Oil Pressure "Gauge"
Discussion in '3rd Gen Tundras (2022+)' started by WasAChevy, Mar 12, 2022.
  1. Mar 12, 2022 at 3:35 PM
    WasAChevy
    WasAChevy [OP] New Member
    Where does everyones oil pressure gauge (bar) run at idle? As part of my weekly ritual I checked the engine oil and man is it so very light in color that it was difficult to see the oil between the circular holes.
    Teddyk1 and Texmech like this.
  2. Mar 12, 2022 at 6:27 PM
    WasAChevy
    At idle?
  3. Mar 12, 2022 at 6:29 PM
    sparky412
    sparky412 New Member
    SW Pennsylvania
    22 SR5 OR CM 6.5 MGM
    After the truck is warmed up the gauge reads about a quarter on a regular basis just shy of 3000 miles
  4. Mar 12, 2022 at 6:45 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Pretty sure Toyota went back to the 1/4 level mark to be normal on the new 3rd Gen, 2.5's are in the middle or slightly just below. Not sure why. :notsure:
    k0diak8o8 likes this.
  5. Mar 12, 2022 at 6:57 PM
    WasAChevy
    Thanks! That is what my gauge reads as well. What does it read when you're doing 65-70ish?
    I wonder what the psi correlation is.
  6. Mar 12, 2022 at 7:00 PM
    sparky412
    SW Pennsylvania
    About the same unless I’m heavy on the skinny pedal
    WasAChevy[QUOTED][OP] likes this.
  7. Mar 12, 2022 at 7:10 PM
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    At low rpm after warm up it should read around 1/4, and higher at higher rpm’s.
    WasAChevy[OP] likes this.
  8. Mar 12, 2022 at 7:40 PM
    stevj
    stevj New Member
    On a clear day, I can see Seattle from my house.
    Current RAM 1500 owner waiting for the new Tundra "hybrid."
    Oil pressure fluctuations are a primarily result of oil temperature and engine RPM, not speed.
    Oil pressure at 20MPH will be the same as at 70MPH if engine RPM is the same because of transmission gear selection.
  9. May 30, 2022 at 6:07 AM
    Snipley
    Snipley New Member
    Wes
    2022 Tundra Limited Double Cab
    I was wondering the same for my new Tundra with the oil gauge. I have the same question about the voltage gauge, mines always below the half way mark.
  10. May 30, 2022 at 8:49 AM
    mass-hole
    mass-hole New Member
    This is why no other brands provide actual moving oil pressure gauges anymore. Cause people freak out.
    FLTon likes this.
  11. May 30, 2022 at 9:01 AM
    Snipley
    Snipley New Member
    Wes
    Mass-Hole, I don't think anyone is freaking out. Just seems odd that the the gauge reads in the lower quarter. Most times ideal is somewhere near the center of the range.
    I only picked up my Tundra yesterday and was curious if mine was low.
  12. May 30, 2022 at 3:34 PM
    xc_tc
    xc_tc New Member
    There’s a warning for when oil pressure is too low. There’s also a warning for when battery voltage is too low. I wouldn’t worry about the gauges… especially one without units.
  13. May 31, 2022 at 6:09 AM
    nodak67
    nodak67 New Member
    JR
    and this is one reason (not including people pouring non engine oil into the dipstick tube) why most oem's have removed the oil dipsticks. too many people complaining about the gauges showing wrong to them level on the gauge (but normal reading per the computer)
  14. May 31, 2022 at 11:40 AM
    mass-hole
    Exactly.
    Ignorance is bliss. if the gauge just sat in the middle and never moved you wouldnt even think about it.
  15. Jun 27, 2022 at 9:38 AM
    BMDTundra
    BMDTundra New Member
    2022 Tundra Limited 4x4
    I’m reading at a 1/4 pressure and I was concerned. Good to know this is a “normal” reading.
  16. Jul 9, 2022 at 4:24 AM
    Demar002
    Demar002 New Member
    Frank
    2022 Toyota Tundra
    I am concerned most of the time it is at 1/4. It is never above that. However what is concerning is when it goes to 0 - It does so if I am running 50, 70, 49 mph Etc and I come off the gas. Here is a picture That just doesn't seem right to me
  17. Jul 9, 2022 at 5:13 AM
    chaztizer
    chaztizer New Member
    2023 Tundra TRD Pro
    This is because you own a hybrid and the engine is currently off in this pic. When the RPMs drop to zero, it’s because the gas engine is shut off and running/coasting in electric only mode. Oil pressure will drop to zero in an engine that isn’t on.
    windblown101, SC4333, pwpblue and 2 others like this.
  18. Jul 9, 2022 at 5:15 AM
    xc_tc
    xc_tc New Member
    The engine is off. Notice how the needle on the tach is at 0 rpm. Can’t have oil pressure if the engine isn’t on… I’m pretty sure all hybrids shut the engine off even at highway speeds when not accelerating or coasting.
    pwpblue likes this.
  19. Oct 22, 2023 at 5:24 AM
    Teddyk1
    Teddyk1 New Member
    Teddy
    Wisconsin
    2022 Tundra SR5 , blueprint
    Tonneau cover
    IM happy to see this thread on oil pressure gauge. Im reading everywhere that this is normal. Im also reading everywhere of engines dropping like crazy. Mine in September had seized camshaft right side. Oil pressure gauge reads at just below a quarter when rpm is under 2000 no matter the speed. At 70 Im under 2000 rpm. When cold it goes up then settles just under a quarter. So this seemed normal, however , just found this Toyota bulletin ,
    Which describes my exact operation. What does that mean? I guess I have to call the dealer and see if this is normal or just software modification, or de we have low oil pressure and thats what is blowing these engines bearing failures.IMG_0222.png
  20. Oct 22, 2023 at 5:31 AM
    Oldandfat
    Oldandfat New Member
    Cannuckastan
    2024 sr5 trd offroad.
    first thing in the morning my gauge shoots up to about 3/4. As it idles down it settles around 1/2
    it will bump back up to 3/4 as I accelerate until the truck is warmed up. Then it doesn’t really move when I’m driving.
    Mattedfred likes this.
  21. Oct 22, 2023 at 6:13 AM
    Oldandfat
    Cannuckastan
    I do exactly the same thing.
  22. Oct 22, 2023 at 12:16 PM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    Mine gets towards 3/4 when accelerating from cold, but settles to about 1/3 at warm idle, and gets up to ~1/2 accelerating when warm.
  23. Oct 22, 2023 at 7:11 PM
    SC4333
    SC4333 New Member
    Grant
    2022 Tundra Limited TRD OR 4x4
    with the engine oil up to temp (around 200*F) the gauge hovers around a quarter at idle. When idle fluctuates briefly and dips low, I will see as low as 9psi (very briefly) and averages around 12-13 psi (when viewing pressure with a scan tool).
    at startup and above freezing temps its more like 3/4 and around 70psi or so of pressure. slightly higher during a really cold morning.
    No TSB here, so if you have the TSB performed (computer flash for oil pressure and fuel reading fluctuations) you'll effectively get a dummy gauge from what I've read others reporting. Or should I say, a much less linear representation of what the actual pressure is.
  24. Oct 22, 2023 at 7:18 PM
    SC4333
    SC4333 New Member
    Grant
    You hit the nail on the head. It is simply a software modification that will change how the gauge represents oil pressure. Presumably this has been implemented in all the later model builds. I guess enough people complained and or are use to watching dummy gauges in late model cars that read smack in the middle as 'normal' operating value. This is very common with coolant temp gauges, especially those that are digital.
    SnrDisregardo likes this.
  25. Oct 22, 2023 at 7:25 PM
    Teddyk1
    Teddyk1 New Member
    Teddy
    Wisconsin
    Tonneau cover
    So just leave this alone you are saying. It’s a real pressure reading
  26. Oct 22, 2023 at 7:32 PM
    SC4333
    SC4333 New Member
    Grant
    Yes sir, it should not be of concern.
  27. Oct 22, 2023 at 8:26 PM
    Tom976
    Tom976 New Member
    Tom
    The pressure on my 23 is about 3/4 when the car is warming up.
    I let it warm up a little and keep the rpms under 2k until operating temp.
    Under 2k rpm the oil pressure is a little under 1/2.
    Over 2k rpm at any speed the turbos spool and the pressure rises.
    Tundraaa3 and Mattedfred like this.
  28. Oct 23, 2023 at 4:24 AM
    nodak67
    nodak67 New Member
    JR
    my 23 oil pressure shows just a tad above 1/4 when under 2k rpm's. jumps to above 1/2 after startup then settles down to just above 1/4.
    have the fuel gauge issue on the 23 so this TSB doesnt apply since its only for 22's
  29. Oct 24, 2023 at 10:55 AM
    Tom976
    Tom976 New Member
    Tom
    Here are a few examples of my oil pressure.
    Idle, under 2k moving and over 2k.
  30. Oct 24, 2023 at 11:03 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Before tsb mine was at about 1/4 pressure. After tsb it looks more normal at about 1/2 pressure
