  1. Jul 12, 2022 at 5:15 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
  2. Jul 12, 2022 at 5:17 PM
    Hell yeah, that dumps just about where mine does, probably further back. It might be a little rowdy depending on the muffs you got, or at least with the gates open it will hahah
  3. Jul 12, 2022 at 5:18 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Someone knows how to hang a spare so you can check its pressure.
    NUDRAT[OP] likes this.
  4. Jul 12, 2022 at 5:18 PM
    empty_lord
    05 rollover special
    Indeed
    Sunnier and NUDRAT[OP] like this.
  5. Jul 12, 2022 at 5:19 PM
    empty_lord
    05 rollover special
    It’s still got decent rumble with the valves closed. I’ve yet to hear them open.
  6. Jul 12, 2022 at 5:22 PM
    Have you driven it or just video clips of the noise?
    I almost think mine in quieter at highway speeds vs in town even when I’m easy on the throttle. It’s not terrible doing 65 @2k rpm inside the cab
  7. Jul 12, 2022 at 5:24 PM
    empty_lord
    05 rollover special
    Only video. I got get it Monday. It’s a 1 hour drive away and I work rest of the week while he’s open
  8. Jul 12, 2022 at 5:47 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I really hope people don't buy into that shit - but they will.
    5N0W808 likes this.
  9. Jul 12, 2022 at 6:30 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Dropped off the driveshaft yesterday and got it picked up today. It looks brand new. Labor was actually decently priced and the turnaround was amazing, but I'm still glad I attempted it myself first. They also painted and re-balanced the shaft - I can tell that a few weights have been removed/ moved around. In the past I've noticed a slight steering wheel vibration at times and I'm starting to wonder if this is going to make a difference. I've been attributing the vibration to a wheel in the front I know is bent, but we will see.
  10. Jul 12, 2022 at 6:39 PM
    Were they able to replace the slip yoke seal? I’ve not seen any shops that could. looks amazing. Ballpark cost?
  11. Jul 12, 2022 at 6:40 PM
    I know I should be commenting on the awesome exhaust, but did you undercoat the bed with a rust inhibitor? Maybe I should do that if I ever buy a new pickup in the future. Interesting.
  12. Jul 12, 2022 at 6:41 PM
    04 Tundra
    04 Tundra New Member
    Albert
    2004 Toyota Tundra 4x4 AC Limited
    DIFF Breather, Painted Rims, Interior Wrap, Tint,
    I have OME 855 spings on the way and JBA uppers. Where can i get the Coil spring isolators to fit onto my Bilstein 5100s ? I am in Canada so firstgenoffroad will not work for me. Anyone have a model number ?
  13. Jul 12, 2022 at 6:44 PM
    empty_lord
    05 rollover special
    It was a quick job mostly to hide the rust it had.. it was a $200 bed. I’ve got stuff I have to do to it and I’ll properly paint is a nice thick black.
  14. Jul 12, 2022 at 6:44 PM
    empty_lord
    05 rollover special
  15. Jul 12, 2022 at 7:00 PM
    des2mtn
    SW
    Tonto cover
    They did not, but I did not expect or ask them to. $80 to balance and $30 to remove/install both u-joints.
    They recommend leaving the double cardan alone.
  16. Jul 12, 2022 at 7:07 PM
    empty_lord
    05 rollover special
    I had to hunt far and wide to find someone to rebuild my Cardon on the taco
    des2mtn[QUOTED] likes this.
  17. Jul 12, 2022 at 7:12 PM
    des2mtn
    SW
    Tonto cover
    If mine goes, it'll be time for a Tom Woods driveshaft.
    Cummins3500 and 5N0W808 like this.
  18. Jul 12, 2022 at 8:33 PM
    My slip yoke doubles as a rust prevention formula slinger under the bed. I pump the grease in, it slings it out.
  19. Jul 12, 2022 at 9:10 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Just throwing this out for anyone even though I know most aren't local. Tempting for me to buy these seats but mine are in pretty good shape. Plus these are captains chairs. Guy apparently also has both front doors with door panels. May be of use to @Tundra2 but I know he's been taking a break from the truck stuff lately. In crestwood KY.
  20. Jul 12, 2022 at 9:35 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Most likely, yes.
    You may need to swap the ignitor for the airbag from the tacoma to the tundra airbag. So it matches the clock spring wiring.
    Iirc either 2nd or 3rd gen tacoma steering wheels are the same as the later year tundra ones. Good source for black switches and air bag covers. Same with 4th gen 4runner (if amber backlighting is wanted).
  21. Jul 12, 2022 at 10:10 PM
    daveeasa
    Yeah, I remember watching a video of a guy changing out his Tundra wheel for a 3G Tacoma one?
    These wheels for earlier gens, just a bit more trouble. I need to learn more about the innards.
    In the meantime, I really need to fix my Tundra headlights cause the switch doesn't fire and my passenger side doesn't stay put, the adjusting ball pops out of it's socket. I think I need to supply parts from my OG OEM units for that bit and then troubleshoot. I d/c'd the harness and no change, not entirely unexpected there. I think the trouble is on the switching end, maybe ECU fried...
  22. Jul 12, 2022 at 10:13 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    the cheap-o headlight housings on the sequoia had that problem, a little bit of heat and manipulating fixed it, closing the socket.
    daveeasa[QUOTED] likes this.
  23. Jul 12, 2022 at 10:16 PM
    daveeasa
    Like heat gun to the plastic to melt it so it retained the ball without ejection?
    NUDRAT[OP] and Mr.bee[QUOTED] like this.
  24. Jul 12, 2022 at 10:23 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Yessir, might have used some heat shrink around the ball to help fill the gap, too. It was close to 10 years ago.
  25. Jul 12, 2022 at 10:43 PM
    des2mtn
    SW
    Tonto cover
    Sunnier, shifty`, FirstGenVol and 2 others like this.
  26. Jul 13, 2022 at 4:47 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I've had that happen a few times. Sometimes you get lucky the filament breaks at the end and gets jostled around and then welds itself back together.
    Sometimes it works for a day sometimes months.
  27. Jul 13, 2022 at 6:29 AM
    Cummins3500
    Logan
    i tried to get Tom woods to build me a 1 piece and they told me it was no go. The double cabs are too long. The off-road shop i use tried a couple other drive line shops local and nobody would do it. I just ended putting a new driveshaft in and carrier bearing drop kit. Chasing a never ending driveline vibe.
  28. Jul 13, 2022 at 6:44 AM
    des2mtn
    SW
    Tonto cover
    I wouldn't do a one piece drive shaft personally.
    Cummins3500[QUOTED] likes this.
  29. Jul 13, 2022 at 7:02 AM
    Cummins3500
    Logan
    Makes sense why it’s a bad idea for our trucks once it was explained to me. I was willing to try it get rid of the driveline vibe I’ve been chasing ever since I bought the truck
  30. Jul 13, 2022 at 7:05 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
