Caught between cat thefts and a hard place
Discussion in 'General Tundra Discussion' started by doggiecareman, Jul 8, 2022.
  1. Jul 8, 2022 at 4:40 PM
    doggiecareman
    doggiecareman [OP] YOLO / Best to do it with a Toyota
    Eric
    North Central CT
    Tundra Army Green Limited Double Cab TRD Off Road 2021
    TRD dual exhaust/Factory running boards/center console safe/Truxedo X15 Tonneau/ceramic coated/ceramic window tint/BFG KO2's/swing cases/debadged
    Been enjoying my freedom not worrying about my cats being stolen but I’m having the truck checked out next week. Was towing in Massachusetts Connecticut and southern Vermont trailering approximately a 6500 pound landscaping trailer and tractor. Didn’t go over 65 kept it about 55 to 60 on average and used tow haul on the inclines. After about two hours of that I got the overheat transmission warning light pop up. fortunately was right when I arrived at my cabin in Vermont. It was sunny and about an 84 to 86° Midday excursion. I may have to get the much hotly debated and ad nauseam discussed transmission cooler. I’ll be curious to see what the dealership says on my appointment next Tuesday.
    Mike59 likes this.
  2. Jul 8, 2022 at 4:44 PM
    Damn. That warning light is 300+ deg F.
    I would service the transmission asap.
  3. Jul 8, 2022 at 4:45 PM
    doggiecareman
    Eric
    North Central CT
    When you say revive, it’s a 21 with 11,500 miles on it. Not exactly sure what you’re referring to?
  4. Jul 8, 2022 at 4:51 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Doesn't matter how new it is. ATF boils at 300+
  5. Jul 8, 2022 at 4:51 PM
    I typed service and it swapped to revive?? Lol. Fixed it.
  6. Jul 8, 2022 at 8:50 PM
    This is why running a good oil can save your transmission. Then again, the seals are probably deteriorating over 300*F.
    I’m going to use the coined Ben Franklin quote “an once of prevention is worth a pound of cure.”
  7. Jul 8, 2022 at 9:46 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Were you driving in S4 or D?
    Terndrerrr likes this.
  8. Jul 8, 2022 at 10:08 PM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Dealer is going to say they can't replicate the issue and that the transmission is functioning as intended. Been there, done that, they DGAF if the trans cooks because Toyota say the trans cooler isn't needed.
    texasrho83 likes this.
  9. Jul 9, 2022 at 3:39 AM
    That ATF boiling point chart can't be right.. Are we talking about 300 to 400 degrees C or F? 300 degrees C seems a bit much which equals 572 F!
    P-Factor and ColoradoTJ like this.
  10. Jul 9, 2022 at 4:26 AM
    Retired...finally
    My guess in drive like the manual states but only tow/haul on inclines. I've tried towing in drive using T/H watching the scan gauge and it's a recipe for a transmission pan turned dumpster fire. And that's with a < 3 ton TT.
    It's S4 T/H with select use of 5th for this kid. The transmission spends way too much time with the TC unlocked when in drive or even S5. Even when in T/H.
    I remember another poster hitting the limits and the dealer recommended a fluid change.
    WVI likes this.
  11. Jul 9, 2022 at 5:11 AM
    With my 2012 (in know, it has a cooler), it seemed like being in D/TH mode was the ticket. Now I was on the upper end of the tow ratings, so no matter what I was in 3rd and 4th all the time anyway. In downhill small grades the trans would shift to 5th.
    The 2019-21 trucks without the cooler just mind baffles me. Even our super secret Toyota engineer said it was a financial decision over reliability. They even installed a factory style cooler on their 2021 Tundra if that says anything.
    @doggiecareman, some things you can do before anything major:
    1) get a monitoring system. Edge CTS3, Scan Gauge just came out with a new model, or whatever you prefer.
    My truck has a factory trans temp gauge and I still use my Edge monitor to double check and set parameters when it’s time to be concerned.
    2) Change your driving habits a bit. Use Tow Haul mode at all times when hooked to a trailer, not just on grades. Try placing the transmission is S mode (shift) with T/H engaged. The data doesn’t lie, and the members with ‘19-21 trucks that monitor trans temps have had good success doing this without any other mods.
    3) Lastly (I would do this first, but that’s just me), install a factory style transmission cooler.
    Out of all my years of towing, never have I had the transmission warning system on in any truck…and at times I was pretty hard on my Tundra. On the flip side, if you don’t keep vehicles outside warranty I wouldn’t do anything more than a OBD scanner.
  12. Jul 9, 2022 at 5:28 AM
    doggiecareman
    Eric
    North Central CT
    I drove a combination of both. Though driving in tow/haul mode should compensate for that from my understanding.
  13. Jul 9, 2022 at 6:11 AM
    timsp8
    NY
  14. Jul 9, 2022 at 7:02 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Tow/haul in S4 is what you’re supposed to use for towing per the owners manual. S4 is your last non-overdrive gear, and the only non-overdrive gear that you can lock the torque converter in. If you tow in D, your transmission is constantly shifting between gears 4, 5, and 6 and isn’t staying locked up in any of them. That is what generates heat.
    I absolutely hate that the 19-21 trucks don’t come with an actual air cooler in addition to the oil puck. That’s why I put one on at 3k miles. There are a couple good YouTube videos on how to do it and how to check your fluid level after adding so you don’t overfill. Easy to find if you search. @Genuine Cooling Systems is where I bought my cooler.
  15. Jul 9, 2022 at 7:14 AM
    Retired...finally
    In my owners manual it's rather vague on where you should place the transmission for towing. It leans toward towing in drive but selecting S4 going down grades for engine braking. Tow/Haul mode is a definite yes though. If there's one change I'd like to have it's that the T/H mode default to on when a trailer is connected to the 7 pin.
  16. Jul 9, 2022 at 8:22 AM
    brobert225
    brobert225 Firm grasp of the obvious
    Transmission fluid does not boil at 300F. The C is probably correct. Not sure this directly relates to anything related to transmission wear etc, but good to get it checked out.
  17. Jul 9, 2022 at 8:32 AM
    Terndrerrr
    Music City
    6UR-FE
    I scoured my manual and couldn’t find anything related to towing in D…do you have a page number where it says this?
    doggiecareman[OP] likes this.
  18. Jul 9, 2022 at 11:49 AM
  19. Jul 9, 2022 at 11:52 AM
    Retired...finally
    Look at the bullet point in the middle of page 210. Vague to say the least. I called Toyota to get their interpretation and asked my dealer to read it and both said tow in drive but use S4 to descend hills. Being someone with a technical writing background the statement leads to believe both clarifications although I believe it isn't written correctly.
  20. Jul 9, 2022 at 12:45 PM
    Terndrerrr
    Music City
    6UR-FE
    Yep, right there. This is a list of towing tips, and I don’t read that to say that you should shift into S4 only for going downhill. Nowhere does it say to tow in D. S4 prevents you from using the overdrive gears which don’t stay in lockup very well except when cruising on level ground. On page 212, the manual gives a checklist of what to do before towing, and that’s where it says to put it in tow/haul mode.
    To me, it’s saying to tow in S4, in tow/haul mode, at ≤65mph.
  21. Jul 9, 2022 at 12:48 PM
    Retired...finally
    It could be alot clearer.
  22. Jul 9, 2022 at 2:03 PM
    Retired...finally
    It was bad enough we didn't get the transmission cooler so they changed the shift parameters to heat the fluid even more. The melted icing on the burnt cake is the unclear instructions regarding towing in the owners manual. Oh, almost forgot: No trans temp gauge. Just a light to tell you that your transmission is now effectively half lifed.
    Jernik and doggiecareman[OP] like this.
  23. Jul 13, 2022 at 3:25 AM
    Bammer
    Monroe, CT
    With a Tranny cooler = T/H + D :burnrubber:
    EmergencyMaximum and WBW like this.
  24. Jul 13, 2022 at 5:04 AM
    “When using engine braking” is the key words here.
    So when do we use engine braking? (Coming to a stop, steep grades, etc.)
    Half tons do not have a fantastic grade braking transmissions like HD trucks and can really put a strain on several components. The electrical system is one of them. If you ever get stuck in traffic (the inch 5’ and stop kind) I would take my trailer brakes out of service until traffic started moving again (don’t forget!!!) All that power needed to activate the brakes at essentially idle can really take its toll on the system.
    I’ve said this a lot in here, but I also have to change things up a bit. Data doesn’t lie. All my towing experiences with a Tundra was with one that had an external front mounted cooler. The 2019-2021 trucks have been running a bit hotter when towing in D/TH mode. With these trucks, probably a good idea to run in S4.
    I agree it’s very vague on the correct towing configuration. My manual in the HD truck is very clear on what to do with any heavy payload or towing. Tow/Haul and exhaust brake on.
  25. Jul 13, 2022 at 6:21 AM
    Bammer
    Monroe, CT
    I put a cooler on my 19, piece of mind, no S mode needed unless it's extreme !
    doggiecareman[OP] and ColoradoTJ like this.
  26. Jul 13, 2022 at 6:23 AM
    What did that end up costing to install a cooler? Did you go with the factory style?
  27. Jul 13, 2022 at 6:50 AM
    Bammer
    Monroe, CT
    Got the kit from Nick(site member) local trans shop installed for @300 bucks. So say $1,100.00
  28. Jul 13, 2022 at 9:35 AM
    Terndrerrr
    Music City
    6UR-FE
    I hear you. What I posted is from my manual (for the 21MY); maybe older manuals are slightly different in their towing tips? I read it as stay in S4 and here is one reason why…the other is left unsaid…is it not also conventional wisdom to not tow heavy loads in overdrive gears, especially on non-HD trucks, and extra especially (lol) on non-HD trucks that deleted their external cooler?
    I put a cooler on my truck as well. Bought the older Hayden kit from @Genuine Cooling Systems and pieced together the OEM parts from McGeorge Toyota and Lewis Toyota. I was into parts and fluid for $700. Did the install myself. Fairly easy.
  29. Jul 13, 2022 at 10:03 AM
    The concern with towing in higher gears is converter lockup. If we could have a way of tuning the transmission’s a bit more this might be possible. As of right now, in 5th & 6th we can only get into partial converter lockup. This just really creates a ton of heat. Maybe @Vizsla can confirm. He has been getting into the HP Tuners software and tuning his truck.
    Yesterday I spent an hour or so talking with a well known tuner and tried to talk them into Toyota tunes. Well that failed miserably. :rofl: At least I tried. I sure and hell spent 1150.00 on a tune pack with transmission tuning though:D. Hook, line, sinker.
  30. Jul 13, 2022 at 10:06 AM
    Solv3nt
    Solv3nt New Member
    Oregon
    2021 SR5 Off-Road 4x4
    Driver side grab handle, Genuine Cooling System Transmission cooler package, Max Modular Bed Rack, White Knuckle Off-road sliders, undercover ultra flex tonneau cover
    What does the TC do, and what does it mean "locked in"?
    FYI, I installed Nick's kit and towing my 4400GVWR TT, the scan gauge won't go over 195F for the pan temp.
