2001 squeaky front drivers wheel well…grease fitting there??
Discussion in '1st Gen Tundras (2000-2006)' started by Adventundra, Apr 26, 2022.
  1. Apr 26, 2022 at 7:43 AM
    Adventundra
    Adventundra [OP] New Member
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    When I turn the steering wheel I hear a squeaky sound down near steering shaft…my pal said there is a grease fitting down there…I can’t find it …& he often talks out his ass.
    Is there any grease fittings near steering shaft??
    Mr Badwrench and Mogo Gogo like this.
  2. Apr 26, 2022 at 8:14 AM
    No there is not. It’s probably tie rods or ball joints
  3. Apr 26, 2022 at 8:51 AM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    T
    Mogo Gogo likes this.
  4. Jul 10, 2022 at 6:10 AM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    This thread says there are zerks but I can’t see diagram where they are….
  5. Jul 10, 2022 at 6:31 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    That thread is talking about the grease zerks on the drive shaft. This is the diagram for that:
    But your problem sounds like it could be the u-joints on the steering shaft possibly, if it's not what Frenchy suggested. I don't think those have grease zerks.
    Part numbers and diagrams: https://parts.toyota.com/a/63340908__6731167/STEERING-COLUMN--SHAFT/671460-4501.html
    https://parts.toyota.com/p/Steering-Shaft-Universal-Joint/63552040/4529035040.html
  6. Jul 10, 2022 at 10:45 AM
    shifty` Ten EV 12's so you know I raise hell
    I agree w/ @FrenchToasty and @des2mtn on this, would be my first two things to check.
    But I'd also note, your truck description only says "2001 TRD Pro" (not sure what a "Pro" is, but ...) and doesn't say whether you're 4WD or 2WD, nor what cab type (AC/DC/RC). The zerks diagram above is only valid for 4WD trucks. 2WD had no zerks on the driveline from the factory.
    Adventundra[OP] and FrenchToasty like this.
  7. Jul 12, 2022 at 1:46 PM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Thanks dez!!
    des2mtn[QUOTED] likes this.
  8. Jul 12, 2022 at 1:48 PM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Gotchya Shifty!
    it’s a 2001 TRD 4x4….cab is Access Cab
    Thanks!
    shifty`[QUOTED] likes this.
