Washer fluid sprays underneath the truck?
Discussion in '2.5 Gen Tundras (2014-2021)' started by aussie2u, Jul 9, 2022.
  1. Jul 9, 2022 at 6:04 PM
    aussie2u
    aussie2u [OP] New Member
    I know it sounds strange but on 2015, the Windshield washer stopped spraying, I popped the hood and turned spray on, it immediately starts flooding out to the ground near the passenger side firewall area. The hose is all one piece right? Or is there a splitter or join back in that fender area? Thanks for any clarification on where the fluid is now squirting…
  2. Jul 9, 2022 at 7:59 PM
    AZBoatHauler
    So.Arizona
    Mice probably got your hose. It runs along that side… have someone squirt while you watch to see where you need to patch. Ask me how I know.
    shawn474 and NH 2018 Limited like this.
  3. Jul 9, 2022 at 8:03 PM
    Bsiu27
    Bsiu27 New Member
    Moorpark,CA
    2015 White Tundra TRD 4x4
    Just had to replace mine due to a leak in the same spot due to mice/rats.
  4. Jul 10, 2022 at 2:19 AM
    aussie2u
    Lol, I did read previous posts on rodent issues, especially on wiring, but this isn’t the case here. Truck is garaged and essentially happened overnight. Standing at the engine when the washer motor is actuated, all the fluid starts coming out from “within the fender” near the firewall.
  5. Jul 10, 2022 at 4:18 AM
    Hambone1
    Hambone1 New Member
    Blaine
    2015 tundr limited
    Not much yet
    You don't think you could have mice in your garage????? And it doesn't take but a second for them to chew thru that hose, they don't need all night.
    gosolo and NH 2018 Limited like this.
  6. Jul 10, 2022 at 4:28 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    If it is real dry or someone has poisoned mice they will hunt water.
    gosolo likes this.
  7. Jul 10, 2022 at 5:17 AM
    Cortez11
    Cortez11 New Member
    2013 DblCab 5.7 4x4
    Sounds like you signed up for the Carnuba wax with the under carriage spray option!! That’ll be $14.
    gosolo likes this.
  8. Jul 10, 2022 at 6:23 AM
    Bsiu27
    Bsiu27 New Member
    Moorpark,CA
    The hose runs from the washer fluid tank and makes a 90 degree turn inside the fender wall at the back of the engine bay on the passenger side. Very simple fix but need to get some new rubber tubing. When I detached the cowl that leads to the passenger compartment air filter I found rodent some rodent dropping in there.
    aussie2u[OP] and gosolo like this.
  9. Jul 10, 2022 at 7:32 AM
    AZBoatHauler
    So.Arizona
    Sounds like you’ve got it figured out. I just don’t know why you’d need to wash the windshield on a vehicle that never leaves the garage. :boink:
