WCP Door Handles/Part #'s
Discussion in '3rd Gen Tundras (2022+)' started by jproy12, Jul 10, 2022.
  1. Jul 10, 2022 at 7:53 AM
    jproy12
    jproy12 [OP] ¯\_ (ツ) _/¯
    JP
    Ottawa, Canada
    2023 Supersonic Red Platinum Hybrid
    Unfortunately, seems like Roman's website will no longer be available, so asking here for those that have changed them.
    I've been doing some extensive searching and was able to narrow down the front door handles to the following P/N:
    69210-0C100-A0
    69210-0C110-A0
    Issue are the rear door handles, are they also identical from left to right? From a bit of searching and this post from @dyota, it seems like they could be: 69211-0C040-A0. Issue is that according to the Toyota Parts, it does not reflect the proper name, but is it the right door handle?
    A0 at the end being the color code for WCP.
    Anyone that have changed them, can you provide the P/N used please?
  2. Jul 10, 2022 at 8:22 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    If I remember correctly they were listed no as wind chill pearl white, but some other white color name. @Roman can you verify?
  3. Jul 10, 2022 at 8:25 AM
    jproy12
    JP
    Ottawa, Canada
    Thanks, I'm more asking as the rear door handle I have linked come up as: HANDLE, FRONT DOOR, OUT, I've sent a PM to Roman, but trying here first!
    You wouldn't happen to have your boxes from your swap?
  4. Jul 10, 2022 at 12:49 PM
    DexterL
    DexterL New Member
    Tossed them a while ago unfortunately
    jproy12[QUOTED][OP] likes this.
