I bumped gas cap off
Discussion in '3rd Gen Tundras (2022+)' started by reese3303, Jul 7, 2022.
  1. Jul 7, 2022 at 4:50 PM
    reese3303
    reese3303 [OP] New Member
    SC Louisiana
    2015 Tundra 4x4
    I was filling up this afternoon and accidentally bumped the gas cap off with my shoulder.
    Is there a trick to snapping back in place. It sounds dumb, but the grooves that go in the receivers seem to work against one another?
    Should I just take to dealership?
  2. Jul 7, 2022 at 5:06 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I would take it to the dealer and tell them you just saw it on the ground when you got in the truck in the morning. If you say you hit it they may not want to cover it.
    Black@Blue19 likes this.
  3. Jul 7, 2022 at 5:11 PM
    EmergencyMaximum
    EmergencyMaximum New Member
    That would be a lie and may lead you down the rabbit hole. If it is hard to remove on its own, they might think someone tried to get into the gas tank in an unauthorized way and may send you to see your insurance and file a claim. Maybe even police report.
    I'd say: "hey gang, I accidentally bumped into it with my shoulder, any idea how I pluck it back on?"
    They are usually good willed people and will help you out, but if they sense BS...:smack:.......don't know what will happen next.
    Besides, why risk contaminating your own consciousness?
  4. Jul 7, 2022 at 5:18 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    From the way the tabs are aligned, it looks like you should be able to slide it on, side to side. That's what I would try. Good luck.
    Since there is a stop in the middle, I would try left to right first.
    =JSG= and EmergencyMaximum like this.
  5. Jul 7, 2022 at 5:25 PM
    MadMaxCanon
    Contaminating your consciousness? It's a car dealer, probably one of the slimiest institutions man has created. This world will eat your soul if you feel bad about lying to a car dealer.
  6. Jul 7, 2022 at 5:31 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    Don't look like any broken tabs. The cover just slides on.
  7. Jul 7, 2022 at 5:35 PM
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    I bet that will slide right back on.
    DBamaC and =JSG= like this.
  8. Jul 7, 2022 at 6:06 PM
    reese3303
    SC Louisiana
    2015 Tundra 4x4
    Ah, left to right!
    I will try that out and see if it slides on
  9. Jul 7, 2022 at 6:19 PM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Yep you may want to lie to the dealership, they lie to you. It's the circle of life. "That cover just jumped off my truck" :notsure:
  10. Jul 7, 2022 at 6:36 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    AE8EB854-4C05-49FB-BAB1-2F682F2F66C3.jpg The part still attached to the truck clearly has broken tabs.
  11. Jul 7, 2022 at 6:58 PM
    reese3303
    SC Louisiana
    2015 Tundra 4x4
    I dont think it does, but I’ll let you all know tomorrow how it goes!
  12. Jul 7, 2022 at 6:59 PM
    reese3303
    SC Louisiana
    2015 Tundra 4x4
    If I end up there tomorrow , I’ll certainly come up with some kind of bs
    Funnyguy713[QUOTED] likes this.
  13. Jul 7, 2022 at 7:20 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    I think that just dirt. The tabs are:
    Usually 6 outer tabs holds the cover and prevent it from popping outwards. The center tab one is a claw that stops it from sliding out.
  14. Jul 8, 2022 at 5:43 AM
    reese3303
    SC Louisiana
    2015 Tundra 4x4
    Went to the dealership and they snapped it back on.
    It slides back on from left to right, as oriented in picture (slides toward the hinge).
    I think this will become a common occurance for others.
    Was filling up and turned towards truck and hit the cover from the inside side.
    Didn't take much for it to pop off.
  15. Jul 8, 2022 at 8:11 AM
    22PlatWCP
    22PlatWCP New Member
    Mississippi
    2022 WCP Platinum 4x4
    Super glue is your friend
    DBamaC likes this.
  16. Jul 8, 2022 at 10:07 AM
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    Sounds like a job for JB Weld Man!
    Kidding. But, it might not hurt to slap a little adhesive or JB weld on the back side of the plate if it dislodges again.
