towing in the mountains
Discussion in 'Towing & Hauling' started by justcuz, Jul 13, 2022.
  1. Jul 13, 2022 at 5:31 AM
    justcuz
    justcuz [OP] 2.5 Gen Member
    from what I understand most use tow haul mode when towing.
    do you leave the truck in drive?
    do you shift into a lower gear when going downhill?
  2. Jul 13, 2022 at 6:04 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    tow haul and using s4 vs drive will keep the trans locked up more, lower trans temps and reduce the trans from shifting all the time.
  3. Jul 13, 2022 at 6:27 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Towing in S4 will keep your transmission cooler even on flat ground. I used to tow in D until i added the temp gauge.
  4. Jul 13, 2022 at 7:12 AM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    I recommend any gear that keeps the rpm's about 2400. this could be s5 if doing 73mph.
    WBW likes this.
  5. Jul 13, 2022 at 7:17 AM
    18" TRD Off Road Wheels
    Yup. And don't use cruise control. It basically overrides what Tow/Haul is doing. Your owner manual should say the recommended method is towing in D and using S4 for downhills to keep the batteries charged etc. Best thing you can do when towing is leave early and drive slower. If you can cruise along at 60-65 MPH that seems to be the sweet spot in my experience. Better MPGs and a pretty easy tow experience.
  6. Jul 13, 2022 at 7:27 AM
    What are you towing? What kind of temperature differences are you seeing between using D/TH and s4/TH?
  7. Jul 13, 2022 at 4:37 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Scale says travel trailer weighs 4300. Only pulled it on 2 trips with the scan gauge. In D at 70mph it will run 212 on flat ground but climbs to 230 fast with the smallest incline.
    in s4 it will stay 203-204 no matter what. I have not hit a massive grade yet though with it.
    Interestingly enough i did just drive socal-black hills-montana yellowstone-home. Lots of grades. Even without towing S4 keeps the trans pegged at 203 regardless of grade at 85mph. In D it rose to 240
  8. Jul 13, 2022 at 4:42 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    TH mode with any trailer. S4 on anything that might require a down shift in normal driving. So unless I’m on highway its s4. If on highway with steady throttle s5. Eliminating shifts and keeping torque converter locked are the keys to keeping a happy transmission.
  9. Jul 13, 2022 at 7:27 PM
    Wow. With the SG, can you tell if the converter is locked or not? (Do you have the new one?)
    That is really weird to me. The hottest I have ever seen my Allison is 200*. Mostly it hangs 50-60* over ambient temps at max GVWR.
    NWPirate likes this.
  10. Jul 13, 2022 at 7:45 PM
    ScenicRoute
    Allison is comparing apples and oranges as you know.
    I’m still dreaming for an Allison behind a Cummins in a ford chassis.
    edit: a 6 speed Allison. Not this stupid 10 speed nonsense.
  11. Jul 13, 2022 at 8:23 PM
    Aisin makes HD transmissions…that’s a fact. They just use different methods of cooling. Using engine coolant keeps the transmission pretty warm already.
  12. Jul 13, 2022 at 9:04 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    no i have the SG 2. Doesnt show if its locked or not. im pretty noise sensitive in hearing the engine while cruising(i know not scientific) however i think i can hear when it unlocks.
    city/highway unloaded driving is normal to see 203 temp in the transmission torque converter consistently. It basically will hang there at all time until it unlocks in overdrive. Mine has a cooler too. I can’t imagine how fast the 19-21 heats up
  13. Jul 14, 2022 at 4:46 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    On my '17 towing a 7800 lbs travel trailer, this has been my experience as well.
