2010 cranks but wont start
Discussion in '2nd Gen Tundras (2007-2013)' started by submarinedeckhand, Jul 12, 2022.
  1. Jul 12, 2022 at 7:39 AM
    submarinedeckhand
    submarinedeckhand [OP] New Member
    karl
    Bog standard 2010 crew max
    3 inch lift, 24's
    hi
    after pouring through threads looking for a solution to cranks but wont start i thought id share and maybe save someone else a f****king fortune.
    so turn the key. good crank
    check fuel= no fuel.
    well 110k fuel pump right?
    towed it to a garage so they could
    1) replace the fuel pump $1400.00
    still no fuel
    2) replace the fuel pump control computer
    still no fuel
    3) replace the inline fuel filter
    still no fuel
    turns out it was the chip in the key was bad
    after $2000.00 worth of the wrong stuff it was a $40 key chip!!!
    hope this helps somebody
  2. Jul 12, 2022 at 8:49 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Funny you post this today. I literally had a thought this morning that I had recently seen a lot of Crank No Start post or even No Crank No Start Post. Then thought maybe a generic post with ideas to start self diagnostics would be helpful to users.
    I stumbled across a couple YouTube Videos that do a really good job of diagnosing both is these.
    The best tip I got from these videos was where the tech unlocked the truck, got in, noted the red security light flashing for the alarm, stuck the key in the ignition and verified the red security light went off completely. Had you know this prior it would have really helped you. Some skip directly to trying a second key also.
    https://youtu.be/IJJ3hXEJMpQ
    https://youtu.be/gAgiLouV_00
