Let's see your first gen - photo thread
Discussion in '1st Gen Tundras (2000-2006)' started by Rkcruza, Jan 6, 2014.
  1. Jul 7, 2022 at 7:06 PM
    #2791
    Kandgo
    Kandgo New Member
    R
    2006 4door 4x4
    I am guilty. I have never waxed it. It spends it’s time outta the weather when not hunting or Colorado Trips. I should wax it though, you guilt me.
  2. Jul 7, 2022 at 7:08 PM
    #2792
    It'll need more than wax. I was in the same boat as you, but worse. Just took a once over with a random-orbit polisher a medium-correction pad, and some Meguair's Ultimate Polish. Other guys around here with white trucks got the same result. Yours looks a helluva lot better than ours did! (link in my signature will show you mine - it was CHALK)
  3. Jul 7, 2022 at 7:17 PM
    #2793
    Kandgo
    Kandgo New Member
    R
    2006 4door 4x4
    I recently retired. I need to learn how to give it a good wax/buffing maybe huh? It sets in a shop most of the time. It is used solely for hunting and Colorado/Moab trips. Paint is great on it I think, but I am no paint guy, and admittedly a non wax guy too!
    Just seen your photos. Nice truck too! My paint is still shining. But I will wax it when we get back this time. I do wash it and keep it clean with car wash wax at the local car wash.
    shifty`[QUOTED] likes this.
  4. Jul 8, 2022 at 5:14 PM
    #2794
    Jbhoops
    Jbhoops New Member
    2001 tundra access cab
    2002 acces cab 256000 miles
    N!Ko, bmf4069, Filthyphil and 4 others like this.
  5. Jul 12, 2022 at 11:26 AM
    #2795
    SharkDog
    SharkDog New Member
    Denver
    2006 Gray DC Tundra SR5
    Dobinson Twin Tubes. Stock.
    Great looking truck!
    I just added a front hitch to mine, which is primarily to haul the shuttle motorcycle when I have a raft trailer on the back. I am thinking about getting a winch and hitch cradle. Which winch and mount do you have? Looks like the harbor freight mount, but a bunch of people make one that looks like it. How do you like it? Did you run power to the rear, too?
  6. Jul 12, 2022 at 6:07 PM
    #2796
    ToyoLife
    ToyoLife New Member
    06 DC Limited 4x4
    I need to replace my sway bar links. How are the Maxx swaybar links holding up? Looking at Overland Custom Designs links as well.
  7. Jul 12, 2022 at 6:17 PM
    #2797
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    The Suspension Maxx links definitely hold up a lot better than OEM or links from the parts store. They do tend to loosen over time though and start to make clunking sounds. Go with the extended option if you're lifted.
  8. Jul 12, 2022 at 8:49 PM
    #2798
    Kandgo
    Kandgo New Member
    R
    2006 4door 4x4
    Yes on power to front and rear, as well as an extension to my trailer. Badlands Apex 12500, I ordered the cradle Amazon. I use a trailer on front to pull Animals up on it when hunting. It also Carrie’s a rack on front sometimes when hunting, keeps the blood of coyotes and such out my truck.
    SharkDog[QUOTED] likes this.
  9. Jul 12, 2022 at 9:01 PM
    #2799
  10. Jul 13, 2022 at 2:59 PM
    #2800
    Kandgo
    Kandgo New Member
    R
    2006 4door 4x4
    Here is what I used to run the winch on front and rear. I encased it inside a thick hose and ran it along the frame hidden and tucked in. I called the guy who sells it and got extra connectors and a jumper cable set 20ft. The cable has some very thick coating, but wanted extra abrasion protection. I als added a battery disconnect switch in front next to radiator on the right side to keep power off till needed. Now I can power winch on my three different trailers too. I also can solar charge the battery’s on the truck when out dry camping/hunting. I get lots of questions on the front hitch whe the basket is in it! But it is so handy for keeping stank/blood/guts out of my truck. The basket will carry upwards of 10 coyote’s, couple deer etc! That is why I needed stronger front suspension, with the Bilstein Springs and 5100 shocks.
    784B6EAF-513D-44F0-9C2F-2082D9A1265C.jpg 8791F42A-6D99-493B-89A3-A212DF67ACE7.jpg 14FE60F0-ED7F-44DF-AC61-EFBDA57AAB42.jpg
    KNABORES and FrenchToasty like this.
  11. Jul 13, 2022 at 3:04 PM
    #2801
    Kandgo
    Kandgo New Member
    R
    2006 4door 4x4
    E04535C4-E47C-4347-A5AD-9689CD2B89C7.jpg 415BE2A4-5084-4071-8953-69EA996C4762.jpg
    bmf4069, SharkDog, des2mtn and 2 others like this.
  12. Jul 17, 2022 at 8:25 PM
    #2802
    Grumpy74
    Grumpy74 New Member
    2005 White Tundra SR5
    Since we're showing off white double cab Tundras, I'll show mine off in a tight place where the sun doesn't shineIMG_20220717_193442624_HDR.jpg IMG_20220717_193434201_HDR.jpg
    bmf4069, alb1k, abcinv and 3 others like this.
  13. Jul 18, 2022 at 2:42 PM
    #2803
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Another one :wave:
    bmf4069, alb1k, Grumpy74 and 2 others like this.
  14. Jul 18, 2022 at 6:41 PM
    #2804
    2005tundra_nopayments
    2005tundra_nopayments 1st gen Tundy
    Jr
    Central Ca
    2005 tundra double cab 4.7
  15. Jul 21, 2022 at 7:09 AM
    #2805
    IndyMike
    IndyMike New Member
    2002 Tundra SR5
    Just joined the forum...here's my 2002 Tundra SR5. I bought her new 20-years ago with 7 miles, now she's at 145k.
    whittkl4, 16CMTXED, bmf4069 and 8 others like this.
  16. Jul 21, 2022 at 10:22 AM
    #2806
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    Welcome and nice ride! 20yrs, seems to be a keeper!!
  17. Jul 21, 2022 at 2:22 PM
    #2807
  18. Jul 21, 2022 at 2:58 PM
    #2808
    I've always wanted to see what your truck would look like w/the bronze finish Methods. I mean, I've got my own pet peeve about blackout wheels on white trucks (it works better if trim/bumper is same), but whatever.
    Anyway, I suck at photoshop, so this really isn't a good example, the blacks inside the wheels should be toned down and I'm not willing to invest the time. But this is roughly in the ballpark, shittily. I think the color needs more orange/copper tone to look right. This is too muted.
    Voss likes this.
  19. Jul 21, 2022 at 3:02 PM
    #2809
    Jbhoops
    Jbhoops New Member
    Like black much better
  20. Jul 21, 2022 at 3:25 PM
    #2810
  21. Jul 21, 2022 at 3:27 PM
    #2811
    Jbhoops
    Jbhoops New Member
    True lol
  22. Jul 21, 2022 at 3:43 PM
    #2812
    My wheels are actually gunmetal with black lip. They are a little dirty at the moment. I don't really like black wheels as much as I used to.
    You might be onto something @shifty`
    Voss and shifty` like this.
  23. Jul 21, 2022 at 3:49 PM
    #2813
    Yeah, that's the look I'm talking about. There are a few out there doing it. There are two looks, one is more of an antiqued bronze, the other being copper or bright copper, and another being more yellow gold.
    I prefer that pic you posted as my favorite look on white trucks vs. hypersilver wheels (which I also love). Smoked looks pretty good too, if not too dark.
    Here's another I found that I like. White trucks look awesome with copper, I think. Wrong generation, but similar color concepts...
  24. Jul 21, 2022 at 3:55 PM
    #2814
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    White trucks do not look awesome with copper. Do the gun metal. or gray/silver/gunmetal/black and or combo
  25. Jul 24, 2022 at 7:28 PM
    #2815
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
  26. Jul 25, 2022 at 9:02 AM
    #2816
    SharkDog
    SharkDog New Member
    Denver
    Thanks for all the info. I used mine for the first time last weekend to carry the shuttle motorcycle on the front with the raft trailer in the back. I am going to wire it up for a winch, too. And because this is a photo thread, here is my truck a couple weekends ago while camping.
    Voss and Cpl_Punishment like this.
  27. Aug 8, 2022 at 4:33 AM
    #2817
    04EbonyTundra
    04EbonyTundra New Member
    Rick
    2004 Access Cab Black
    K&N intake, flowmaster muffler
    So my new black beauty (04) , And my work truck, (started life as a 01 but has various parts off a 03 on it) I also have two more but they're stored at a friend's as they're parts trucks
  28. Aug 8, 2022 at 4:56 AM
    #2818
    04EbonyTundra
    Rick
    Okay so I do happen to have a picture of my 2000 as well. The one far left. The two OTHER silver trucks are what now make up my current work truck. As well as a rear and leafs out of my blue 01 parts truck.
    5N0W808, bmf4069 and Cpl_Punishment like this.
  29. Aug 8, 2022 at 6:56 AM
    #2819
    DesertRoads
    DesertRoads Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore. Mostly Stock
    Here's my '05 Tundra shortly after I got it (a few weeks ago). The roof it oxidized, and she needs some TLC. I've since replaced the headlights with some after markets and threw in some Hella halogens. I have a handful of practical mods planned, nothing too crazy. :)
  30. Aug 8, 2022 at 7:25 AM
    #2820
    Unswashed daytime pic with new fogs.
    Jack McCarthy, txagg, bmf4069 and 2 others like this.
