as wide, and are as close to plug-and-play as you can get, but a marked improvement for in-town driving.
  28. May 3, 2023 at 9:49 AM
    ALMDawgfan
    I found Spyder by a general search for "four star and up" after market Tundra headlights... They are listed at CARiD.com... They price out about $150 but the shipping is stupid high...
    Found the DEPO's on Rockauto just now....
    The adjusters are factory patented so as to handicap sellers of aftermarket goods. I adjust headlight settings on new vehicles for my employer... We change existing light adjusters in compatible models simply for that purpose.
    I wish I had known as to the "Near News" That seems reasonable for the quality you get... I generally run Sylvania or Phillip's best in mine and call it good.... None of the aftermarkets I have used over the years focus the beams so well as Factory.... I put some LEDs in a Tacoma I drove for hunting. You could see The Goddess's bones if she walked in front of the truck with them on but they didn't shine as far down the road as did the regular bulbs...
  29. May 4, 2023 at 4:55 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    I too have this setup that also comes with 3.5 Aux. Works great!
  30. May 9, 2023 at 7:00 PM
    ALMDawgfan
    Heeellllooo!
    Installed a new set of Headlights and turn signals on the 2004 Tundra. Lights and signals all function per usual but I have no dash/kombi lights or tail lights... What gives?...
