Speedo Calibrator
Discussion in 'General Tundra Discussion' started by texasrho83, Jul 9, 2022.
  1. Jul 9, 2022 at 12:03 PM
    texasrho83
    texasrho83 [OP] Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Does anyone with the RC speedo calibrator know if disconnecting the battery for a few hours will erase the update/info programmed for your truck?
    I DC'ed so I could trickle charge my AGM for a few hours and noticed I'm off by 10 mph. I'm going to re-update when I get a laptop reconnected to it but yeah weird.
  2. Jul 10, 2022 at 8:10 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Really depends on the circuit and microcontroller RC is using.
    I don’t think they provide a wiring diagram but if they are using the constant power wire going to the cluster it could be to retain memory in the chip.
    If not they could be using EEPROM to store the calibration in the chip so you don’t loose it when power is disconnected.
    texasrho83[OP] likes this.
  3. Jul 10, 2022 at 8:19 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    You’re actually supposed to have the battery disconnected when you’re performing the calibration. I’m running the Hypertech but I’m pretty positive they are the same module, just rebranded for RC, and I’ve never had an issue after disconnecting the battery. Do you use the Hypertech software to do the calibration?
    Jeff_5_7 likes this.
  4. Jul 10, 2022 at 8:35 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Good to know. I don’t have one but I assume the program and code is pretty simple. If you do flash yours with the battery off I wouldn’t think it would loose the program when battery is disconnected
  5. Jul 10, 2022 at 8:53 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    No, RC has their own printed instructions as well as online location for the updater and software. I did not see any place that mentioned to DC the battery prior to calibrating.
  6. Jul 10, 2022 at 8:54 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I would think a momentary lapse in power wouldn't cause a memory wipe but yes, a prolonged absence of power seems likely.
  7. Jul 10, 2022 at 9:00 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I just looked and it’s the same module and software as Hypertech. And the instructions don’t mention disconnecting the battery because you program it before installing it in the truck. Bottom line, the module shouldn’t lose anything no matter how long it loses power.
  8. Jul 10, 2022 at 9:01 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    TRDFerguson likes this.
  9. Jul 10, 2022 at 9:03 AM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    It's not supposed to lose the information. I've had my battery out a lot lately but I haven't verified.
  10. Jul 10, 2022 at 9:27 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah I did the initial flash from my PC but after the install, I used a laptop (did this post-gear swap) while the module was installed.
    If settings should be retained, I don't have a good reason why it is so far off all of a sudden. I'm gonna reflash then monitor.
