  1. Jul 8, 2022 at 11:59 PM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    It is always a correct decision to remove lift blocks.
  2. Jul 9, 2022 at 7:39 AM
    Curious ... which uppers are you running? They look notably more stout than what Camburg and JBA are putting out, to me at least.
    Wait, what? How tall are the blocks? I wouldn't expect much (if any) alignment change with, like, 1" blocks.
  3. Jul 9, 2022 at 9:43 AM
    Silver1stgen13
    Silver1stgen13 New Member
    Sam
    2005 Blue DC 4x4 2001 Silver AC(SOLD)
    They are SPC's. I was pleasantly suprised with how beefy they are.
    oscardog86 and FirstGenVol like this.
  4. Jul 9, 2022 at 11:36 AM
    cadebucket
    cadebucket New Member
    Utah
    2005 Tundra DC Limited
    It has 2" blocks. Some info I found in a different forum said that lifting (or lowering) the rear could effect caster angle, which from my very limited understanding of alignment geometry is important for clearing the 33's. Even if it barely effects the alignment I don't want to risk uneven wear on my brand new tires.
    oscardog86 and Archive like this.
  5. Jul 9, 2022 at 5:38 PM
    Silver1stgen13
    Sam
    I'm assuming the poly bushings for the stock shackles you referred to are the tacoma ones?
    Archive[QUOTED] likes this.
  6. Jul 9, 2022 at 6:20 PM
    daveeasa
    I feel like I need a PhD in suspensions to understand the best choices. :) And I’m only half joking. Going on one year of “I want a truck which can do cool stuff”.
  7. Jul 9, 2022 at 8:07 PM
    Finally got over my fear of metal sparks from a cutting wheel near the gas tank and went to town mangling off the old pickup cab mount to replace it with the new one.
    Voss, RUSTYNUTS, oscardog86 and 8 others like this.
  8. Jul 9, 2022 at 9:10 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    The measurements will be different, simply because the frame angle will change.
    But as you're not actually changing the front suspension settings by lowering the rear, it won't change any front clearance (or lack of). No need to worry about tire wear from this.
    shifty` likes this.
  9. Jul 9, 2022 at 11:43 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Poly body mounts?
  10. Jul 10, 2022 at 2:54 AM
    Yep, the energy suspension ones made for the latest years of the Tacoma. Looks like they fit exactly for the regular and access cabs, but not for the double cabs.
    Unless somewhere between 02-04 the body mounts changed for all variations of the Tundra.
    Got them on Amazon for $99.
    shifty` and empty_lord[QUOTED] like this.
  11. Jul 10, 2022 at 7:10 AM
    Braixen Infection
    Braixen Infection New Member
    2002 Toyota Tundra SR5 4x4 V8
    N/A
    This morning I replaced those stupid little plastic clips for the screws on the cowl. It leaked a ton onto my passenger floor last night driving due to the severe heavy rain and hitting lots of puddles on the road. I got the correct parts to stop the leak but all my snaps are busted so I have to order some more parts lol. Hopefully it leaks no more! Also I found why my fan was making a noise, it was a leaf in there. Little by little my baby is getting fixed!
  12. Jul 10, 2022 at 8:48 AM
    sakana
    sakana New Member
    2002 Tundra AC Limited 4X4
    MT Classic II, Bilstein 5100, 4.88's, BAMuffler catback, 250cc 12-hole injectors, Powerstop Z36 brake kit, Hellwig helper spring and rear swaybar
    Swapped out BFG K02's for Yokohama Geolandar MT's in 265/75/16
    sportbike37, 5N0W808, Archive and 5 others like this.
  13. Jul 10, 2022 at 9:01 AM
    empty_lord
    05 rollover special
    I should do those. Did it include the radiator support bushings?
  14. Jul 10, 2022 at 9:49 AM
    Is that $99 for one or did you do the others too?
  15. Jul 10, 2022 at 10:13 AM
    cadebucket
    Utah
    Lookin good!
  16. Jul 10, 2022 at 10:17 AM
    926A08E0-FD81-4097-8105-92D9D7FCBE65.jpg B70931A0-A604-47A4-BCB8-8980E2DF0BA2.jpg 12FDC0E5-79D0-48FB-AF1B-61D92A52B899.jpg 4B15E71D-3E0C-41BE-BE08-83ECF673B17C.jpg E0C2AF43-ADC6-4312-ACF9-4DD2E942985B.jpg Did some wiring this morning before it got to hot(it was already hot) added two circuits to an existing run, one to get whip with it, and a spare.
  17. Jul 10, 2022 at 10:47 AM
  18. Jul 10, 2022 at 10:50 AM
    You get all 6 for $99. It’s a good deal IMO. I haven’t done the rest yet.
  19. Jul 10, 2022 at 10:54 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Does she come with it?
    KingSequioa007 and Jack McCarthy like this.
  20. Jul 10, 2022 at 10:57 AM
    That would’ve been more than the $12 special I got on it at Marshall’s. :D
    des2mtn[QUOTED] likes this.
  21. Jul 10, 2022 at 11:08 AM
    Yup. I had same issue when I did the work and issued that warning over here, maybe that post will help?
    Here are the part numbers you'll likely need for the clips.
    bfunke likes this.
  22. Jul 10, 2022 at 1:39 PM
    empty_lord
    05 rollover special
  23. Jul 10, 2022 at 2:39 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Or lift plus pole jack.
  24. Jul 10, 2022 at 3:34 PM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    Just curious. Has anyone been Daptized recently? Either VVTi or non VVTi.
  25. Jul 10, 2022 at 4:28 PM
    empty_lord
    05 rollover special
    Say what?
    RUSTYNUTS likes this.
  26. Jul 10, 2022 at 4:35 PM
    Cummins3500
    Logan
    I really need to get off my lazy ass and get the archive relocation kit and hammer hangers on my truck. They’re just chilling in the basement.
    RUSTYNUTS and 5N0W808 like this.
  27. Jul 10, 2022 at 4:42 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    DAP tunings latest 4.7L tune for our trucks. I know he was working on a new one to extract max power and TQ from the engine. The last email I got from him said increases in the 25-30 HP range and TQ, can't remember.
  28. Jul 10, 2022 at 4:52 PM
    empty_lord
    05 rollover special
    But does it cover the 05-06. Or is it 07+. OV tune my buddy dug into the files and all he actually supports is a 2008 4.7
  29. Jul 10, 2022 at 4:52 PM
    empty_lord
    05 rollover special
    I still need to figure out my backup camera situation…
    shifty` likes this.
  30. Jul 10, 2022 at 5:10 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Yes 05-06. I have a 07 Sequoia. Still rocking the 4.7L VVTi. I currently have a R9k tune which is okay but isn't as good as DAP.
