Help with engine light codes
Discussion in '1st Gen Tundras (2000-2006)' started by RR60, Jul 8, 2022.
  1. Jul 8, 2022 at 2:25 PM
    RR60
    RR60 [OP] New Member
    2003 SR5 Tundra long bed
    I have a 2003 but this is for my friend with a 2000 2WD V-6
    So far he has spent a fair amount of time and money trying to fix this.
    Codes P0171 and P0441
    So far had replaced.
    Vapor cannister and everything that goes with that
    New fuel pump
    PCV valve & checked all vac lines.
    O2 sensors.
    Any other suggestions
    Thanks
  2. Jul 8, 2022 at 3:28 PM
    Stupid question, did you take the simple step of replacing the gas cap? And confirm he's closing the gas cap until it clicks once?
  3. Jul 8, 2022 at 6:54 PM
    RR60
    Yes, sorry did not list. That was the very first thing we tried a few months ago.
  4. Jul 8, 2022 at 6:58 PM
    nickrick78
    nickrick78 New Member
    Pittsburgh PA
    2004 DC
    Purge valve at the engine. They also call it an EVAP VSV (vacuum switch valve)
  5. Jul 8, 2022 at 7:11 PM
    nickrick78
    Pittsburgh PA
    2004 DC
    Should look something like this, left side of engine bay I believe
    Get the part number off the old one to make sure you get the right part
  6. Jul 9, 2022 at 5:34 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Same friends Tundra from couple months back ?
    Codes P0171 and P0441 | Toyota Tundra Forum (tundras.com)
    If so....mind answering a semi important question @shifty` asked in original thread ?
    Also, don't want to assume wrongly but you are or have erased all codes properly ?
    shifty`[QUOTED] likes this.
  7. Jul 9, 2022 at 6:00 AM
    RustyMcTee
    RustyMcTee We do it right, cause we do it twice
    New England
    03 AC SR5 4x4 3.4L V6 234k
    New frame in 2022 CB Radio Aluminum cap Bilstein 4600's
    Did this on my honda element and it turned out to be the culprit. Evap canister box needed to be replaced eventually. Full of gas... Sold it before I had to deal with it
  8. Jul 9, 2022 at 6:12 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    P0171 is an intake leak between MAF and plenum. Most likely an air tube with bends/folds in it, inspect carefully. Replace only with OEM stuff.
  9. Jul 9, 2022 at 10:28 AM
    RR60
    Yes same problem. Been awhile so started a new thread.
    And all parts OEM ordered thru Coniceilli Toyota
    Mechanics erased codes when parts put in and they come back on.
    Thanks
  10. Jul 9, 2022 at 10:56 AM
    RR60
    Would that be the samething he also replaced. Called the
    Valve Vacuum Switch
    9091012268
    Thanks
  11. Jul 9, 2022 at 6:06 PM
    nickrick78
    Pittsburgh PA
    2004 DC
    Probably. It should have a line going to it with a port with a green cap
