2.5 gen bed on 2nd gen
Discussion in '2nd Gen Tundras (2007-2013)' started by Borgunit, Jul 13, 2022.
  1. Jul 13, 2022 at 5:38 AM
    Borgunit
    Borgunit [OP] New Member
    JR
    Ohio
    2013 Black Rock Warrior
    Question. Would a 2.5 gen bed fit on a 2nd gen? (Got my title messed up)
  2. Jul 13, 2022 at 6:09 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Yes Toyota made 3 bed lengths for these years. All crew cabs are 5.5Ft, Double Cab and Regular Cab can be 6.5 Ft or 8 Ft.
    I have a 2007 regular cab with a 6.5Ft bed and installed a 2017 bed from a double cab. It bolted right on, rear bumper is different and so is taillight wiring/ taillights. In the photo top is 2007 bed, bottom 2017 bed.
    The 2.5 Gen (2014-2021) was just a physical appearance refresh really. I haven’t seen a newer bed on an older crew max but I see no reason why it wouldn’t work.
    WFD473, Gaston, Borgunit[OP] and 7 others like this.
  3. Jul 13, 2022 at 6:14 AM
    Borgunit
    JR
    Ohio
    So you did a front and rear update. Interesting. Have you done a write up on the instructions and caveats of doing this? Kinda cool.
  4. Jul 13, 2022 at 6:23 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    I did the interior and dash also. Got a little carried away but after 2014 you couldn’t buy a regular cab short bed anymore so I decided to make my own 2018+ version.
    You can see the full build here, lots of pictures and write up. https://www.tundras.com/threads/the...014-conversion-front-clip-interior-bed.90281/
    Anything can be done if you have the funds and time. I don’t know that it’s practical to do the full conversion on 2007-2013 crew max and double cab trucks because you can just got buy one that way if it’s what you really want.
  5. Jul 20, 2022 at 3:27 AM
    Borgunit
    JR
    Ohio
    The writeup was phenomenal. Question, was everything on the bed swap plug and play? Lights, rear camera, hitch, locks? Wondering.
    Jeff_5_7 likes this.
  6. Jul 20, 2022 at 6:19 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    My truck didn’t have a rear camera but I added in the factory one. Taillight connectors are different and it’s kind of a pain to find the right one. I was luck my bed came with the newer style taillight harness. I have the 07 hitch on mine and the new style bumper bolted right to it.
    The taillight wiring is definitely the biggest hurdle.
  7. Aug 6, 2023 at 7:37 AM
    CharlesF
    CharlesF New Member
    Charles
    2010 double cab white Tundra 5.7
    None
    I have bed rot and was thinking of putting a Gen 3 backside on my Gen 2. What harness issue did you run into and was this just a matter of splicing in the wires? Will my existing bumper work ?I took your pictures and spliced them in and this is what it would look like. I don't think it looks too bad as I'm not trying to impress, just trying to get longevity. I do know I will not have that beautiful TRD Pro bed due to the cost and difficulty of finding one.
  8. Aug 6, 2023 at 2:17 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    I spliced the wiring together with the soldering iron and some heat shrink. The tailights have different style connectors.
    You will need the newer bumper also as the rear of the bed is different shaped. It’s bolt on
