Creak/rattle noise when rear window is down
Discussion in '3rd Gen Tundras (2022+)' started by molson7, Jun 10, 2022.
  1. Jun 10, 2022 at 8:45 AM
    molson7
    molson7 [OP] New Member
    Looking to see if others hear a tailgate rattle when back window is down, and if so has anyone found a fix for getting rid of it. I can't emulate the rattle manually when messing with the tailgate but think it's either movement of the gate from it's mount point or possibly the rubber bump stops not being large enough to press against gate when closed.
    Anyone else have this issue?
    Mavnatty likes this.
  2. Jun 10, 2022 at 8:56 AM
    Mavnatty
    Mavnatty Go Dawgs!
    2022 Tundra CM SR5 XP
    Same issue not sure how to fix I only hear it on bad bumps tho like going over the RR tracks near my house.
  3. Jun 10, 2022 at 9:24 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    On the 2nd gens you can loosen the screws on the latches that are mounted to the bed and push them forward a little bit, then retighten. This will hold the gate more snugly and eliminate the play. Not sure if this is doable on the 3rd gens but worth a look.
  4. Jun 10, 2022 at 9:48 AM
    molson7
    good to know, i'll give that a try
  5. Jun 10, 2022 at 11:31 AM
    TeeT2
    TeeT2 New Member
    Tee
    2022 Tundra Platinum
    Yes!!! Took it to my dealership yesterday and was given some BS that it was my seatbelt banging against the side. These guys are freak'n dumb-asses. I'm still pissed off AF.
  6. Jun 10, 2022 at 12:08 PM
    Breathing Borla
    Northern Illinois
    tape the belt to teh sidewall and then take them on a test drive, hey dude, it isnt the belt, lol.
    sorry for you troubles, im trying to figure out when to purchase but it just seems they are not fixing these things yet. need some TSBs
  7. Jun 10, 2022 at 1:10 PM
    Seawolf
    Seawolf New Member
    2022 Toyota Tundra Platinum 4x4 Blueprint
    I created an account just to reply to this thread because I know how frustrating rattles can be, lol.
    I, too, hear the rattling when the rear window is down. I'm not sure if mine is the same issue you and others have, but my issue wasn't the tailgate, it was the plastic bedside caps (for lack of a better description) that run the length of either side of the top of the bed. My driver side is tight, but the passenger side is slightly loose and when there's vibration applied to it then it rattles against the bedside. At some point, it will likely bother me enough that I take it off and try to do something about it but as of right now I haven't done anything to fix it. I may let the dealer deal with it the first time I take it in.
    Before tearing into your guys' tailgates, I'd suggest inspecting these bedside plastic caps first.
    glozanoff and LukeS like this.
  8. Jun 10, 2022 at 1:21 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Nice first post, congratulations and welcome!
  9. Jun 10, 2022 at 1:48 PM
    Silver17
    Eastern PA
    These are the latches I was referring to just for reference. Not sure if the 22 uses the same style but these do slide forward a little in the 2nd gens. I’ve heard others complain of the 3rd gen bed rattle, no one has blamed the tailgate for it until this post that I’ve seen.
  10. Jun 10, 2022 at 1:56 PM
    15whtrd
    15whtrd Mr. Blonde
    I’ve got a tailgate seal. Basically weatherstripping to help keep the dust and water out. My tailgate shuts nice and snug
  11. Jul 8, 2022 at 8:30 AM
    molson7
    So had my Plat in for rear windows weatherstrip replacement (which still has gap but so far is staying in rather than popping out) and creaking/rattle noise over bumps from rear which is heard with back window down. They fixed the noise issue which was loose bed bolts that needed tightening. Report said they turned bolts 3 TIMES to tighten to specs.
    So in short my truck passed quality control without this being caught. What else got passed 'quality control'?
    If you have similar noise issue with rear window down I hope this helps. Can include pic of service order if someone needs for reference.
    Troyboy84 likes this.
  12. Jul 8, 2022 at 9:04 AM
    Hextorm
    Hextorm New Member
    Blake
    White 2022 Tundra TRD Sport CrewMax
    Where are the bed bolts located that they tightened? I may take a look at mine. Having same noise issue.
  13. Jul 8, 2022 at 9:26 AM
    molson7
    in the bed
  14. Jul 8, 2022 at 9:34 AM
    Breathing Borla
    Northern Illinois
    geez, they have a recall for the axle bolts too.
    tighten things up on the assembly line boys!
  15. Jul 8, 2022 at 9:42 AM
    molson7
    no doubt, makes me want to take a couple hours going around and checking tightness of everything. Wouldn't want to be driving down the road and have something fall off! Doesn't inspire confidence.
  16. Jul 11, 2022 at 5:56 PM
    ToyotaLifer6
    ToyotaLifer6 New Member
    Tom
    2022 Tundra 1794
    Factory
    I just picked up my '22 1794 and heard the same thing with the window down. Gonna check the clips ASAP!
    Crableg85 likes this.
  17. Jul 12, 2022 at 7:57 AM
    Crableg85
    Crableg85 New Member
    Michael
    2022 tundra platinum
    What clips are you talking about I have the same noise like thumping when hitting bumps
  18. Jul 14, 2022 at 5:41 AM
    ToyotaLifer6
    Tom
    2022 Tundra 1794
    Factory
    The latches noted above are actually one side of a latch mechanism that I referred to as clips...sorry for the confusion
  19. Jul 15, 2022 at 9:48 AM
    molson7
    Mine was more of a creak/rattle, your video sounds more like a clunk noise. Don't think it's the bed issue i had. Good luck with getting that resolved though.
  20. Jul 24, 2022 at 7:48 PM
    Levo1228
    Levo1228 New Member
    Lunar rock Trd crew cab off road SR5
    Mine sounds just like that have you figured it out yet.
  21. Jul 25, 2022 at 1:37 PM
    Hextorm
    Hextorm New Member
    Blake
    Ahhh I see. I've had a bed mat in mine since day 1 so I've never even seen those.
  22. Jul 25, 2022 at 7:55 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    any idea what the toque specs are?
    moonrover likes this.
  23. Jul 27, 2022 at 9:51 AM
    swageit
    swageit New Member
    Mark
    2018 Tundra Limited Double Cab
    Do you have a platinum? If so do you have AVS?
  24. Jul 28, 2022 at 8:30 AM
    moonrover
    moonrover New Member
    2022 Tundra SR5 TRD OR
    Wondering the same
  25. Jul 28, 2022 at 8:39 AM
    molson7
    I don't know the torque specs. The dealer tightened them during a service visit. When leaving the dealership it made a few creaks while in the parking lot but once on the road it went away. Hasn't returned since. I still have a minor rattle that i suspect is the tailgate. Planning on putting a rubber spacer on bed so tailgate play is removed once closed.
  26. Jul 28, 2022 at 10:05 AM
    KRLTUNDRA22
    KRLTUNDRA22 New Member
    22 Tundra
    Not sure about you guys but on mine the rattle from the tailgate is the straps that go from the tailgate to the bed. They rattle like crazy where they are connected to the bed. I have not figured out a fix yet but something to check out if you have the rattle & not the clunk noise.
  27. Jul 28, 2022 at 10:47 AM
    FomoToyo
    FomoToyo Lunar Rock / Terra Enthusiast
    Jake
    Frederick MD
    2024 Tundra TRD Pro Terra
    Just got my truck and noticed this today. Was also thinking the connection cables were the culprit.
    Levo1228 likes this.
