Solid Offroad - Solid Motor Mount Holiday Deal
Discussion in 'Deals & Group Buys' started by Bonzen, Jul 8, 2022.
Thread Status:
Not open for further replies.
  1. Jul 10, 2022 at 9:30 AM
    #61
    I just replaced with oem when I did long tubes, so im good for a while
  2. Jul 10, 2022 at 9:32 AM
    #62
    Kur
    Kur New Member
    Mesa, AZ
    08, 5.7, Double Cab Tundra, White
    No you mustn't. You'll never find a better time to buy these than now.
    Think of it as an investment. You spend $420 now to avoid spending thousands later in possible frame damage.
    tundra_20, eccracer104 and Bonzen[OP] like this.
  3. Jul 10, 2022 at 9:33 AM
    #63
    Frame damage? That’s new
    eccracer104 and EmergencyMaximum like this.
  4. Jul 10, 2022 at 9:36 AM
    #64
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    If you romp on trucks hard enough the mount perches fail with stock mounts
  5. Jul 10, 2022 at 9:39 AM
    #65
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    I'll sleep over it. My truck is in very good shape but TBH I've not dived into the bay to check on the mounts. I'm currently staying away from hard/speedy off road due to future heavy add-ons and shock valving setup... Tough I bet when the time is right, those mount's will be a godsend.
  6. Jul 10, 2022 at 9:45 AM
    #66
    Kur
    Kur New Member
    Mesa, AZ
    Not that new. It was literally the second thing the OP said in his first comment.
    I looked into it a bit and found out it does happen if you push your truck harder than a typical driver. Lift kits, driving fast off-road, rock crawling, etc, can cause your OEM mounts to fail which allows your engine to move around, exerting lots of forces in all directions which can bend and crack the frame, crack the exhaust manifolds, and cause many other expensive problems. You can see an example of such damage here: https://www.tundras.com/threads/5-7-motor-mounts.58606/#post-1597883
    Here is another guy whose mounts failed and the result was his frame being slowly pulled together over time by his engine moving around: https://www.tundras.com/threads/5-7-motor-mounts.58606/#post-1599875
    I plan on putting my old truck through its paces. And I really like doing upgrades but HATE doing repairs.
  7. Jul 10, 2022 at 9:47 AM
    #67
    C.I.
    Cesar Pedrin
    Cabo, Mx
    QFT
  8. Jul 10, 2022 at 9:53 AM
    #68
    Bonzen
    Bonzen [OP] Solid Offroad motor & transmission mounts
    Lake Havasu City, AZ
    I receive DMs on Instagram almost daily from people with cracked frame perches and caved in frames around the perch towers due to blown out OEM mounts.
    But yes this is typically a result of faster driving over rough terrain aka whoops, jumping, etc.
    A street truck that only sees pavement or flat graded roads probably wont ever have damage like that.
    However every truck can benefit from the increased throttle response and better traction to the tires that the upgraded motor mounts enable. I sell dozens of these kits to S and X runner owners who swear the motor mounts shave time off their strip and track runs.
    Tech Info from the website, so I don't have to retype a novel here haha.
    https://solid-offroad.com/tech-info
  9. Jul 10, 2022 at 9:57 AM
    #69
    empty_lord
    05 rollover special
    I will admit, the throttle response is snappier with the mounts. The lack of twist in the engine is great.
  10. Jul 10, 2022 at 10:10 AM
    #70
    EmergencyMaximum
    EmergencyMaximum New Member
    I wonder if there is a good engineering reason for motor mounts to be softer vs rigid.
    Tundyfundy and eccracer104 like this.
  11. Jul 10, 2022 at 10:18 AM
    #71
    Kur
    Kur New Member
    Mesa, AZ
    Having a rigid mount is good for performance but bad for longevity. Having SOME give is always beneficial for longevity however having too much give turns your engine into a slide hammer.
    tundra_20 likes this.
  12. Jul 10, 2022 at 10:20 AM
    #72
    C.I.
    Cesar Pedrin
    Cabo, Mx
    I guess this is why Solid went with urethane and not delrin :)
  13. Jul 10, 2022 at 10:33 AM
    #73
    Kur
    Kur New Member
    Mesa, AZ
    It wouldn't make a whole lot of sense to use Delrin. Delrin is a great material for bushings that do a lot of moving, such as suspension arms. They are self lubricating and very tough. But for a motor mount that basically does not move, poly bushings are perfectly fine. They are harder than natural rubber but don't self lubricate, which is fine because motor mounts don't pivot. I guess you could use delrin for motor mounts, but it would be a waste to do so. No point really.
    tundra_20 and C.I.[QUOTED] like this.
  14. Jul 11, 2022 at 7:23 AM
    #74
    SAGE63
    San Diego County
    Count me in Mike...I will go with Red...
  15. Jul 11, 2022 at 7:32 AM
    #75
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    Alright Sage! :fistbump:
  16. Jul 11, 2022 at 7:34 AM
    #76
    SAGE63
    San Diego County
    also in for the install party
  17. Jul 11, 2022 at 8:25 AM
    #77
    C.I.
    Cesar Pedrin
    Cabo, Mx
    Well, I have a very convincing pillow. @eccracer104 I'll take a 5.7L set in titanium ;)
  18. Jul 11, 2022 at 9:17 AM
    #78
    eccracer104
    San Diego, CA
    Must be a softy. Haha. You got it! PM inbound for details.
  19. Jul 11, 2022 at 10:07 AM
    #79
    Bonzen
    Delrin is more brittle, and adds to much "vibration". We actually experimented with Delrin back in like 2005-2006 and all the bushing flanges cracked off during off road use. We also tried it in lieu of poly bushings in the lower control arm mounts and the same thing happened. We also machined and ran some poly-carbonate (bullet resistant glass material) bushings too and those were very brittle. Instant cracks. So polyurethane once again was the best of all worlds. I have seen the polyurethane bushings in motor mounts I sold 15 years ago still in used in customers mounts. So they last a long time as long as they weren't melted by a custom exhaust header or damaged from bolts that were allowed to become lose.
  20. Jul 11, 2022 at 10:39 AM
    #80
    BackyardMECHANIC
    BackyardMECHANIC New Member
    Ty
    07 red sr5 trd
    Alot
    07 5.7 bronze please
    tundra_20 and eccracer104 like this.
  21. Jul 11, 2022 at 11:25 AM
    #81
    eccracer104
    San Diego, CA
    Roger that! PM inbound.
  22. Jul 11, 2022 at 11:39 AM
    #82
    eccracer104
    San Diego, CA
  23. Jul 11, 2022 at 12:53 PM
    #83
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
  24. Jul 11, 2022 at 1:11 PM
    #84
    eccracer104
    San Diego, CA
    Awesome!
    Yeah, no problem at all :thumbsup:
    Thanks for participating
  25. Jul 11, 2022 at 1:42 PM
    #85
    nlaroy
    nlaroy New Member
    So Cal
    2017 Inferno Crewmax
    LED bulbs, RCI Underwear, WKOR Sliders, Fox 2.5 w/ resi Front and back, Deaver leaf springs,
    Is there an Install party, cause I'm in if so!!!! lol
  26. Jul 11, 2022 at 1:50 PM
    #86
    eccracer104
    San Diego, CA
    Lol. I know there are talks of one for us socal people
  27. Jul 11, 2022 at 3:51 PM
    #87
    Bonzen
    I have received 8 payments currently. Appreciate the business guys and yes thanks to Mike for spearheading this.
    tundra_20, SAGE63, Silver17 and 3 others like this.
  28. Jul 11, 2022 at 4:09 PM
    #88
    SAGE63
    San Diego County
  29. Jul 11, 2022 at 7:17 PM
    #89
    Kur
    Kur New Member
    Mesa, AZ
    I'm pretty sure I paid.. First time using Zelle. I don't know if the "memo" section is the same as the "notes" or if they will see what I typed or if only I can see it...
    Well.. Somebody got $420...
  30. Jul 11, 2022 at 7:19 PM
    #90
    Sunnier
    Sunny
    San Diego, CA
    :rasta:
Thread Status:
