Backlight tap to headlight
Discussion in '2nd Gen Builds (2007-2013)' started by raymond_hb, Jul 8, 2022.
  1. Jul 8, 2022 at 6:00 AM
    raymond_hb
    raymond_hb [OP] New Member
    Oakland, CA
    07 Tundra Limited 2WD
    Hi everyone, I just got my DD SSC2s these have a backlight integrated on them but my wiring will go to my switch panel. So the red and black will connect on the switch panel and the blue wire that allows that backlight to be on will be left.
    Is there a way to tap into headlight with the blue wire so the backlight only turns on when my headlights turn on?
  2. Jul 8, 2022 at 6:04 AM
    Taco-Spike
    Two Trucks
    You could use an add a fuse for the low beam fuse box instead of tapping the headlight wiring itself?
  3. Jul 8, 2022 at 6:09 AM
    raymond_hb
    Oakland, CA
    That sounds about exactly what I need to do. Sorry I’m new to wiring specially cutting and adding new wires. Thank you so much you just saved a tundra
    Taco-Spike[QUOTED] likes this.
  4. Jul 8, 2022 at 6:41 AM
    Post pics once they are up and running :thumbsup:
  5. Jul 8, 2022 at 7:23 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    ^^ This
  6. Jul 11, 2022 at 1:21 PM
    raymond_hb
    Oakland, CA
    Finally got around to installing diodes SSC2 and as suggested I hooked the lights to the headlight fuses with the add a fuse and the backlight works perfect!
    You guys are awesome! Thank you so much for the help!
    Taco-Spike likes this.
  7. Jul 11, 2022 at 1:27 PM
    Taco-Spike
    Two Trucks
    :fistbump:
    Looks awesome!
    Get some night shots too (If you can or want to*)
